Question about Toshiba CX36H60 TV
Toshiba tv 32ax60 3 thin wires disconnected
Hi, I mistakenly pulled out my tv while the cable were still connected.. the result is a small silver box, almost like a cable splitter, around 3 inches by 2 inches by 1/2 half.. with 3 connection cable connections has been pulled right out the back of the TV... the part number is WSA2170-0007R 811YA RSU 133X5...
The problem is there are 3 very thin wires, blue, yellow and redi...these wires were soldered onto the back of the small silver box.. i can see where they became disconnected but i am not sure where each wire should be connected... can you help..? thanks.
  • 3 more comments
  • mortgagewhiz Dec 03, 2008
    Hi tvjoseph, yes, i think it is the RF converter assembly.. there are 3 threaded connections on the outside, not damaged, but it was pulled right out through the tv, broke the plastic tv case.. and on the inside were 3 very thin wires, blue, yellow, red... tv has never been worked on.. was never moved since original purchase 7 yrs ago.. i'm confident i could solder those 3 wires back but just don't know where they go...
    i can attach a small video clip and post on youtube if that would help you identify the problem better? thanks
  • mortgagewhiz Dec 04, 2008
    Hi, i've put a short video clip so that you can view the problem... any advice is welcome.. thanks
  • mortgagewhiz Dec 05, 2008
    This was helpful.. thank you.. now if you can only tell me where the hot wires are supposed to be connected...
    ps. did my video help?
    Hi again, thank you.. sorry, i don't understand 'insulated fee thru ceramic bubble.' i don't see any ceramic or any bubble... excuse my ignorance.. my electronics knowledge is limited..it's been a long time since i worked on these things...
  • dagordon Dec 18, 2008
    exact same problem here.
    I have a volt meter at hand but I don't know where the power and ground need to be connected.
    Thanks!
  • 121 Answers
Belive your referring to rf converter assembly. entire unit can be replaced  or if threaded end pulled out can be repaired. dont understand 3 wires unless worked on previously. avg shop prob min bench to repair. .
Posted on Dec 03, 2008
  • 1 more comment
  • joe wertenberg Dec 04, 2008
    wires are for switching voltage to converter.  wont work with out same. back of converter may be marked b+ next to posts. you will need volt meter to idenify hot wires. if you have any repair shops near they may have your tv look at same. the 2 connedtions with insulated feed thrus are for b+ metal case is for wire with no b+ idenify wires with b+ hook to feed thrus if dozent work reverse wires.
  • joe wertenberg Dec 05, 2008
    yes vidio great! hot wires go to insulated feed  thrus ceramic bubble  on connecter
    another way the 2 connections with high reistence to ground are for b+ need ohm meter.
NES controller input
Installation Steps:
Locate the TV's VHF IN [ANT, CATV, or 75(ohm)] or Cable Connector.
Disconnect the existing cable wire from the TV's VHF IN.
Connect the short, thick wire from the RF Switch (labeled ANT) to your TV's VHF IN.
Reconnect the existing cable wire (disconnected in step 2) to the silver post labeled ANT on the RF switch.
Connect the thin wire of the RF Switch (labeled Control Deck) to the back of the NES (labled RF Out).
On the back of the NES, set the 3/4 switch so that it matches the channel of the TV.
Note: The RF Switch does not produce stereo sound. To get stereo sound, connect your Control Deck to your TV or VCR using the Stereo Audio/Video Cable.
After the system is connected to the TV:
Insert the Game Pak firmly into the Control Deck.
Plug the controller(s) into the front of the Control Deck. Use the far left port for a one player game.
Plug the AC Adapter into the back of the Control Deck. Plug the other end of the cord into a wall outlet.
Press the Power button on the front of the Control Deck.
Turn on the TV and set it to the appropriate channel (3 or 4.)
The game image should now be displayed on the TV screen.
If after following these directions you are not able to view the game (for instance, if the red power light flashes off and on), try our Troubleshooting Tips.
Mar 02, 2012 | Nintendo NES Console
How do you hook up the super nintindo console to the tv?
Original-Style Super NES RF to TV Hookup
hook_sns_rftotv.gif Installation Steps:
  1. Locate the TV's VHF IN [ANT, CATV, or 75(ohm)] or Cable Connector.
  2. Disconnect the existing cable wire from the TV's VHF IN.
  3. Connect the short, thick wire from the RF Switch (labeled ANT) to your TV's VHF IN.
  4. Reconnect the existing cable wire (disconnected in step 2) to the silver post labeled ANT on the RF switch.
  5. Connect the thin wire of the RF Switch (labeled Control Deck) to the back of the Super NES (labled RF Out).
  6. On the back of the Super NES, set the 3/4 switch so that it matches the channel of the TV.
  1. Insert the Game Pak firmly into the Control Deck.
  2. Plug the controller(s) into the front of the Control Deck. Use the far left port for a one player game.
  3. Plug the AC Adapter into the back of the Control Deck. Plug the other end of the cord into a wall outlet.
  4. Slide the Power Switch to the On position.
  5. Turn on the TV and set it to the appropriate channel (3 or 4.)
  6. The game image should now be displayed on the TV screen. You are ready to play!
If after following these directions you are not able to view the game, try our Troubleshooting Tips.
Jan 13, 2012 | Nintendo Super NES Console
Toshiba cf32h40 started last week the pic would go down to one thin line i would hit it on the side and it would come back ,but now thin line comes back when i hit and then goes away so i took off the back...
that silver box is called TV tuner (see picture ) ............ but in your case that is not the problem ......... after 4 or 5 yrs (depending on usuage ) in some TVs on mainboard & CRT tube's circuit board at some soldering joints cracks develops ... then due to loose contact TV behaves as you have described ........ when you are hitting that lightly on its side then these cracks at soldering joints are getting connected temporarly & for few seconds or minutes you are getting normal picture ....... so solution is most of the soldering joints on mainboard & on CRT circuit board has to be resoldered ....... only good tv service engineer can do this without shorting joints or damaging components..... so that silver box ( TV tuner ) is not the problem because when it gets deffective then you will get picture that comes when tv is switched on ---- usually it will be blue screen ......& also if you connect dvd you will get picture normally ...only thing is that you won't get picture from cable or antenna .............. vishnuswamy_25.jpg
Sep 01, 2011 | Toshiba CF32H40 32" TV
Eu tava com o super nintendo ligado e ele espludiu a fonte
Aug 21, 2011 | Nintendo Super NES Console
I believe I need to replace the bulb on my Toshiba 44NHM84 but I dont know where the bulb is. I've watched some videos and I cant find anythng that looks like what i'm seeing in the video. What I see is a...
This is lamp of your tv (lamp with housing) that you will see inside tv.
Click Toshiba Support to download user manual copy and check page-50 to 52 for lamp replacement instructions.
Thanks.
Jul 31, 2010 | Toshiba 44NHM84 44" TV
No tv picture - only audio - after pc to tv box hook-up
Hi I am a silver surfer but this is how I got it working
First off get the program tou want to watch up on PC Moniter(screen) Then connect 3 cables
Yellow cables / One end to tv other end to yellow hole rear of PC/TV Box
Grey cable small end goes in PC/TV Box just behind the wirds "kworld" other end goes into back of your Computer ,you need to check your Computer manual to see the which one is the connection to your Computer screen(moniter),mine was blue with 2 screws , disconnect this and screw in Grey cable
Black cable narrow flat end into front bottom of Computer ,other end intoPC/TV Box end hole next to yellow cable
Switch on TV and change AV until you see your program, sound will be thu your Computer Speakers NOT your TV
THIS IS FOR A DESKTOP COMPUTER
Jun 15, 2009 | KWorld PC to TV (0872880887527) Video...
Tv fell and coax antenna cable got yanked out of back of tv.
Repair can be made if you use the utmost care. Do not remove tuner (steel case). Open side closest to screw jack and remove other side,may be soldered. Observe the the center lead and how damaged the pc board is. Use solder and thin wire, strip a twisted wire till you have one strand and repair board and solder the outer metal to the tuner can. Then presto TV again! Good Luck be safe..
Mar 30, 2009 | Emerson EWC20D4 Combo
Broke the piece where the cable wire goes in...what's it called?
Unfortunately, that coax connector  is almost certainly crimped onto a cable inside.  You might want to pull off the back panel to see if that internal cable is screwed onto another jack on the chassis. If so, you can disconnect that end and substitute another cable, they come in several different lengths and are not critical. Any electronics store will have them.
If it isn't equipped with a connector inside, you will need to have someone unsolder the defective cable and install a new one.
Dec 21, 2008 | Philips Magnavox 51MP392H Rear Projection...
Toshiba Satellite m55-s139
sure..use a toothpick, to open the small thin lever, that is on top of that connector(like opening a trap door in the floor) then gently insert the ribbon cable, then push the small lever back down. make sure that the cable is centered, and fully inserted..
Oct 19, 2008 | Computers & Internet
Toshiba 30HF84 and progressive scan
check your connections properly there could be some thing that you are not connecting .or your cable are not compatible.good luck
Jan 23, 2007 | Toshiba 30HF84 30" TV
Televison & Video Logo
64 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
