Question about Sigma AF 70-300mm f/4.0-5.6 DL Macro Super Lens for Canon-EOS
Err 01 Communication between Camera & Lens is Faulty
I've just purchased a Sigma 70-300 F4-5.6 lens for a Canon EOS 450D.
When I take a picture I get an error message ERR 01 Communication between Camera & Lens is Faulty Clean the Len Contacts.
To take pictures I have to switch the camera off after taking a photo then on again to view what I have taken a photo of.
Please help as I have very little knowledge of this sort of thing and would appreciate any help greatly.
  • 2 more comments
  • Anonymous Feb 15, 2009
    Just installed an old canon 28-90 EF lens on a new 450D and received the same problem. Autofocus works, confirmation works. It could took 2 pics for me and showed them. (although they were not sharp at all). On the third time camera reported err 01 and that`s all
  • Anonymous Mar 06, 2009
    I have the same problem with Lens sigma 28-300 DG macro.
    I cleaned the lens contacts but it does not make it difference,
    What to do? I appreciate any opinion
  • Pedroash Mar 11, 2009
    So frustrated with this same problem,Sigma 70-300 (APO Macro super),and my Canon 450d are not communicating,Dreaded ERR1,Cleaned contacts as instructed,and sometimes it actualy allowes me to take a couple of Pics before it decides to give me only the ERR1 sign.Dont realy want to have to buy a Battery Grip,( chookin's solution),but guess I may have to consider!!!!!!!!!
    Peter S
  • cmull May 05, 2009
    i have the same problem and would love to know if chookin's solution has workrd for anyone else?
Cleaning the contacts did nothing for me. what ended up fixing it was turning the camera to AV mode and setting to the highest f value. (f22) and then taking a picture. after that i was able to change it to what ever and resume as normal. hoping i dont see that error again.
Posted on May 02, 2010
  • 9 Answers
Most of the old Sigmas have problems with the Digital Canons. Sigma didn't buy the EF patent so they tryed to reverse enginer it. The "BUG" is regarding aperture. you can only use then in AV mode (the lowest F in you lens). I use a Sigma 70-210 and a 70-300 APO this way.
Only the new Sigmas (it has DL on the name) are fixed not to return that error.
PS - If the lens is in any other F that it's not the lowest one it will always give the error (even in AV mode). You need to go into a 35mm Canon with EF and set it to the lower F. Then you can use in Digital EOS Canon Cameras.
Posted on Jul 03, 2009
  • 4 more comments
  • Heather Workman Nov 11, 2010
    K I am not sure I am understanding this well enough. I also have a 70-300mm DL, I can not get it to take sports photos. Low light..Dark. Or long distance as I should be able to. I also ONLY on Sports and Dark shots I am getting a message saying that there is a communication error. between lens and camera.
  • HELMI_07 Feb 04, 2011
    HI.. Thanks for the tip.. I just purchased the 70-300 lens and it didn't work in manual mode...
    I tried it in auto mode and somehow it works fine... I then tried ur tip by lowering the F to the lowest F and it works even in manual mode.. THanks for this....
  • Fongolicious Apr 09, 2012
    I had the same problem as HELMI_07. I have a Canon 60D dSLR with EFS 17-85mm lens. I've used it manually before. But halfway through an outdoor excursion I had the err01 message. If I put it on auto or semi auto it worked fine. When its on full manual I encountered the err01 message. I switched to my 50mm f1.4 prime and it was fine on all modes. So it must be the 17-85mm lens. After reading this post, I just tried reducing my f to the lowest number (widest setting) and did a few test shots and it worked. Thanks.
    I had the same problem as HELMI_07. I have a Canon 60D dSLR with EFS 17-85mm lens. I've used it manually before. But halfway through an outdoor excursion I had the err01 message. If I put it on auto or semi auto it worked fine. When its on full manual I encountered the err01 message. I switched to my 50mm f1.4 prime and it was fine on all modes. So it must be the 17-85mm lens. After reading this post, I just tried reducing my f to the lowest number (widest setting) and did a few test shots and it worked. Then I increased the f stops, and its working now too. Must be a silly bug, and not just with SIGMA lenses. Thanks.
  • wasimabbasto
    wasimabbasto Dec 07, 2012
    'hello every one hope it will solve my problem i have canon D450 some time it show the error "communication error between camera and lens " plz show me detail procedure
  • Ishtiaque Mahmud
    Ishtiaque Mahmud Jul 24, 2014
    i am having this on my canon 550D and canon 50 prime. used this highest and lowest f manual. didn't work. what to do now??
I had the same prob with the Sigma lens [70-300mm af] and was pulling my hair out. I have a new Canon EOS 40d that would constantly give me the dreaded "err 01". No matter how much I cleaned the contacts or adjusted the aperture, nothing would work. I tried turning the auto focus off and on, pulled the focal length in and out, nothing. I ended up buying an after-market battery grip on ebay [$120.00 and came with two batteries] and had another go at attaching the lens. Straight away, bang, it worked. It seems, at least in my case, the single battery in the camera just doesnt have enough oomph to run the lense. It even works now in maximum burst mode, which is what you really want for shooting fast moving distant events. I'm stoked. [that's happy in aussie slang.] Hope this helps you out.
Regards
Jason
Posted on Feb 11, 2009
  • Tim Scott Oct 06, 2012
    I have the same problem with my Canon Eos T4I and already own a after market battery grip so I believe I will try this. Great suggestion and hope it works.Just got the lens used and don't care to send in for repair. I am a little mechanically inclined so I would rather take care of the problem myself instead of paying someone else to repair.Thanks for the suggestion. Tim
I have this same problem, with a canon T1i. i did this n it works out:
switch off then switch on ur camera. DONOT FOCUS OR do anything. put camera to AV(aperture priority) and set to lowest F no. 4 in this case, point , focus manually --shoot! works all the time! PS. this is a software bug error not a physical error, so DONT clean the, contacts, dont press down n stuff!
njoi!
Posted on Feb 28, 2011
  • 2 more comments
  • baz j May 14, 2011
    I have the sigma 70-210. It seems to me that the EOS1000D body does not recognise the max f stop is 5.6 and in sopme situations tries to shut it down more than this causingthe crash and err01 message. I have managed to take photos at f5.6 by scrolling the thumbwheel down to f4 in the AV mode, taking a picture and then the camera seems to work in any other mode. Keep an eye on the f setting in the viewfinder before taking the picture to make sure f stop is niot more than 5.6.
  • liveislam909
    liveislam909 Dec 18, 2012
    Awesome! thanks it worked!
  • Thomas Simons Jul 08, 2013
    Its work for me too, thx sooo much!
  • Giorgia Bertolino
    Giorgia Bertolino Apr 22, 2016
    You made my day, dude! Thank you so much.
    Scholar:
  • 170 Answers
Try to clean the electrical contacts between the camera and the lens with an eraser. Be careful not to let any debris fall into the camera body. If this lens has an aperture ring, set it to the minimum aperture (maximum number available)
Posted on Feb 10, 2009
Okay so i have a similar problem. On a 40D with the 17-85mm lens.
I haven't found anything useful re permanent fixes. It seems this issue is widespread and apparently due to bad build quality..
TEMP FIX: I leave the aperture at 4 and its fine but when i put it higher i get err 01 then i find if i zoom a little anything past 24-35 range and i can jack the aperture up as much as i desire. Just a little hint so you dont ditch your lens altogether. peace
Posted on Mar 01, 2010
  • oshim1 Jul 04, 2011
    Thanks! It helped. I have the same problem with the kit lens 17-85mm on canon 40D.
There is aparrently a similar problem not just with your Tamron lens, but also with Sigma lenses. I have just been given the Sigma 70-300 APO for Christmas for my 450D. I am somewhat disappointed. In full auto mode (idiot mode) only it seems to work fine, but in P mode and TV, in which I mostly work, it returns "comunication between camera and lens is faulty,clean the lens contacts". The contacts are not dirty - just to be safe I cleaned them with a trusted contact cleaner (I'm an electronics engineer and know about contacts). With my daughter's 350D it will not work at all.
These two manufacturers are of course manufacturing lenses in competition with Canon !!! Canon lenses are good, the top of the range are argueably if not possibly the best available today -but at a price only the professional or banker can afford (sadly) I've borrowed a couple of their top lenses in the past - wow!
I am going to try a firmware update, if this does not work then I will contact both Canon and Sigma. Perhaps they will have a solution. I doubt it, the problem has been known for a long time it seems. Look into other Forums for help as well. The problems are varied and sometimes erratic. Hope this helps ... OK, not really !
Posted on Dec 24, 2009
I have the same problem with my newly purchased 50D and my old Sigma 75-300 that I use with my 650 EOS 35mm. The Sigma is the only lens that I have a problem with and it works fine on my 35mm.
I have found that putting a moderately slight downward pressure on the lens works. The contacts are located in the bottom portion of the lens/camera interface and this seems to increase the contact between the two. I hold the lens at about the halfway point when I do this, with my hand placed on the side to top of the lens, pulling down. So far, it does not appear to interfere with the pop-up flash coverage, although I usually shoot with a Speedlite.
I buying a battery grip because I want the extra battery life, not because of this. But if it helps with this problem, that's o.k., also. I know that putting the slightly moderate pressure down on the lens will not hurt the camera (or the mount), but still, I shouldn't have to do that to operate it with this lens.
Posted on May 16, 2009
    New Friend:
I've just purchased a new Canon EOS 60D, and experienced this problem when using my 15 year old Sigma 170-500 EPO lens. The work around, as MarsWalker so helpfully points out, is to use the widest aperture setting on the lens. I found that any other aperture setting other than the widest resulted in this error.
Posted on Jan 09, 2013
Had the same problem with a new tamron 17-50 on canon 550. i took the battery off. turned on the camera (witout the baterry) turned it off and then on again with the battery. IT WORKS!!!!
Posted on Sep 30, 2012
  • Alfie Feb 12, 2013
    Thank you! This worked for me!
I have same camera and lens as you, also getting the Err 01 message, must turn camera off and back on every time. Equipment about 2 years old, but this problem started about 3 months ago. Just about ready to give up -- any ideas?
Posted on Jul 11, 2012
  • huskydog781
    huskydog781 Jul 11, 2012
  • Jo Lukins Jul 28, 2013
    Just wondering if you found a solution? I have had my camera 2 years and the problem has just started for me. Camera is a Canon 500D and the lens is a sigma 18-250mm
I have a canon eos 450d and it wont let me take any pictures with any settings just comes up with: "err 01 Communication betweenThe camera and lens is
Faulty.
Clean the lens contacts. " i've tried cleaning the lense, and it didn't work! I'm an animator, and I really need to get it fixed soon as possible, any suggestions please?
Posted on Mar 12, 2011
I have a tamron 18-200mm , canon 450 eos and when i take a picture the camera send me an error "comunication between camera and lens is faulty,clean the lens contacts" , what can be the problem?
Posted on Nov 07, 2009
Thanks for all that. I have 450D, too, and sometimes use a Sigma fixed focus 400mm on my EOS10 and Rebel EOS500 with no probs so that's why I bought the Canon camera to replace them - I hoped! But, like others I am getting the message: Err 01
Faulty.
Cleaning didn't work and I used alcohol to clean the contacts. I had a theory about battery poke and maybe that's the real prob. Gonna try the pressure trick and then might see whether there is a way to extend the contact pins a fraction.
Posted on Mar 26, 2010
2 Suggested Answers
  • 84 Answers
SOURCE: I've just purchased a Sigma 70-300 F4-5.6 lens for
It is asking you to clean the electronic points on the lens that come into contact with the camera body when the two are fitted together, in order to power the lens functions.
If other lens work ok, try giving the lens electronic contact point on the mounting plate a light rub with a dry cotton-bud, may be a fingerprint .
Posted on Oct 14, 2009
Error 01 in canon eos 5d
Err 01: Lens to body communication error
1.The camera to lens communication is somehow being interfered with could be a problem within the lens itself, possibly the camera body, or something as simple as a smudged fingerprint on the lens mount contacts,
2. Check the lens and the contacts
3. Also check below link if you need a canon eos 5d service manual
http://goo.gl/1rXwuc
thanks
Apr 26, 2012 | Canon EOS 40D Digital Camera
I have a Sigma 70-300 mm lens 1:4-5.6 DL. it works on my EOS 450D does it also work on an EOS 500D hoping for a reaction
Hi
Here's Sigma's Webpage. You should call them at 1-800-896-6858 to verify this lens will work, as I can not find a listing for the "DL" lens you have.
My initial response is that if it fits the 450D, it is a Canon mount and should work about the same on the 500D assuming both cameras have the same size sensors.
Again, a free call to the manufacturer is going to provide the best possible information on compatibility issues between this lens and various Canon camera bodies.
Jan 21, 2012 | Cameras
How to repair err 01 on canon 1000d "Communication
So, have you cleaned the contacts? Remove the lens and using a cotton swab lightly dampened with rubbing alcohol, clean the contacts on the lens and the camera body where they meet.
Oct 15, 2011 | Canon EOS Digital Rebel XS / 1000D IS...
Hey! I purchased a Sigma lens 70-300mm macro ____ and after I've attached it to my Canon 450D a take one or several pictures I get the "Err 01" problem, that "the communication between the camera and...
According to Sigma, your lens should be fully compatible with your camera although there will be the usual 1.6x crop factor as the lens is designed for a full frame sensor. This would not cause your Err 01 fault though so you should return the lens to your dealer for refund or exchange. Failing that, consider claiming on Sigma's one year international warranty. The warranty is ONLY valid if your lens was supplied with the Sigma Warranty card. All new Sigma lenses supplied through official resellers include the Warranty Card. You can find more details about where to send your lens for a warranty repair by clicking here.
Good luck, and please take a moment to rate my reply.
Sep 16, 2010 | Sigma AF 70-300mm f/4.0-5.6 DL Macro Super...
I've just purchased a Sigma 70-300 F4-5.6 lens for a Canon EOS 450D. When I take a picture I get an error message ERR 01 Communication between Camera & Lens is Faulty Clean the Len Contacts. To take...
Oct 14, 2009 | Sigma AF 70-300mm f/4.0-5.6 DL Macro Super...
I´ve been trying to use my Quantaray 70-300 mm lenses with my Canon EOS 450D. It gave me Err01 message (communication fault), I cleaned the lenses and it started taking the pictures but one at a time,...
Canon leads the current world market in lenses with their L-series lenses using fluorite rather than other manufactures use of glass. however, they do not make money when we buy 'other' brands of lenses and have kept a certain amount of their body to lens, coding as propriatary. the problem you stated is a common complaint with all second manufactured lenses and the only real solution is to put a canon lens on a canon body.
Sep 28, 2009 | Sigma AF 70-300mm f/4.0-5.6 DL Macro Super...
Canon 450D, ERROR 99 only when flash pops up
Err 99 usually means your lens contacts are dirty either on the lens itself or on the camera.
To isolate the cause of the issue, do the following: -
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert only a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99" message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99" message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99" with a different Canon lens attached, then the camera is faulty and should be serviced.
Mar 31, 2009 | Canon Rebel XT / EOS 350D Digital Camera
When I try to take a picture with my New Canon 450d/Sigma 70-300
check your card,change with new cf.That might fix problem i had the same issue and it was my card.
Mar 29, 2009 | Sigma AF 70-300mm f/4.0-5.6 DL Macro Super...
Problem with sigma 70 300mm dl
If the lens is a super it may need a rechip
Aug 19, 2008 | Sigma AF 70-300mm f/4.0-5.6 DL Macro Super...
Trouble focusing with sigma 70-300 DL macro
it may not be compatable with digtal camers to test set camera to AV get a iris of F22 using the stopdpwn button see if it stops down if yes it is compatable but faulty if nothing it not compat and need rechiping
Sigma AF 70-300mm f/4.0-5.6 DL Macro Super Lens for Canon-EOS Logo
37,184 people viewed this question
Top Sigma Cameras Experts
M_Butkus
Steve
Are you a Sigma Camera Expert? Answer questions, earn points and help others
