Ive got a philips mcm11 midi hifi, everything works fine but the lcd display is not working so i can see to tune my radio in or when i,m playing a cd i cant see the track number, please advise thanks
  • Anonymous Mar 07, 2009
    the LCD display stopped working on my Philips MCM 11 - still not figured out how to get it back... Help appreciated
3 Suggested Answers
  • 4234 Answers
The first thing to check is the solder connections on the display itself. Look specifically at the connections on either end of the display. These are the supply pins. Also, I don't know if this model has an LCD display or LED. If LCD, then make sure that the back light is funtioning.
Keep us posted on what you find.
Posted on Apr 11, 2008
  • 2632 Answers
Welcome to Fixya. The user manual is on the link below.
Philips MCM11/30 Manual
Thanks for using Fixya
Posted on May 24, 2011
2002 acura tl type s cd player works but sounds distorted, everything else plays and sounds fine?
thats a lazer problem in the cd usually a cd cleaning disk will sort that problem if not a its the lazer head thats distorted best this to do it put a conversion tape to ipod or iphone and play your tunes off those devices via your tape, there only cheap to buy.
May 04, 2014 | 2002 Acura 3.2TL
Speakers for Philips fwm154 stopped working
So the speakers are working but the mini hifi is not generating any sound to them. Replace the mini hifi, keep the speakers.
Dec 15, 2013 | Philips FWM154/05 MP3 Mini HiFi System
Display not working after installation
If everything else seems to be working, the display may have failed.
Jan 23, 2018 | Sony XPLOD CDX-GT200 CD Player
After many years of use the Radio does not play. CD is o.k.
its very possible and most likly that the antenna receiver unit in clock is worn out, unfortunatly there is no cure for this as you cant buy replacment parts for it
Nov 07, 2009 | Philips AJ3980 Clock Radio
Everything works except the radio. It appears
If have factory amp you have to find the turn ou wre for the amp and hook it up to the amp turn on wire from the radio(bootleg way sound might cut in & out) or go to local sound shop and get a bypass for the amp
Aug 07, 2009 | Jensen's VM9312 Car DVD Player
CDA 9885 No idea why it suddenly stopped working
It sounds like you have a bad ground connection. You need to take the radio out and check all the connections. I bet you have a loose one somewhere. That is what the problem was with my bronco
Sep 08, 2008 | Alpine CDA-9885 CD Player
Problem with my MX Gt 88!!
use the speakers it came with it works fine for me i have mine hooked up to a 300w inverter anything less i dont get the best sound you cant turn the volume up too loud on the reciever it will draw too much power and shut it off or blow the fuse in you car unless the inverter you are using has an external fuse on it my inverter warns me that i am drawing to much power so when i hear the beep i turn it down a notch and works fine but ya try using the speakers th system came with
Nov 02, 2007 | JVC MX-GT88 CD Shelf System
Music Won't Play
ok I had this happen before
Try unplugging the possitvive battery from your car let sit for 5min or open the doors and turn the key making sure that your car is completly dead. then put the possitive wire back on.
this will reset the deck and make sure you also have the setting s correct I thin it called I tunes is set to on in the menu opptions
May 01, 2007 | Alpine CDA-9855 CD Player
52 people viewed this question
