Question about Dishwashers
Have a Hotpoint dishwasher, mod HDA2100N10WW, that is not cleaning top rack. Any suggestions?
    President:
  • 1,462 Answers
Open door when in operation and check the top spray arms are rotating. if not they are clogged with food debris so take them out and clean
Posted on Dec 03, 2008
-+the top arm is not turning in my washer Model #GU1200XTLB2. I have removed it and cleaned it and it is still not turning. Can you offer any suggestions? Thank you,
Dishwasher Spray Arm Not Turning ' Home Guides ' SF Gate
homeguides.sfgate.com > Foreclosures > Other Foreclosures
Remove the lower tray of the dishwasher to freely access the spray arm. ... Although spray arms are directly powered by the water pump for the dishwasher, not all of ...For best use, clean the filter and pump at least a couple of times per year. .... MyRidevisit'Cars-My Ride'navigation-www'4 · Sell Your Carvisit'Cars-Sell Your ...
Dishwasher Cleaning - Top Rack Doesn't Clean - YouTube
? 12:57
https://www.youtube.com/watch?v=75DB9cyPYO0
Feb 7, 2013 - Uploaded by Dogwood Tales
With that said, I'm working on more such videos for household maintenance and repairs and ... In my case the bottom rack of thedishwasher was cleaning well, but the top rack of thedishwasher was not coming out clean at all. In fact ..... How to clean and replace Dishwasher Spray Arms - Duration: 2:07.
How To Fix A Dishwasher Not Cleaning Bottom Or Top Rack ...
Jan 12, 2016 | Dishwashers
Top sprinkler not spinning and there is a rattle in it
When my wife started complaining about her dishwasher not getting the top rack clean this is what I found and I wrote a tip about it...
Dishwasher Spray Arms not Spinning
heatman101
Sep 02, 2010 | Hotpoint 24 in. FDW60 Free-standing...
There has been a trail of dry soap on inside of door after wash is complete, also dried soap on some dishes in bottom rack as well as not being clean and on top rack spots on glasses and sometimes some...
Check your heating element..
A bad heating element causes many problems in dishwashers…
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " expanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Aug 28, 2010 | Hotpoint 24 in. HDA900X Built-in...
Top rack whisperquiet dishwasher no water
http://www.kitchenaid.com/assets/pdfs/product/ZUSECARE/8573754.pdf
I know this isnt the same model, they dont carry your manual as of yet. But it does have some suggestions to look at on page 17. I had the same problem and I looked really carefully and found my sprayer arm was blocked. I cleaned it out and havent had a problem with it again. I do check it regular now.
Sep 27, 2009 | KitchenAid 24 in. KUDP02CR Built-in...
I Bought a hotpoint hda3540 it looks cheap will it work good?
You purchased an economy model dishwasher. Sure it will work. Would a slightly more expensive model work better? Yes. You are almost always getting the best value (performance for the dollar) when you buy a middle of the line product. In the case of the dishwasher, a bit more money would have resulted in a "tall tub" model, which would have had three wash arms, without the extending tower sprayer in the middle of the bottom rack. Once you go beyond that, you start paying for more cycles, more delux racks, and additional sound insulation, which is nice, but not essential to getting the dishes any cleaner.
Jun 07, 2009 | GE Profile PDW9880NSS Stainless Steel...
Top rack not getting clean
you may have a bad chopper. put a couple of coffee mugs upright on the top rack turn the dishwasher on and see if the mugs are filling with water give it about 1 minute. if they are mot filling up you have a problem with either the recurculation pump or the chopper. it's usually the chopper
Mar 24, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwaher does not clean, upper rack
The top rack is not cleaning because of low water pressure from the wash motor to the upper spray arm.
Assuming the top spray arms are clear of debris, remove the lower spray arm to access the wash motor. Remove the 4 torx screws and the filter (accumulator assembly). Remove the torx screw and the inlet protector that covers the chopper assembly. Make sure the chopper is not broken (broken chopper will fill with debris and block water flow). While holding the chopper blade, reach inside the "D" shaped opening on top of the motor and spin the wheel/motor by hand in each direction to make sure either the chopper gear or the motor gear that drives the chopper is not broken. Replace the chopper if necessary (part # 8268383). If the motor gear is broken, replace the sump and motor assembly (part # 8535150). Remove any debris from the sump area in the process.
You don't have to shut the power off to the dishwasher because the door will be open, but if you feel more comfortable, do so.
Mar 13, 2009 | Whirlpool 24 in. DU1100XTP Built-in...
Top shelf items dirtier after cleaning
After some experience with our own fdw60 with the same problem, we now put all pots and pans on the top rack. Putting them on the bottm appears to stop the clean water rinse reaching the top rack. All washes since have been ok.
Sep 23, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Dishwashers Logo
299 people viewed this question
Top Dishwashers Experts
