Question about Canon PIXMA MX310 All-In-One Printer
Cannot print from Apple MacBook to Canon MX310
  • nathan541 May 11, 2010
    you need to be a little clearer as to the problem - a cable? Do you get an error message?
    Have you ever printed to it before?
    Guru:
  • 206 Answers
First, check your USB printer connection to your Macbook from your Pixma MX310 printer.
If the USB cable is securely seated, make sure you have installed the updated drivers for your version of Mac OS X. Here is the Link:
Canon Pixma MX 310 Drivers for Mac OS X (v10.6/10.5 and earlier).
If you have already updated your printer drivers to the most current Canon Pixma update for your version of Mac OS X, then click on the Apple menu icon, located in the upper left corner of your screen and select System Preferences.
• From System Preferences, select Print & Fax.
• Within the Print tab, make sure you can see your Canon listed in that window.
If you can, proceed to perform a test print on any document you have on your desktop or folder of choice. If this does not help, from within the Print tab, select the Canon and press the "-" Minus button and remove that printer.
• Once it is removed, now click the "+" button
and re-add your printer.
• Once it has been added, attempt to test print again.
This should help get your printer back to printing again.
Regards,
-Mactechtrainer
Posted on Jan 31, 2010
  • 600 Answers
Have you selected the printer? when you press print (apple key and "p" together) the drop down box has on the first line a printer select feature, click on the square with a little up and down arrow and it will expand to a list, select your printer if it is on the list, if not click the "add printer" button and follow instructions. Unless instructed otherwise OSX installs drivers for most printers.
Posted on Aug 13, 2009
  • 3 more comments
  • Chris Edwards
    Chris Edwards Aug 16, 2009
    Try to print (apple key and "p" together) the print window, first line has a blue button with small up and down arrows, click on this and there is a facility to select printer.
  • Chris Edwards
    Chris Edwards Aug 19, 2009
    try to print (applw key and "p" together and the print window will appear, top line has a blue button, click on button and a menu appears, click add printer and if yours is not there click the browse button, make sure printer is plugged in to power and usb and switched on
  • Chris Edwards
    Chris Edwards Aug 21, 2009
    Try to print, when the print window appears to the left of the top l;ine is a blue box, click on box and a menu appears, second to bottom line is add printer (unless printer is in list then just select it) click add printer and follow instructions
  • Chris Edwards
    Chris Edwards Aug 25, 2009
    Hwat happens when you attempt to print?
  • Chris Edwards
    Chris Edwards Dec 30, 2009
    have you selected it in the print window? also all in ones often come with their own integrated software have you installed it?
Hello, l have recently purchased a macbook air laptop and l am trying to figure out how to get it to print to my canon Pixma MP480 printer. Any suggestions??
You need the printer/driver software. In your Apple system prefs they have a lost of printer/drivers available - you need to check if yours is on there, you might have to download from Canon.
Mar 29, 2011 | Apple USB 2.0 Ethernet Adapter for MacBook...
Can not get my MX310 to work on the wireless network using apple airport extreme and mac
The MX310 is not a wireless printer. You must use a USB cable from the computer to the printer to print.
Mar 06, 2010 | Canon PIXMA MX310 All-In-One Printer
Attempting to print to a Canon MX860 remotely results in the file printing at a very reduced scale Attempting to print email message The printer is connected to a Apple Time Capsule. The Time Capsule is...
Change the scale in the print options. The print options can be seen when you start to print something. There will be an option asking "print to scale"...select that and you should be fine.
Nov 03, 2017 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
Canon mx310 feeds paper w/out printing
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 09, 2009 | Canon PIXMA MX310 All-In-One Printer
Sending a fax directly from computer using Canon Pixma MX 310
With the document open, you click Print, then choose Cannon ...Fax.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=15603
Jan 02, 2009 | Canon PIXMA MX310 All-In-One Printer
Scan problems with Canon MX310
i have found the way to scan items from a Canon MX310 (on windows)
1.On windows go to control panel
2. click hardware and sounds
3. then hit devices and printers
4. then click on the Canon Inkjet MX310 seriers
5. then you will see scanner management click on scan Photos or docs
6.then place the photo or doc under the scanner and hit scan!
That is all the steps you will need.
17 years old computer tech.
Aug 16, 2008 | Canon PIXMA MX310 All-In-One Printer
Can't print to mac wirelessly (could do it a few days ago)
I had the same problem until recently. You have to install the drivers FROM THE CD that came with the printer, instead of selecting the drivers from the default list. Then, when selecting which printer driver to use (you'll have two options) choose Canon IJ and NOT Canon MX310 series. This is a problem with their MX310 driver, which is solved using a default/generic Canon InkJet (hence, the IJ) driver. Hope this helps!
P.S. This only works on Mac OS X. I have yet to figure out how to print wirelessly through Vista. Will keep you posted.
Mar 28, 2008 | Canon PIXMA MX310 All-In-One Printer
Canon PIXMA MX310 All-In-One Printer Logo
269 people viewed this question
old marine
old marine
