Question about Toshiba 57H84 57" Rear Projection HDTV-Ready Television
Xmas tree effect in tv
Dear Sir,
Tv has a tearing effect in picture(zig-zagging, xmas tree effect) audio is good, menu is good.
Karen Williamson
601-849-9212
  • sassis Dec 02, 2008
    Tv has a xmas tree effect, zig-zagging, tearing effect, i have run dvd through video 1, 2, 3 same effect, I have changed cable. I need help desperatelynow please
    Top Expert:
  • Toshiba Master
  • 78,267 Answers
I owned this same TV and this problem, it turned out to be a part called the convergence module, also a problem with the main circuit board, the parts alone where $600, then labor would have been even more, I bought a new LCD TV and been happy ever since, new TV cost little more than fixing the Tosiba, which by the way has a very poor service record, check out this on the net.
Posted on Dec 02, 2008
  • 10,594 Answers
Your TV needs HYPER Board, 23148017 replacement and its bit costly approx $269.00 and available in Part Store.
    Genius:
  • 1,239 Answers
Hi You have the TV connected to the cable box with an HDMI cable, I'll bet. The problem is with the cable box. If you unplug the cable box and plug it back it it will reboot and proabably work. You should connect the cable box to the TV using component cables and you won't have this problem again.
  • ABHISHEK.C
    ABHISHEK.C Dec 02, 2008
    or
    This is a problem with closed-captioning. What you are seeing is a closed captioning box with no captioning in it. Usually this is being accidentally transmitted by the cable company "head end". Just make sure your closed captioning function is completely turned off. if you are seeing it randomly, it may well be coming from your cable company. Is it just on certain channels?
  • 2,335 Answers
This type of failure is due to a defective hyper board. This type of repair might not be a DIY without a basic knowledge of electronics and know how to use a de-soldering/soldering iron.
    Sergeant:
  • 217 Answers
Its due to the faulty ic and blown capacitors on the main board.
  • 734 Answers
First of all if you are connected to a HD cable box or a HD sat. recvr. using component cables.
  • futureloginn
    futureloginn Dec 02, 2008
    This is probably a short in the TV, most likely a ground problem.,, make a proper ground (earth) for the the TV.
    that will Fix your problem.
  • futureloginn
    futureloginn Dec 10, 2008
  • 4,472 Answers
Does it do this on all the inputs? You will want to try different inputs and different cables, Even different jacks for example if your using composite try component or vice versa. If you need further assistance please let me know. Once I have more information I will be able to better assist you. Please take a moment to accept and rate my solution accordingly.
Thanks,
Lee
  • Lee A.
    Lee A. Dec 02, 2008
    Have you tried something else besides the dvd player? Like cable box or something else? It could be the dvd player if that is all you have tried. If problem persists you will need professional service.
    follow this link to locate the nearest service center.
    http://www.tacp.toshiba.com/customersupp...
    Please take a moment to accept and re-rate my solution appropriately.
    Thanks again,
    Lee
Cant get tension correct when zig zag on really strechy material
Be sure you are using a ball-point needle. Try setting the upper tension looser. You also may need to increase the presser foot pressure on your machine (consult your owner's manual if you don't know how to do this). Using a closed-toe presser foot (vs an open-toe embroidery foot) may help control the fabric and prevent it from puckering under the needle. Also, reducing the width of the zig-zag may be helpful.
Some sewing machines have an overlock presser foot. Effectively, there is a thin piece of metal in the center of the presser foot. The needle will straddle that piece of metal in a zig-zag so the upper thread has a little bit of slack in each stitch that will let the fabric lie flat. It is a very nice tool to have especially when zig-zag finishing raw edges too.
https://www.amazon.com/Janome-Top-Load-Overedge-Foot-Brush/dp/B00KCWB2SA
C9store overlock presser foot how to video
Some sewists will increase the fabric's "body" by inserting a layer of wash-away or tear-away stabilizer. If it is only a small project, a piece of paper added to the seam (like adding machine paper) will help stabilize the fabric.
One last thing to try would be loosening the bobbin tension. However, there is a reason it is the last effort, because most sewists are uncertain about messing with the bobbin and it is also requires "minute" adjustments to effect a big change.
How can properly adjust my tension
Understanding Bobbin Tension
Jun 18, 2016 | Sewing Machines
I'm not able to connect to the internet. My modem is a SURFboard SB6141 (Motorola). Here is te Light Status: Power: White Recieve: Blue Send: Blue Sphere: White Zig Zag: Blinking Orange
on the back or the bottom of that tv box in the picture there, there should be something that says something like: 'tv password' type in the tv password on your phone/tablet or whatever and it SHOULD work. if it doesn't then I'm so sorry I couldn't help :(
good luck! :) look at this website and it should work x
Jun 09, 2015 | Computers & Internet
How do I get it to zig zag
There is a dial or a lever that you turn it to. It usually has a straight line picture for straight stitch and a zig zag photo for the zig zag stitch.
Mar 01, 2015 | Sewing Machines
I have a Tacsew T20U73-1 straight stitch/ zig-zag machine and I am wondering how I go about making my machine go from zig-zag to straight stitch?
There has got to be a selector of some kind on the machine. Usually it will be marked with symbols indicating straight or zig-zag stitch. You may also try varying the width of the stitch. The wider the stitch, the more pronounced the zig-zag effect.
Aug 18, 2011 | Vacuums
We cannot get sound through the yamaha amplifier while watching a dvd? TV and Foxtel works but we only get sound from the tv when we are watching a dvd. we have a Sony Bravia TV and a Yamaha HTR6130...
You need to connect the unnamed DVD player's audio to the receiver according to the player's manual and then assign the digital input on the HTR (if applicable). THAT would be in the HTR's manual (page 6).
I'd run the DVD's best video straight to the TV. Nothing good comes from having unnecessary cabling or interconnects zig-zagging across the room.
Jun 26, 2011 | Yamaha Audio Players & Recorders
Only get zig zag lines in viewing window no picture
1. try to setup a different setting in setup menu where are you can setup the NTSC or PAL sistem2. change the driver
I think the driver change will help.
Feb 01, 2011 | KWorld PC to TV (0872880887527) Video...
Zig zag problems
oh my i think you need to open your machine sir. i already tried it. kinda hard to explain it here
Sep 05, 2008 | Brother LS-2125 Mechanical Sewing Machine
My phillips ts2746c221 model
If it is a horizontal line is straite or zig zag, if it is straite then problem in your vertical section,please check the supply of vertical section or output ic of vertical, if it is zig zag line then it could be dry solder in the yoke connector or vertical yoke open, please let me know the vertical ic no.
Oct 22, 2007 | Philips 27PT71B 27" TV
Distorted picture
when you say distorded, is it like a 3-d effect? or more of zig zag type lines in the picture. If there are color outlines like a 3-d effect, then you are having a convergence preakdown, and are going to need to have the convergence IC's replaced. if the problem is the piture is zagged edges and zig zag, lines or a smearing effect, most likly it is the PIP modle is going bad, and even if you dont use the PIP, the video still goes through that module. If it does not have a PIP feature, then there are bad capacitors in the sweep power supply and the problem will get progessivly worse till the set wont come on anymore. Hope this helps. Good Luck
Dec 28, 2006 | Mitsubishi WD-52825 52" Rear Projection...
Toshiba 57H84 57" Rear Projection HDTV-Ready Television Logo
23 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
