Question about Zanussi Dishwashers
Zanussi dishwasher DA6142s discharge hose
The discharge hose has split very close to the dishwasher, how can this be removed to be replaced
  • 76 Answers
With most dishwashers that i have pulled apart it is at the bottom of the dishwaher. You should be able to remove the bottom plate (under dishwasher) and take the clap of and put a new one on.
If you have any questions plese dont hesitate to ask
Posted on Dec 03, 2008
Error 20 in dishwasher AEG 77012 wop
i20 error code means:
Water is not pumped off and could be:
  • Fault with discharge pump
  • Discharge pump deenergized (faulty wiring or no activation by electronics)
  • Obstruction/blocking (filters in the appliance, discharge opening in discharge trough, discharge pump, discharge hose, siphon, cover plug at siphon connection not removed during first commissioning)
  • Discharge hose bent or connection height above 100cm
  • Ball valve in discharge trough glued / blocked (discharge pump does not aerate)
or water level inside appliance is not detected and than
could be:
  • Pressure controller faulty
  • Pressure controller hose obstructed or bent
  • Insulation fault with heating element
Dado
Feb 19, 2016 | AEG Dishwashers
I need to replace the drain hose on my Samsung dishwasher as old one split but cant work out how to do it.
It's a big job. You have to pull the dishwasher all the way out. On most Samsung DW's, you then need to remove the metal panel on the left side of the DW to be able to get to the case-brake assembly. Remove the water inlet port on the inside of the dishwahser by turning it counter-clockwise ( a tool will be required). Pull the case-break assembly out so you can get to the clamp that holds the drain hose in place. Pull the clamp down and remove the hose. Have a towel or Sham-Wow ready to catch all the water. You will have to disengage the hose clamp at the back of the dishwasher, then you can pull the hose out. Reverse the process to install the new hose. As I said, it's a big job; if it sounds like more than you want to do, I recommend calling a professional repairman. Sears has technicians who are experienced with Samsung dishwashers.
Aug 12, 2014 | Samsung Dishwashers
I WANT TO REPLACE DRAIN HOSE WITH NEW ONE AS OLD ONE SPLIT
It's a fairly big job. You have to pull the dishwasher out from under the cabinet. Then remove the left-hand metal panel. You should now be looking at the case-brake assembly. Reach inside the dishwahsher and turn the water-inlet bezel counter-clockwise to remove it. Now you can tilt out the case-brake assembly and loosen the clamp that holds the drain hose in place. Pull the hose off (have a towel or Sham-Wow ready to catch the water). Then you have to remove the clamp or hose-restraint at the back of the dishwasher. Thaen you can pull the drain hose out and replace it.
Replace dishwasher drain hose F&P DW60
The attached assembly document might be helpful. To access the drain hose at the dishwasher end your best bet is to pull the dishwasher out from under kitchen cabinet and lay it on the floor on its side. Make sure you disconnect the mains power and the hose connections first. The hose should be accessible from the bottom of dishwasher.
http://www.jordansmanuals.com/ServiceManuals/FP/Dishwasher/DW60CDW2/DW60CDW2.pdf
Mar 25, 2014 | Fisher and Paykel Dishwashers
My dishwasher hose has 2 splits in it so I need to know how to replace the hose
remove the rear cover and loosen the hose clamp. Pull off the old hose. Put the hose clamp on the new hose, fit the hose to the machine and do up the clamp. Put the rear cover back on,
Dec 20, 2013 | Zanussi 24 in. ZDT6041 Built-in Dishwasher
Drain not draining
Elimination Of Problems From Most To Least Likely:
1. Connection from discharge hose to drain pipe is blocked/corroded.
a) Loosen the gear clamp (5/16" Nut Driver/Phillips/Standard) holding the discharge hose to the barbed drain fitting.
b) Check that the barbed fitting is not blocked by poking at the opening wth a screwdriver.
c) If the barbed connection is Galvanzied and it has gotten heavily corroded, replacement of that fitting is recommended.
2. Discharge hose is blocked/kinked from dishwasher to drain connection.
a) After 1b), place discharge end of hose into a bucket and run the dishwasher through a cycle.
b) If flow is poor, examine hose for kinking or parts (such as couplings) that may have corroded shut. Removing front panel and using a flashlight will be required for this (1/4" nut driver/phillips) If such corrosion found, 1c).
c) If hose and fittings are ok, there may be an inline filter whose screen is clogged or a filter screen where the dishwasher ties into it's discharge line.
3. Pump has failed internally . Usually held in place by large squeeze clamps, screws, gear clamps. Will most likely require removal of dishwasher from alcove to repair. Any reputable dealer should stock parts. i.e. Kenmore => Sears
N.B. May be under warranty - check. May be cheaper just to get another dishwasher at this point, especially if the dishwasher is more than 10 years old.
Sep 08, 2009 | Miele 24 in. G892SCU Plus Built-in...
Will not drain.
I know you said the drain's not blocked, but i feel obligated to mention it anyways ;)
3. Pump has failed internally . Usually held in place by large squeeze clamps, screws, gear clamps. Will most likely removal of dishwasher from alcove to repair. Any reputable dealer should stock parts. i.e. Kenmore => Sears
Sep 07, 2009 | GE 24 in. GSD6660GSS Built-in Dishwasher
Mdb7100aww maytag, just not draining now. never problems before. water standing in tub and shuts down????? Float appears to be functioning just does not seem to drain, possibly drain motor?
3. Pump has failedinternally . Usually held in place by large squeeze clamps, screws, gear clamps. Will most likely removal of dishwasher from alcove to repair. Any reputable dealer should stock parts. i.e. Kenmore => Sears
Aug 08, 2009 | Maytag Dishwashers
The Dishwasher won't drain
Aug 08, 2009 | Kenmore Dishwashers
Dishwasher keeps running and will not turn off, standing water in bottom
Aug 05, 2009 | Asko D3251HDSS Stainless Steel Built-in...
Dishwashers Logo
88 people viewed this question
Top Zanussi Dishwashers Experts
Paul Carew
Charles T Nevin
Charles T Nevin
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
