I need to scan my documents as a pdf in order for the receipients to be able to open. This scanner is only giving me two choices...tif and mdi. Is there any way to scan items as a pdf?
    Scholar:
  • 154 Answers
No. You need to scan then convert the .tif into a .pdf. There are many good converters around, some of them freeware or costing around $30 or as shareware. You could do worse than starting your search at the url below.
Good Luck.
http://www.download.com/1770-20_4-0.html?query=convert+to+pdf&tag=srch&searchtype=downloads&filterName=platform%3DWindows&filter=platform%3DWindows
Posted on Dec 02, 2008
How do I scan more than one page at a time so I have a complete document of 6 pages instead of having 6 different document
you either select add a page, or use the document feeder. The document feeder will try to scan all pages into one file.
Mar 02, 2011 | Brother MFC 420CN All-In-One InkJet...
My hp laser jet 3052 cannot scan documents in pdf.It is only giving options to save either in jpeg, tif, bmg format. There is no pdf format.
You may need to purchase a scanner to get a PDF like Acrobat Reader. But if you managed to save to PDF before, try to reinstall the software and add software and choose OCR. Most of the HP PDF capablility is together with its OCR software.
Aug 22, 2010 | LaserJet 3052 All-In-One Printer
Why does my HP 3015 only scan into TIF files and not PDF?
You need to change the scanner program settings on the computer to save the document as a PDF instead of a TIF.
Dec 07, 2009 | HP LaserJet 3015 All-In-One Printer
Why doesn't the HP Deskjet F4280 scan documents to PDF
to get pdf files you have to have adobe installed in the computer
Jul 01, 2017 | HP DeskJet F4280 All In One Printer InkJet
New Laptop with Vista Scans Documents as .tif instead of .pdf Why
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.hp.com/printer/prob676ijt65/solution
abdsf268
Aug 01, 2009 | HP Officejet 5610 All-In-One InkJet...
MCF 6490CW SCAN AS A PDF
I was trying to figure out how to scan multi-page documents to a single file and found this on the Brother website:
Double-click on the ControlCenter3 icon located in the Task Tray to launch the program window.
Click on CONFIGURATION -> SCAN.
Choose the type of scan you require. The choices are: IMAGE,
E-MAIL, and FILE.
The Scan to configuration window will appear.
The SOFTWARE BUTTON tab configures the Scan to button within theControlCenter3 software interface. The DEVICE BUTTON tab configures the Scan to key on the Brother machine. Choose the tab you want to configure.
Under FILE TYPE select an option that allows multi-page documents:
a) PDF (*.PDF)
b) Tiff Multi-Page # Uncompressed (*.tif)
c) Tiff Multi-Page # Compressed (*.tif)
Click OK.
Apr 28, 2009 | Brother MFC 6490CW InkJet Printer
Hi,I have got a Canon,smartbase MPC 400 printer/scanner. My question is: How can I scan a document straight to a PDF file,because it only gives me options for TIF,BMP and JPEG. I have downloaded a TIF to...
I'm using an MP780. Usually when I scan an image to jpeg I press START, CANON, SCANGEAR STARTER. This open a window to ScanGear MP. Since I use the Advance Tab I can set the DPI and whatever outputs. The DPI rsolution will determine the size of the file also. When it is finished scanning it goes to the next window which has Save As Type and Save Scanned Image to. Save As Type is where you can choose JPG or TIFF or BMP. Hope this helps.
Nov 13, 2008 | Canon Office Equipment & Supplies
Problem with MSPVIEW
when the file has been saved on tiff format the wrong compression and set byte order ibm pc
Sep 23, 2008 | Computers & Internet
Scanned copy cannot be saved
Try to downlaod the software from HP.com
May 02, 2008 | HP PSC 1410 All-In-One InkJet Printer
Scanner problem
Hi BethKay,
What it's telling you is that the "filename" that the scanner/software package is trying to use to save the document being scanned to your hard drive has reached it's limit in the amount of times that it can be incremented by "1". In other words every time you scan a document it is saved to a directory or folder on your PC under a filename which is probably assigned by default. This filename has a "suffix" which is also assigned by the scanner/software eg. filename01.tif (or jpg, etc) filename02.tif filename03.tif and so on. Either I'm way off base or you must have scanned a whole bunch of documents using this naming convention because the scanner/software has run out of numbers that it can affix to each individual file. What you need to do is either 1. Change the folder that you are saving the documents to or 2. Change the pre-suffix filename in order to retain individuality.
Make sense?
Let me know if this helps and good luck.
J
Feb 22, 2008 | Microtek ScanMaker 3800 Flatbed Scanner
Computers & Internet Logo
David Payne
David Payne
