Question about FrancisFrancis! X5 Espresso Machine
X5 espresso machine help
I just got my espresso machine and i can't get any water throught the system. the water-intake tube dosen't seem to stay in very well and when it is in, it dosen't take any water up into the machine.... is there some hole i should be trying to get the tube in inside the machine.?
When the machine is cool, make sure the intake tube is submerged in the water, open the steam valve and then activate the pump. If the pump does not siphon water after 20-30 seconds then try to force air into to intake tube (compressed air, no more than 10 psi)
Posted on Feb 22, 2007
Hello, My x5 keeps popping my kitchen GFI plug in the kitchen, i plug it into a non GFI and the top light (heating element) flickers when turned off. When turned on it appears to be working ok?
Stop! Do Not use this machine until it can be serviced by your vendor or the MFR!
** There is probably an open or ruptured heating element in your brewer. The heating wire is embedded in a sand filled copper tube which is immersed in water. Sometimes when the copper tube cracks or leaks allowing water to seep into the heated wire. This will steam the water and rupture the tube thus exposing the element directly to the water in the tank. Most units will short out and trip out any breakers by overloading the line. Some will still heat the water but this is a dangerous situation as the 'short' in the water will still heat up the water to a high boil and may rupture to whole brewer. If your power cord does not have a good 'ground' wire then there is a strong chance your operators will get a shock while touching the machine and another 'grounded' machine (like the grinder)
** Be safe and get it properly serviced.
Aloha, ukeboy57
Dec 05, 2017 | FrancisFrancis! X5 Espresso Machine
The plastic water line intake part cracked an is leaking, the parts book says it is part of the generator. The generator is 180.00 dollars. I just need the plastic part. Can anyone help?
I've gotten parts from and had good luck with ereplacementparts.com. Their diagram for the 3300 indicates that this is the water tube going from the pump to the generator:
http://www.ereplacementparts.com/tube-23cm-long-p-695107.html
It is less than $8.
In my 4500 unit, all of the water tubes have similar connections though in different lengths. At 23cm, this one seems pretty long.
Tube 23Cm Long
Jun 09, 2015 | DeLonghi Magnifica 3300 Espresso Machine
Just got a Jura x5 from a friend who has not used it in 3 years. Plugged in, set up, and display reads "system fills" but no water is released from the water reservoir. Machine makes a sound, like the...
Message :Fill System
Causes/Troubleshooting:
Leaks in the fluid system-localize the leaks and seal them.
Blockage in the fluid system, no water can be fed - Localize blockage and replace blocked components (valves, heater, tubes) if necessary.
Flow meter-count error - Open the floow meter by a quarter turn and clean it, replace if necessary.
Oct 01, 2013 | Jura Capresso Impressa Z5 Espresso/Coffee...
This morning I tried making a few shots of espresso and ran out of water. I filled the tank again and when I tried brewing the machine started making a harsh noise and no water came through. I checked the...
Hi
Any time you run out of water when the machine is operating, you will need to prime the machine again through the wand not the brew head. Turn the knob on the left and then turn the machine on. The pump should get quite after a few seconds and water should come through the wand. If it doesn't you need to turn the machine off. Get a asperator bulb or you can use a turkey baster. Fill with water and stick on the end of the tube going to the pump . Turn the machine back on ( the knob should still be open), and squeeze the bulb to force water into the line. If the pump changes tone, turn the machine off. Remove the bulb and put the tube back into the tank . Try the machine again.
May 09, 2011 | Saeco VIA Venezia
The water hose got cut in half.
I had the same issue when a friend tried to use mine - if you remove the top plate, you can then lengthen the hose as there is an extra bit of tubing. It should be enough to reach the bottom of the water container again. You can then attach the filter from the severed half.
Dec 29, 2010 | FrancisFrancis! X5 Espresso Machine
Toastmaster 583P leaks after cleaning - water seems to come from pump area around bottom
There are two soft plastic tube from the heating elements, one is intake tube which must fit the water reservor intake plastic well. another one is send the hot water to the top of the coffee maker to shower the hot water to coffee. Anyway is take it apart to find out which is the possible spot cause leaking. Not too easy.
Apr 27, 2010 | Toastmaster 583P
Gaggia Coffee Deluxe: After I run decalcifying solution throught the machine and replace with fresh water, the pump stops working. I can hear it running, but it will not **** and push water throught he...
The desolve scale have blocked the vibrating pump. You are write sometimes it can be unstuck by itself hoever this time is seems that more scale blocked inside the pump. If you know how you can open the pump directly and clean it with a wire brush. If you find it dificult you can try decalcifying solution once more and leave it for more time inside the machine so that more calcium will be desolve and probably you will have the pump unstuck. When you try to test the machine dont leave it work continuasly for more than 2 min cause this will burn the coil of the pump.
Please remember to vote for this answer
Feb 14, 2010 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
FrancisFrancis! X5 Espresso Machine Logo
188 people viewed this question
Top FrancisFrancis! Coffee Makers & Espresso Machines Experts
dharmanos
Level 1 Expert
Jim Goldsmith
Jim Goldsmith
Are you a FrancisFrancis! Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
