Question about IBM ThinkPad T21 Notebook
ERROR CODE I got this error message when I startup my laptop 0175:Bad CRC1,stop POST task. then press F1 to enter SETUP press F12 to choose temporary doot devive. at this stage then nonthing happens
  • sheif1968 Dec 23, 2007
    ERROR 0175 : Bad CRC1, stop POST task
    SAME PROBLEM IN MY A21M 2628
  • Anonymous Mar 12, 2008
    then
I have tried this, open the notebook from back and remove the CMOS battery and leave it for 12 hours, then boot the system and shutdown immediately and put CMOS battery on its place, then boot the system Junaid Pakistan
Posted on Feb 23, 2007
  • 624 Answers
It sounds like your computer can?t read the boot sector on your hard drive which it needs to start up. The most likely cause is mechanical wear which usually starts gradually and gets worse over time. The computer ?system? can generally overcome these read errors through a series of read retries at first but as the problem progresses it becomes more difficult. When this retrying becomes more common users typically notice their computer making a ?clicking? noise. Mechanical hard drives failures not uncommon on laptops where power settings have the hard drive shut off after 5 or 10 minutes of inactivity. This is done to increase battery run-time; unfortunately this puts a lot of stress on the hard drive. My default settings for all my laptops is to not allow spin down (shutdown) while on A/C power and when on battery only to spindown after 30 minutes of inactivity. I would go into your BIOS setup (F1) and verify your hard drive is still defined and as long as you?re there take a look to make sure the date and time are still set correctly. If everything looks OK quit out of the BIOS, shut down and restart your laptop, several times if necessary. If you are lucky and this is the beginning of the read error cycle then eventually you will be able to start your PC. If you are successful immediately backup your data, collect up your restore CDs and install a new hard drive. If you have any other questions let us know what additional info you have. As always please don?t forget to rate this post.
Posted on Jan 31, 2007
Unfortunately this is not a Hard Drive issue. When the Laptop displays "0175:Bad CRC1,stop POST task" The PC just freezes and does not let you go anywhere else, neither the Bios or Setup. IBM's only solution is to replace the Mother Board. There are other solutions is you google it but all of which require an investment of between $70-100. All in all it is much better to just replace the board which can be found on eBay from anywhere between $30 to $70. Hope this helps and Good Luck!!
Posted on Feb 09, 2007
ERROR 0175: bad crc1, stop post task
0175: bad crc1, stop post task ,ibm t20
Jan 16, 2011 | IBM ThinkPad T20 2647 Notebook
ERROR 0175: Bad CRC1, stop POST task message Been using my IBM a30 laptop for some months but was surprised to get this error when i tried putting it on this message pops up ERROR 0175:BAD CRC1 STOP POST...
You obviously didn't read the problem carefully. The machine won't boot, so there is no command line. I have the same problem with a T23. It might be the CMOS battery that needs to be replaced.
Jan 11, 2010 | IBM ThinkPad A30 Notebook
Post problem
If it beeps (which it should) means that some device did not pass post. Find your motherboard online and look up the beep codes. This should help you to discover the problem. I hope this helps!
Jul 15, 2009 | IBM ThinkPad A21m 2628 Notebook
Error 0175 bad crc1
Numeric error codes - ThinkPad General From IBM Web Site
Notes:
· The most likely cause is listed first.
· A numeric error is displayed for each error detected in POST or system operation.
· In the displays, n can be any number
Error code
Symptom or error
Field replaceable unit or action, in sequence
0175
Bad CRC1, stop POST task. The EEPROM checksum is not correct
This problem you may not be able to fix. There are a couple of things you can try.
1st Keep on rebooting your laptop until this error goes away.
2nd Replace the BIOS battery, it maybe nearly worn out. After replacement you need to go into the BIOS setting to set the Date & Time.
System board
May 16, 2009 | IBM ThinkPad T20 2647 Notebook
Error 0175 on boot IBM Thinkpad T20
Error code Symptom or error Field replaceable unit or action, in sequence 0175 Bad CRC1, stop POST task. The EEPROM checksum is not correct. System board
Mar 27, 2009 | IBM ThinkPad T20 2647 Notebook
Error 0175: bad crc1 stop post task
It appears that your BIOS battery is nearlt flat and needs replacing.
F2 function key is the normal BIOS setup key for Thinkpad
Jan 28, 2009 | IBM ThinkPad A21m 2628 Notebook
0175: bad crc1, stop post task, system bios shadowed
Go on tis forum and post your problem. There is also the Lenovo forum. I have a T23 and haven't seen this error before. These Forums are very good for information on your laptop.
http://forum.thinkpads.com/viewforum.php?f=28
http://forums.lenovo.com/lnv/board?board.id=T_Series_Thinkpads
Oct 02, 2008 | IBM ThinkPad T20 2647 Notebook
While booting error " bios shadowed " & 0175: bad crc1, stop post task
sounds like cmos battery flat small battery inside pc to retain cmos setting when pc switched off
Cannt get normal logon screen
i think your hard disk had be dsectors
try to boot your system with win xp bootable disk
then go to trecovery console
then run
chkdsk /r
comamnd at recovery console
followthe instruction
Sep 30, 2008 | IBM ThinkPad T22 2647 Notebook
Stop POST task, bad CRC1 error 0175
There are a couple of possibilities, go to this link for the solutions, but it could be a bad power supply http://www.hardwareanalysis.com/content/topic/31761/
Aug 07, 2007 | IBM ThinkPad A21e 2628 Notebook
IBM ThinkPad T21 Notebook Logo
414 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
