It wont drain water from it's tank..
Model is LG WM1285FHD washing machine
  • 121 Answers
Check the dran pump it may have something stoping it
Posted on Dec 02, 2008
My lg wt-h750 wont spin or drain..
the pumps clogged or the drain pump is bad,the washer won't spin until all the water is drained out.also that model number doesn't show up,open the door to the washer look around the opening where you put the clothes in and you'll find the model number there
Nov 11, 2017 | LG Washing Machines
Lg top loader washing machine wont drain?
watch if the water pipe is connected
May 19, 2015 | Washing Machines
What is the error code CL mean for LG WM1285FHD
LG washing machines indicating error code CL may have the child lock activated.
Try holding down the temperature and eco/rapid options together to turn off child lock.
Some LG series use "TEMP and OPTION" at the same time.
Thanks
Oct 10, 2011 | LG WM-2277HW Front Load Washer
Hello, I have the LG Washing Machine Model WM1832CW and I'm having drain issues. The machine itself wont drain the water out. The water remained in the machine. Please advised on what I need to do in...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 26, 2011 | LG WM-1832C Front Load Washer
My washing machine is not spinning anymore
Do not think this is the problem. Make sure pumping out properly,,Could also be motor brushes if its an older machine...
Nov 10, 2009 | Washing Machines
LG intello washer WM1285FHD The code CL is on display how do i clear and get machine to work?
CL == Child Lock.
Press "Wash" & "Rinse" buttons simultaneously to set / clear.
Dec 26, 2008 | Washing Machines
LG Intellowasher cannot complete spin cycle.
Unplug power cable, remove top cover and inner panel, locate water level sensor on the right with 3 wires and a thin tube, remove the tube and puff into it until you hear water bubbling. This will clear any blockage caused by suds build up. Replace tube, covers and plug back in. It should complete cycles now.
Sep 11, 2008 | Washing Machines
LG WD-8074fhb
Your problem is either in the control board or the water level switch.  The computer can't tell if the water has drained or the control board is stuck in the 8 minute drain cycle.  Recommend pulling the plug and wait 5 minutes to reset the computer.  If the problem persists, it will require an LG experienced tech to see what's going on.
Mar 14, 2008 | LG WM1814CW Front Load Washer
Washing Machines Logo
44 people viewed this question
Top Washing Machines Experts
