Question about Dryers
Drum doesn't turn, start switch turns dryer on when held on but dryer shuts off as soon as start switch is released.
  • 734 Answers
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in.
2. Door switch / Door switch actuator lever
The dryer would not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
4. Timer
Replace if defective (note: uncommon problem).
Posted on Dec 02, 2008
Dryer makes a buzzing noise when I turn it on but it doesn't come on, just buzzes.
Open the dryer door and slowly rotate the dryer drum in a counterclockwise (CCW) direction. Rotate the drum 2-3 revolutions and then shut the door and see if it will start. If it continues to just hum and not start could indicate a voltage issue, motor issue or a friction issue. Open the door again and locate the door switch plunger in the upper or lower corner on the hinge side of the drum opening. Hold the plunger in while someone begins rotating the drum counterclockwise. While turning the drum counter clockwise and holding the door switch plunger inwards press the start button. If it starts, there is likely a friction problem or motor problem.
What is the model number?
Nov 06, 2012 | Dryers
GE dryer starts but..... stops
What you describe is either a failed evenheat board or a failed motor relay.
Please post the complete model number from the machine and I can help you narrow it down. There should be a wiring diagram inside the console with voltage checks also.
Thanks/Mike
Nov 25, 2007 | Kenmore 63932 Electric Dryer
I HAVE A GE DRYER THE MOTOR SHUTS OFF WHEN YOU RELEASE THE START BUTTON AND THE DRUNM WONT ROTATE
there's a broken belt switch connected to the belt idler pulley,(when this belt breaks the switch opens) located down by the motor and it kills the power to the dryer when the belt breaks so the heating element cant get the clothes too hot to burn the clothes when the drum cannot rotate properly
Feb 25, 2012 | General Electric Dryers
Runs when PTS held but shuts off when released/no heat
No problem at all.The motor has a start and run winding.Your run winding is bad.The reason you have no heat is the run winding has to run to close the contacts on the motor switch.Replace the motor ,both problems solved. Hope this helps Please rate my response :)
Dec 13, 2009 | Kenmore Washing Machines
GE electric dryer (model #DDE5300BBLAD) won't start when I hit the start switch. I do hear a noise when I hit the start switch...stops when I release the switch.
the sound you hear is the motor trying to start.reach in drum and turn clockwise 1 revolution.try to start it again,if it starts your motor is starting to go bad and will have to b e replaced soon.if you canrt turn thje drum you probably have something stuck in blower below lint filter .hope this helps .please rate my response:)
Dec 09, 2009 | GE Dryers
Model 63942101 Dryer Starts\Stops after Start buttton released.
Sounds like a bad door switch. Thats about all it can be. I see this from time to time but not often.
Please rate solution.
Aug 26, 2009 | Kenmore 63942 Dryer
Start switch starts dryer but as soon as release d the dryer stops. Ifstart switch held in start position it turns and heats.
one of 2 things, your door switch is not working or the wires are shorted causing it not to work
Mar 26, 2009 | Dryers
Ge Cloths dryer will not stay running or turn drum
probably broken belt some dryers have broken belt switch that shut dryer off if belt broke
Nov 25, 2008 | GE Dryers
Dryer will not start
I had the same problem and this is how I fixed it ,,, i did a comfortor ,very heavy when wet .....next day i tried to do a new load ...when I turned start button all i got was a hum... I removed screws just inside door at top of lip this releases top of dryer,,,, exposing drum i rotated drum clockwise to check condition of belt ....looked good ....mine is 7 yrs old ...to soon to be motor problem ....so while turning drum i held start button on and finally motor kicked in and this solved my problem...you might be able to accomplish this without taking of panel ..though you wont be able to see belt ....by turning the drum from inside dryer while someone else turns on start button
Oct 25, 2008 | GE Profile Prodigy DPSR513GA Dryer
Dryers Logo
131 people viewed this question
Top Dryers Experts
