In this case please first uninstall the printer and the reinstall again.After that get a test print.If do the same then change the colour settings as default.
Thanks for using fixya.
Try first to remove the cartridges and for about 2 minutes an dput it back in then try again to print, if still have the same problem uninstallation and reinstallation of printer software will also help...
Using the printer utility, try to use the color adjustment option. You need to calibrate the color printing using the printer utility. If it doesn't work, try to update the driver. You must uninstall then reinstall the driver using updated one.
How to reset Canon MX310
printer low ink signal
1. Power off the printer.
2. Holding the stop/reset button, press and hold
power button also. Hold both buttons
together for 5 secs.
3. Still holding the power button, release the
stop/reset buton, then press the stop/reset button twice.
4. Release power button (the screen should now
say 'Service Mode').
5. Wait until the power button lights steady
green, then press the stop/reset button three times with a 3 sec space between
each press. On the 3rd press the
indicator should turn steady orange.
6. Press the power button once, (the orange
light should go off).
7. Open the printer and remove both
cartridges. Wait for 10 seconds. Replace the cartridges and close
printer. Wait for 30 seconds.
8. Press the power button, and wait until
printer has shut down.
9. Press power button to power up. The printer will feed one piece of paper,
then ask you to set the language.
10. The page counter is now reset! Enjoy.
