Question about Dewalt DC011 AM/FM Radio
Dewalt Radio Radio stopped working, power is good up to radio. Removed all visual screws, but still can not remove the front or back panel from each other. Is there some secret that I am not aware of? I know that there is a fuse that needs to be replaced, but can't get to it. Need some assistance. Thanks, Chris
Take all screws out of front perimeter, then there are 2 screws on the back at the bottom right and left you have to look close these screws are deep.
Posted on Nov 25, 2007
SOURCE:
How do i remove the stock radio from my 1993 geo metro 4 door hatchback
here is the online fsm quote
  1. Disconnect the negative battery cable.
  2. Open the glove box. Remove the glove box open panel.
  3. Remove the air conditioning switch connector and heater control unit lever knobs. Pull heater control unit cover plate from instrument panel.
  4. Remove the gearshift control lever upper boot and center console.
  5. Remove the ashtray.
  6. Remove the instrument panel center trim bezel and radio face plate.
  7. Remove the screw from the back of the radio receiver and the screws from the front face of the radio.
  8. Remove the radio.
Sep 30, 2014 | 1993 Geo Metro
Disassembly of the tivoli table top radio
After removing the 6 screw, gently slide the front panel out of the box. Now disconnect the little 2-way connector with a black and white wires: it should be the more tight cable between the front cover you have just removed and the rear panel.
Now slip-on your fingers in the box and push the rear panel up to slide it off the box, so that you can turn gently the front panel, pass it through the box and get the electronic completely apart from the wooden case.
Mar 16, 2012 | Tivoli Kloss Model One AM/FM Radio
My dewalt stopped giving any sound
Try this if the display seems stuck on the same station: If you take off the front of the radio (don't forget 2 screws in back!) you will notice a set of black and red wires running from the 2 AA backup batteries to the digital display circuit board. The wires plug into the board with a little white plug. If you unplug this the display will fade to nothing. If you plug it back in it will display an unset digital clock format. This seems to reset the radio, after which it should work.
Nov 11, 2010 | Dewalt DC011 AM/FM Radio
DeWalt DW911 Dis-assembly Problem
look on the back of the radio theres two more screws by the mounts for the cage
Feb 18, 2009 | Dewalt DC011 AM/FM Radio
DeWalt DW911 Radio/Charger
the second fuse is behind the circuit board,in middle of the radio.
there are 4 screw holding circuit board. Still looking for 2 AA battery.
Oct 09, 2008 | Dewalt DC011 AM/FM Radio
Dewalt dw911 radio
I had the same problem with the case not coming apart after I took the screws off, but thanks to someone posting a suggestion on this website, I was able to take it apart and take care of the problem. Use a soft mallet and use it around the seam of the radio until it pops loose.
By the way, my original problem with the radio was that it would not get any power at all, whether using the power cord, or an 18v battery. I was able to fix the problem by replacing the fuse located inside the case (250v / 1AMP)......works great now!! Many thanks to all of you who posted suggestions on this great website!!
Jun 05, 2008 | Dewalt DC011 AM/FM Radio
DEWALT DW911
2 screws sunk in at the back left and right. no need to remove speaker screws.
Oct 27, 2007 | Dewalt DC011 AM/FM Radio
Dewalt DW911 jobsite radio
Got mine open.
There was a fuse inside - Replaceable - fixed the problem.
There were no hidden screws, none under stickers or in the battery box like suggested by others, and the 2 magic release screws not so. There are several deep screws requiring a long philips, but the entire seam is glued (why?) so to open the radio I had to hit the body near the seam with a rubber hammer to crack the seam loose once all the screws were removed, comes right apart. Put it back together without glue, just the screws, it will be fine.
Sam. DesertSolutions.net
Sep 06, 2007 | Dewalt DC011 AM/FM Radio
Radio not working
Have you tried changing the AA Batteries, sounds simple, but a lot of people forget to try this. When they go flat, they lock the radio out and nothing will work. HHM Dewalt Agent
Sep 28, 2006 | Dewalt DC011 AM/FM Radio
Dewalt DC011 AM/FM Radio Logo
281 people viewed this question
Top Dewalt Audio Players & Recorders Experts
Gyula Lacz
Daniel
Daniel
Steve Pack
Steve Pack
Are you a Dewalt Audio Player and Recorder Expert? Answer questions, earn points and help others
