Have you deleted or changed settings for the Recovery Partition on your hard drive ?
You should retry Recovery a few times to make sure.
If not, then you will probably have to reinstall your operating system. Before you do, you can remove the harddrive (some models are easy, other require disassembling) and plug it into another computer to extract your data (providing the HD is functional).
If you provide more details on the "crash" or error messages you get on startup, maybe we can get it going without having to reinstall your Operating System.
SOURCE: laptop
Hey you try this.
Enter into BIOS, Disable SATA Support, if problem persists, change your Hard Disk, that is crashed. I had the same problem last month.
SOURCE: operating system not found
the laptop is unable to read operating sistem from disk - you have to try to insert recovery disk after changing in the bios (you can read on laptop manual how come in bios for changing to first boot is hard disk to first boot is cdrom or dvd or cd ) after that you can try to recovery the operating sistem - it may be not so easy delfo
SOURCE: operating system not found on my laptop
Unfortunately the OS got corrupted and you need to re install the Operating system.
There is no other way to fix the problem but use the recovery disc.
If you dont have a recovery disc you may want to contact the manufacturer of your laptop and order one.
Or if you can use a retail version of Operating system and once finished installing you may need to download the drivers of your laptop on the support site.
Hope this helps.
Hi there.
Hard drives don't come with operating systems on them, you have to reinstall the OS yourself either with your recovery CD or an install disk.
Post back if you need anymore advice.
Good luck and thanks for using FixYa!!
SOURCE: tryed to turn laptop on and now it is saying
Please check your Hard Disk Drive in the BIOS is still functioning. At the BIOS Booting Setup the should be ON to boot your Operating System.
Try and try again.
