Question about HP OfficeJet D135 All-In-One InkJet Printer
Print quality on oficejet all-in-one hp d135: Re: How do I "clean" / prevent background printing from a prior print request? Problem: 1st print OK; 2nd printed 2nd page with printing from some other source also printed on page 3rd page: same as 2nd: also included printing from another prior print job presumably.
    Problem Solver:
  • 12 Answers
Go to the printer's Properties and cancel all printing jobs that are in queue. Switch of the Printer. Restart it.
Take print of any document and see if problem is solved.
Posted on Apr 27, 2009
Getting lines across the page when printing pictures
This is a well known (painful)phenomenon.From the steps recommended by HP inthe manual I would try the following:1. Usea higher print quality setting.
2. Align the printer.
3. Clean the printheadTo clean the printhead from thecontrol panel:Press Setup.Press the down arrow button tohighlight Tools, and then press OK. Pressthe down arrow button to highlight Clean Printhead, and then press OK. Theproduct cleans the printhead. Pressany button to return to the Tools menu.After cleaning the printhead, printa print quality report. Evaluate the print quality report to see if the printquality problem still exists.
Oct 22, 2011 | HP Photosmart Premium C309A All-In-One...
I have an hp officejet d135. It has knew ink jets and is hooked up. When I try to print the ink won't come out and the window says it's empty. Do I have a toner and if so where is it?
Your printer has a print head under the ink cartridges. You can try a cleaning, and if this does not fix the issue, you may need to replace the print head .
Clean Printheads function
To activate the Clean Printheads function from the front panel:
  1. From the front panel, press MENU.
  2. Press the RIGHT or LEFT ARROW until Status and Maintenance displays.
  3. Press ENTER
  4. Press the RIGHT or LEFT ARROW until Clean Printheads displays.
  5. Press ENTER
After a few minutes the HP Officejet D series will automatically complete the printhead cleaning operation.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Thanks, Joe
Jan 24, 2011 | HP OfficeJet D135 All-In-One InkJet...
How do one correct print quality in hp color laser jet 2600n
Hi Good day!!
Follow this method hope it helps you!!
During the printing process, paper, toner and dust particles can accumulate inside the printer. Over time, this buildup can cause print-quality problems such as toner specks or smearing. This printer has a cleaning mode that can correct and prevent these types of problems.
This printer has two processes for generating cleaning pages: one is automatically generated and one is manually generated. When a new black print cartridge is installed, a cleaning page will be automatically generated prior to calibration.
Clean the fuser using HP Toolbox
NOTE: Use the following procedure to clean the fuser using the HP Toolbox. To clean the engine when the computer is running an operating system that does not support HP Toolbox, see the late-breaking Readme on the root of the CD-ROM, or visit http://www.hp.com/support/clj2600n .
1 Make sure that the printer is turned on and in the Ready state.
2 Open the HP Toolbox using one of the following methods.
On the Windows desktop, double-click the HP Toolbox icon.
* On the Windows Start menu, click Programs (All Programs in Windows XP), click HP , click HP Color LaserJet 2600n, and then click HP Color LaserJet 2600n Toolbox .
3 Click the Troubleshooting tab, and then Troubleshooting Tools .
4 Click the Print button next to step 1, "Click the "Print" button to print out the Cleaning Page."
5 Remove the Cleaning Page from the output bin, and load it printed side down in Tray 1.
6 Click the Clean button to complete the cleaning process. Press the GO button on the printer control panel. The Cleaning page will print, with a second page adhered to the first page. This is normal behavior during the cleaning process.
Cleaning spilled toner
Defective print cartridges can develop leaks. Also, after a paper jam has occurred, some toner might remain on the rollers and guides inside the printer. The pages that print immediately after the jam can pick up this toner.
CAUTION: When cleaning the printer, do not touch the ETB with a damp cloth or with fingers.
Cleaning the paper path
The device features a special cleaning mode to clean the paper path.
NOTE: If there is access to HP Toolbox, HP recommends cleaning the paper path by using HP Toolbox.
Clean the paper path
1. Use the (LEFT ARROW) or the (RIGHT ARROW) button to select Service, and then press (SELECT).
2. Use the (LEFT ARROW) or the (RIGHT ARROW) button to select Cleaning Mode, and then press (SELECT).
A page feeds through the printer slowly. Discard the page when the process is completed.
3. Load plain letter or A4 paper when prompted.
4. Press (SELECT) again to confirm and begin the cleaning process.
Calibrating the printer
Calibrations are performed at regular intervals. For best print quality, a calibration can be performed from the control panel using the following steps:
NOTE: This will calibrate the color and clean the black electrostatic transfer belt (ETB).
1 Use the (LEFT ARROW) or the (RIGHT ARROW) button to select System setup and then press (SELECT).
2 Use the (LEFT ARROW) or the (RIGHT ARROW) button to select Print quality and then press (SELECT). Calibrate color will display on the control panel.
Press (SELECT).
3 Use the (LEFT ARROW) or the (RIGHT ARROW) button to select Calibrate now and then press (SELECT).
4 Press (SELECT) to start the calibration.
Other options for print quality defects that still persist
Oct 26, 2010 | HP Color LaserJet 2600n Printer
HP D135 PRINT error
I am sorry the print head goes out on the B And W on these things quite frequently. however you can go to www.hp.com amd go threw thier secdualed way of testing the print head but am sure you will find it defective. I had one and it was a problem. B e aware they have a new head that replaces the old head that lasts much longer.
Oct 05, 2009 | HP OfficeJet D135 All-In-One InkJet...
Officejet d135 - "Supply Expired" error message
HP, in order to sell more ink, monitors the expiration date of the cartridges installed. Solution is either to buy a new unexpired cartridge from HP or to disable the date monitoring built in to the printer. This latter is done by removing the button cell located inside the D135 printer on the left hand side or by simply slipping a thin piece of plastic between button cell and metal contact. You will no longer have date function on printer, but it won't object to expired cartridges either.
Aug 07, 2008 | HP OfficeJet D135 All-In-One InkJet...
Test page quality bad
When I scan a document it prints out small. How do I change the size?
Feb 21, 2008 | HP Photosmart C4280 Aio Printer
HP d135
Clean the copper contacts of the ink cartridge and the printhead wih the cotton swab and then try. Moreover in the printer there is an option to clean the printheads and ink carts. Later ty to print the h/w test page from the printer, if it prints fine then in the computer, righth click the printer icon and left click properties,in the color settings check if there is an option print in grayscale ... if thatoption is checked then uncheck the option.. and then print the test apge from the computer. If while priting the h/w test page it does not print in color then either upgrade the printer or replace the printer as the contacts of the printer ink carts slot are corrupted.
Jan 22, 2008 | HP OfficeJet D135 All-In-One InkJet...
HP OfficeJet D135 All-In-One InkJet Printer Logo
112 people viewed this question
Ben Johnson
