Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
Frigidaire Gas Range with Convection--fan does not turn on
Hi there! I have a Fridaire gas range with a convection fan. It was working just fine this morning, and then when I went to use the oven this afternoon, the fan will not start up. The "Speed Bake" light comes on, but the fan does not blow. I'd be very grateful for any advice, and thanks in advance for your help!
Best, Heather
  • 61 Answers
The convection fan is wired through the door switch make sure your door switch is o.k. before replacing the board or the fan. Please have a local service tech check unit if you have to get into any electical checks. good luck
Posted on Dec 26, 2008
How to repair the control panel when the convection oven does not work but other things work
Good Morning Friend,
I understand you want to know how to repair the control panel on your Frigidaire range. I see that the convection oven is not working, however other functions are working. Typically, this is not a do it yourself job, as there are no step by step instruction manuals. I suggest contacting your local authorized technician for further assistance. They have been trained on your appliance and should be able to diagnose your appliance and determine why the convection oven is not working. Hope this is helpful.
-Best Regards-
WP
Jul 08, 2014 | Frigidaire Ovens
Door won't. open on frigidare convection oven #240462603 can you help?
Good Afternoon Karen, this you for your question!
I understand your Frigidaire oven (240462603) will not unlock. However, it appears above-listed model number is invalid. The serial tag, which lists your model number, is typically located in the storage drawer, on the right side.
In the meantime, I suggest pressing the CLEAR/OFF or CANCEL button in for approximately three seconds if your range is a touchpad model.
If you have a knob type range control, I suggest starting a self-clean cycle. Then turn the stop time knob to the off position. If that does not work, then disconnect power to your range and reset it by either unplugging it or flipping the breaker off. It is necessary to wait roughly ten minutes and then turn your range on.
I ask that you please follow up with a response on the post, at your convenience, to advise if further troubleshooting is needed or if your range status has changed successfully.
Best of luck - Z
Mar 30, 2014 | Frigidaire Ovens
Frigidaire professional range boil convection and reheat doesnt work
Hello D Scott - Sounds like the range is either experiencing a wiring/communication error or a faulty EOC. Try resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes. If it proves to be ineffective, contact a professional to move forward accurately.
Jan 10, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
I have an american range gas convection oven i think lightning may have struck them but they still run but the gas will not come on the igniter just keeps ticking and no gas
there posible pilot burner is clogged, you may want take off the gas pilot tube and make a quick turn on to see gas is come out from pilot tube or disconnect from gas valve pilot connector...have fun....
Sep 23, 2011 | American Range Ovens
Oven temp will not change
Most ovens have BAKE, BROIL and yours might have CONVECTION. Turn each on independently. If all don't work its one problem if only one doesn't its another
Also is it the gas doesn't ignite or it ignites then no temp change (or electric gets to xx degrees but doesn't get hotter?
Sep 04, 2011 | Wolf Range WKGD-2 Gas Double Oven
The control panel lights do not work nor does the oven. all the burners work fine this is a convection oven with a smooth top Gallery series
Check your main breaker in the fuse panel, it may be partially tripped. Turn the 40 amp breaker off and back on. if the display does not return to the stove, the I would suggest you contact a local servicer.
Aug 29, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Oven not working
It sounds like the element/s have blown, especially if the fan is still working o/k.
You cannot always tell by looking at them if they are faulty or not.
Only way to be sure is to test them with a meter.
Hope this helps.
Please rate my solution.
Thankyou.
Jan 18, 2010 | Frigidaire Ovens
Convection oven no longer works
Could be the fan trying to start, ,if there is a removable cover in the back of the oven, remove it and see if the fan is free to spin, could be a tight bearing , or it could be stuck with a build up of grease.
Jan 02, 2009 | Viking 30" Professional Select Built-in...
Oven/Broiler Igniters for KitchenAid range KGST307
Oven bake ignites usually have lifetime 5-7 years. If igniter glows but gas not came in - replace igniter. Same with broil igniter.
Dec 09, 2008 | Ovens
Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
1,563 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
