The machine has worked properly since I got it new (even though it is an old model) about 2 years ago. All of a sudden, it began to turn itself on at random. It does nothing other than power up and never turns itself off. First, I tried to resolve it by covering the IR remote sensor thinking that something was sending a signal. No change. Then I unplugged the unit to completely drain memory and left it without commercial power for an extended period. I then re-connected to power and did no programming whatsoever. No change. Then I completely re-programmed the unit. No change. The last thing that I tried was to go into timer record--even though no programs were scheduled and clear all timer settings. No change. Any ideas? I really love the unit but in this condition, it is a serious problem. Thank you very much.
SOURCE: after programming my new universal remote, the tv keeps changing chanels! wont stop!
you need to program your remote control. take the battaries out. and maually turn the tv on. then hit the source you want to view. for example, I want to control the tv set. I push, code search and hold it then push the source button and then release the source button and then release the code search button. now, aim at the tv and then keep pressing power button till it goes off. when the tv is off, hit return or set or something like that.( every remote has different calling for it but still the same function) it should work. try it and let me know.
SOURCE: Can't program my cable remote to work with tv volume
So I had the same question and found this web page.
http://support.cox.com/sdccommon/asp/docview.asp?sprt_cid=bd70d786-6d94-45e7-9fb7-7fc5345157d4&sprt_verb=preview&sprt_ct=sprt_resource&fname=Raw+Document&sprt_usage=false&sprt_rate=false> target=_blank”
So I hope this helps
SOURCE: programming my remote
http://66.77.167.109/rcaaccessories/BrandCode.do
go here for your codes to any rca remote
SOURCE: compatibility with remotes
Have you tried this link?
http://www.garagedooropeners.us/helpgifs/maincode.html
Mike
SOURCE: Magnavox Model #PR1910 C123
It is very very rare for this to happen. I would try other remote or you can google universal remote codes and look for other codes.
