Question about Toshiba DKT-2020 Corded Phone
# button does not transmit DTMF tone when pushed
I can't dial in to conference calls of mail because the phone does not transmit a DTMF signal whe the # sign is pushed
  • 45 Answers
YOU DO NOT HAVE A speed dial programmed.
If you hit *# then # it will work or have a programmer prog a speed dial button.
info@ameritelnj.com
Tony
Posted on Apr 03, 2009
Is it possible to call out with this phone,it has an old fashion dial
I assumed your old-fashioned phone works in Pulse (Rotary) mode only. Maybe the Tel Company or the Private Tel Exchange in your house supports only DTMF (Dual-tone Multi frequency) or MF (Multi Freq.) tone.
Sep 05, 2015 | Lands Phones
Want to change dial pulse out dialling to DTMF tone dialing
unless your phone supports that (and has a little switch somewhere), you just can't. Get another phone, sorry !
Jan 22, 2014 | Nortel Meridian Norstar M7208 Mics Cics...
NET10 W408g does not allow using the Xlink gateway fully, especially sending DTMF codes to automated systems.
Jim
Been a long time since I have seen this phone but I seem to remember a setting like this. Some phones had a long and short setting too.
Mark
Motorola Support
Activate DTMF tones: Menu > Settings > Initial Setup > DTMF When you dial a number, your phone sends it to your network as Dual Tone Multi Frequency (DTMF) tones. To send DTMF tones during a call, just press number keys or scroll to a number in the phonebook or recent calls lists and press Options > Send Tones
Dec 17, 2012 | Motorola Mobility W408g - Silver net10...
My KX-T7030 phone will not send a tone during a call, so I cannot "Press 1" or any number to use automated options. It does dial numbers ok??
If it dials O.K., try pressing # and see if it turns on the DTMF pad. You could have pulse dial on outside calls enabled, and that would keep the keypad in pulse mode until it's told to send tones.
This is really only a guess. The type of dialing is programmed in CO trunks and it's possible it's been set to Call Blocking! It is designed to send pulse only and block the audio of DTMF so the CO won't get confused. You might start with changing the Type Dial to DTMF and test. If that doesn't work, try Pulse and test. Last, if that doesn't work, you will need to keep call blocking and try the # after dialing.
Please comment back if it does or doesn't work. We don't see much pulse dial around here.
Carl
Dec 09, 2009 | Panasonic KX-T7730 Corded Phone
How do I do conference calling?
With caller on phone, press the conference button. You will get intercom dial tone. DIal another extension or grab a line and dial another cell number. When connected, press "conference" again, and you will all be together.
Jun 24, 2009 | Nortel T7316E 2-Line Corded Phone
Need procedure for dialing 3-way or conference calls
while on a call, press the talk button
you will now hear a dial tone or just silence
dial the number to the 3rd party at this time.
after the 3rd party has answered press the menu button and select 3way/ conference.
these direction must be followed as closely as possible
May 04, 2009 | Samsung SCH-a870 Cellular Phone
Conference Calling
If you have a flash button, you would use that to place the first call on hold and dial or answer a second call. If this is a single line phone in your home, you would have to have "Three Way Calling" feature with your local phone company. If you do, you could ask them what the dialable feature code is. It's possible they allow you to use your flash button, get dial tone and dial another person, when they answer, flash again to conference. If you don't have a flash button, they you would be using your Green or Off Hook button that you use to get your dial tone.
Apr 03, 2009 | Panasonic Lands Phones
ID 27831F32
DTMF is techno-speak for tone dialing (as opposed to pulse). Your GE phone is DTMF.
Nov 20, 2008 | GE 27831FE2 Phone
Where is the Initial Setup at?
DTMF tones will not fix your length of rings before the phone kicks over to voicemail. You have to call your wireless carrier to fix that because voice mail is an external system on your wireless carriers NETWORK.
Changing the DTMF tones from short/long to off will only make your Voice mail prompts not work :) you always want your DTMF tones to at least be on SHORT.
And your right, DTMF tones are not on the LG phones because LG knew there was no point to that... IF a customer shuts them off they'll only be calling their wireless providers saying "every time i press a button for the selection i want.. it never registers!"
Hope this helps
Dec 12, 2007 | LG VX8300 Cellular Phone
Can't get to voicemail
Change the DTMF found in phone settings (Initial Set-up) to either short or long. When this is set to off, the voicemail cannot pick up the numbers you type.
Oct 25, 2006 | Motorola Mobility RAZR V3
Toshiba DKT-2020 Corded Phone Logo
143 people viewed this question
Top Toshiba Lands Phones Experts
Oloyede Monsuru
Are you a Toshiba Lands Phone Expert? Answer questions, earn points and help others
