Question about Canon imageRUNNER 400S Copier
Can't figure out how to reload stapler
Don't know how to reload staple cartridge into the unit
I called a repairman to come and fix it. I am not a stupid person and can generally follow instruction and figure something out, but this is the second time this has happened with this machine & this staple cartridge, and why this is so difficult is beyond me. We have a mainternance agreement so I just called to have him come and fix it....again.
Posted on Dec 03, 2008
How do I reload staples into my Xerox WorkCentre 7530?
You did not indicate finisher? Xerox MFPs' come with the most finishing options of any manufacturer.... I included instructions for all of them below. Enjoy!
Solution : Load Staples in the Professional Finisher With Booklet Maker The stapler in the booklet maker uses two Staple Cartridges labeled R2 and R3. Booklet stapling requires that both Staple Cartridges be free of jammed staples.
WARNING: Do not perform this procedure when the printer is copying or printing.
  1. Make sure the printer has stopped copying or printing.
  2. Open the Finisher Front Door.
  3. Squeeze the orange R2 and R3 levers together and pull the Staple Cartridge unit out of the Finisher until it stops.
    NOTE: The Staple Cartridge unit does not detach from the Finisher.
  4. Grasp the orange tabs on both sides of the Staple Cartridge and lift the cartridge out of the Staple Cartridge Unit.
  5. Push the new cartridge into the Staple Cartridge Unit.
  6. If no jammed staples are found, repeat step 4 - 6 for the other Staple Cartridge.
  7. When finished, return the Staple Cartridge Unit to its original position.
  8. Close the Finisher Front Door.
Solution : Load Staples in the Main Stapler of the Professional Finisher NOTE: Using Staple Cartridges other than the recommended staples may impair quality and performance. Only use only Staple Cartridges recommended for this Finisher.
  1. Make sure the machine has stopped copying / printing.
  3. Grasp the orange R1 lever on the Staple Cartridge and push it to the right.
  4. Grasp the orange tabs and pull the cartridge out of the Finisher.
  5. Check inside the Finisher and remove any loose staples.
  6. Pinch both sides of the staple case and remove the staple case from the cartridge.
  7. Insert the front side of the new staple case into the Staple Cartridge, then push the rear side into the cartridge.
  8. Grasp the orange tabs on the cartridge, and then insert the cartridge into the Finisher until it click into position.
  9. Close the Finisher Front Door.
Solution : Load Staples in the Booklet Maker of the Optional Office Finisher LX NOTE: The Booklet Maker uses two staple cartridges. Booklet stapling requires that both staple cartridges contain staples.
  2. Open the Finisher Side Cover.
  3. If the Staple Cartridges are not visible, grasp the vertical panels to the left and right of the opening and slide them to the center.
  4. Hold the tabs on both sides of the cartridge and pull the cartridge out of the finisher.
  5. Hold the tabs on both sides of the new cartridge and insert it into the original position in the Finisher.
    NOTE: If you have trouble inserting the cartridge, make sure the staples are positioned correctly in the cartridge.
  6. Starting at step 3, repeat the procedure for the other cartridge.
  7. Close the Finisher Side Cover.
Solution : Load Staples in the Integrated Office Finisher WARNING: Do not perform this procedure when the printer is copying or printing.
  1. Make sure the machine has stopped printing or copying, then open the Front Cover on the Integrated Office Finisher located under the Scanner Assembly.
  2. Remove the Staple Cartridge by grasping the cartridge by the orange handle and pulling it straight out of the Finisher.
  3. Remove any loose staples inside the Finisher.
  4. Pinch both sides of the staple case and remove the staple case from the cartridge.
  5. Remove the new staple case from its packaging and insert the front side of the case into the staple cartridge. Push the rear side into the cartridge. The cartridge will click into place when it is installed correctly.
  6. Grasp the cartridge by the orange handle and insert the cartridge back into the stapler until it clicks into position.
  7. Close the Front Cover.
    NOTE: If the Front Cover is not completely closed a message will be displayed. The machine will not operate if the cover is even slightly open
Nov 18, 2013 | Xerox WorkCentre M-24 Color Copier
I have tried to reload the stapler but it will NOT staple What am I doing wrong?
1. Make sure you have the correct staples for the machine. This machine requires "standard" staples, which are 1/4" staples.
2. Check the staple cartridge to make sure there are no visible jams.
3. Check the power connection to the stapler. Is it plugged in? Is the plug working?
4. If you continue to experience problems, contact the manufacturer at
1-800-STAPLES. They will replace the stapler if it continues to malfunction.
Apr 18, 2011 | Staples One Touch High Capacity Stapler
I can't seem to reload staples into this stapler. I used the staples that came with it and it worked fine. I try reloading and it doesn't staple.
With the stapler sitting a solid surface, turn it 180 degrees so it is pointed away from you, and you are looking at the back. Press down on the plastic extension that you see (about mid-height on the stapler). This releases the staple-holding compartment (it shoots out the front of the stapler). Reload it with standard staples, push the compartment back in place until you hear a click. Voila!
Apr 15, 2011 | Staples One-Touch DX-3 Desktop Flat Stack...
WHERE do I open it to refill it??
Located on the end opposite of where the staples come out, there is a spring loaded cap. Push it in toward the base of the stapler and slightly down to release the retaining hook. then let the spring release the pressure rod and pull it out. Connedted to the end of the rod you will see a plunger that is shaped like a short run of staples. Make a mental note of how and where this plunger slides into the base of the stapler. Place a run of staples into the stapler in the same manner that the plunger fits then replace the plunger into the same place following the run of staples. Compress the spring into the stapler and attach the hook as it was. Now you are ready to work.
NOTE: If you cannot compress the spring enough into the stapler you have inserted too many staples, just remove some of the run of staples and try again.
Nov 12, 2010 | Arrow T50P ARROW STAPLE GUN
Our Canon NP6035 copier won't staple. It had a jam in the stapler, which I removed. We installed a new staple cartridge. The stapler makes indentions in the paper, but it won't advance any staples.
Do you have a 10 or 20 bin finisher? I'm guessing you have a 10 bin. Did you install the stapler cartridge in correctly? There is a small black plastic gear that cracks and the stapler will not work. The two way's to solve the problem is to replace the gear or the stapler unit. Both may be had to find. Good Luck
Aug 24, 2010 | Canon NP 6035 Copier
Stapler is not dispensing staples after new cartridge is inserted. Can you help?
Remove the staple cartridge, look into the cartrige area, are there any stray staples in this area, if so remove them, cycle the unit a couple of times without the cartrige in place, check the output end, any stray staples here? re assemble making sure you pull the first row ow staples even with the nozzle of the cartrige.
Hope this helps
Ed
Apr 30, 2009 | Office Equipment & Supplies
My Swingline model 520e jams every other time I staple.
There were a few staples left in the cartridge when the stapler stopped working. I went thru all the steps on bottom for stapler after changing the cartridge with two different cartridges. It makes the noise and puts marks in the paper, but no staples come out of it.
Mar 18, 2009 | Staples Swingline® 36115 Staple Guns Tools...
Can't load the stapler
check those staples or take to home store where you and i am sure they will help you figure it out
Nov 20, 2008 | Powershot Tool Company Cobra 8000 Forward...
Refilling the staple gun
The staples do not go on the bar you pull back but directly into the bottom once you have pulled the bar back. I was trying to put the staples on the bar at the back and push them into the stapler.
Oct 10, 2008 | Arrow 8000 Power Shot Pro Staple & Nail...
Stapler
please make sure that there are no staples jammed in the unit,
take the staple cartridge out, release the leaver on the staple cartridge and remove the first sheet of staples, close up the leaver, and reinsert in the copier.
then try to staple again
May 13, 2008 | Toshiba e-Studio 350 Copier
Canon imageRUNNER 400S Copier Logo
347 people viewed this question
old marine
old marine
