Question about NetGear ProSafe GS108 8-Port Gigabit Ethernet Switch (GS108NAKIT)
Switching from Linksys 5 port switch to Netgear 8 Port Gigabit
We have 4 computers on our small buisiness network and one internet connection. System worked with Linksys 5 port switch. Swapped switches and cables and booted all computers. 2 computers work fine...autodetected everything. Other 2 computers do not work at all. Was able to connect to local area by manually inputing IP addresses, but could not get connection to the internet for either computer at all. 3 computer (2 work 1 not) are the exact same. Same drivers, same networking card (Intel Pro/1000 MT) all running xp. Other computer is vista laptop attempting to connect via cat 5 (this is the other that does not work).
Please help if you can...i'd appreciate it. Small buisiness and cant afford expensive tech assists, but we need to add another computer to keep up with workload.
    Scholar:
  • 118 Answers
Kindly check the Gateway used in the computer where internet is working.....
to find gateway follow this
start menu >>> RUN>> CMD>>>> Ipconfig
then configure this gateway in all other systems and ask for DNS from you isp as well..to provide DNS manulay.
If still dont work ...
tell me the all information you get by useing ipconfig command in the PC where internet is working.
like IP address
Gateway
DNS
i will make you a map to follow.
best regards,
Posted on Dec 02, 2008
GS605 v4 netgear
Move your primary Internet connection to port number 5. Although it is not mentioned in any of the documentation, Port 5 is the uplink port.
Feb 25, 2012 | NetGear GS605 5Port Gigabit Ethernet...
I've got a BT HomeHub which works fine with a 4-port Ethernet switch to give me a small home network of 1 Mac Pro, 1 Laptop and 1 printer. I have an older Netgear RO318 Router - with 8-ports. But when...
When you use the older Netgear RO318 Router, make sure you don't use the WAN/Internet port, only use the numbered switch ports of the router.
Jul 31, 2017 | NetGear RO318 Router
Hi I would like o hook up a netgear prosafe 8port gigabit switch to my pc and run an ethernet cable which is allready hardwired to my sony bluray player so I can enjoy netflix
It would be much easier to use a simpler device, namely any Netgear 10/100 wireless router.
Cable-modem (or DSL-modem) --> Router's WAN port
Router's LAN port #1 --> your desktop computer
Router's LAN port #2 --> your Sony player
Router's wireless adapter --> your iPod Touch's WiFi adapter
Since the cable-modem (or DSL-modem) is only delivering 5 to 25 Mbits/second to your router,
unless you are paying a _lot_ of money per month to your ISP,
there's no need to buy/use expensive "gigabit" equipment.
Jun 06, 2011 | NetGear ProSafe GS108 8-Port Gigabit...
I can't connect to internet via my tv all the sudden . I streamed a movie on netflix just fine just yesterday . Today it won't connect . I checked allt he wires and connections to the computer and modem...
Here are a few things to try:
- Remove all the devices plugged into the netgear and leave only the TV and Internet connection
- Swap the cable for the TV Internet connection
- Try a different port on the netgear
- Monitor the activity lights on the netgear
Are you still able to connect to netfix via a computer?
Post any findings
Apr 26, 2011 | NetGear ProSafe 5-Port Gigabit Desktop...
How do i connect two computers so they both have the same ip address i have a linksys 5-port workgroup switch will that work ? also i had hooked it up but only one of my computers had internet
They cannot have the same IP address due to the mechanics of DHCP. Buying a cheap 50$ router (not switch) will fix your problem as your internet service provider will see that device as a single unit that it will assign an IP and then the router will give out internal ip addresses so that they can get online. The switch does not have this functionality.
Feb 16, 2011 | Linksys EZXS55W EtherFast 10/100 5-Port...
Hi, Im using Linksys SR224 24 ports as my main switch. I got a poor internet connection, this problem occurs few weeks ago. I tried to connect my modem through a LAN cable directly to my server and...
Try a brand-new cable between the modem and the "uplink" port on the router.
Try a brand-new cable from one of the "LAN" ports to your computer, and test to see that you get a good connection.
Jan 04, 2011 | Linksys SR224 (srw224) 2x1000 Mbps...
I have a Linksys 5-port switch connected to a cox cable modem and I'm trying to use it to connect two computers at the same time. Only one works at a time and I have to reset the switch and modem to get...
Because the cox cable modem will only bind to one mac address (computer). You need to purchase a router, any router linksys, dlink, will do, get a wireless one so you can setup wifi as well. Plug your cox cable modem into the wan port on the router, plug your pc into one of the ethernet switch ports, you can use your web browser IE to login to the router and secure your wifi signal, power cycle your modem to make it bind to the new router. Most linksys dlink are programmed for a class c network, you could in theory put 254 devices, computers on your connection now.
Aug 27, 2010 | Linksys EZXS55W EtherFast 10/100 5-Port...
Linksys SRW2008 blocking ports
blocking ports and QoS is a layer 3 function, switches are layer 2 unless you buy a layer two switch. You will need to do this on your router.
Mar 31, 2010 | Linksys SRW2008 8-Port Gigabit Ethernet...
How do i set it up with my modum router and switch
Connect your modem/router to one switch's port. Connect your PC to the rest ports.
Dec 06, 2009 | Linksys Instant Gigabit 5-Port Workgroup...
Want to have wireless with my Limksys Sr2016 switch
Go to: www.speedtest.net with a laptop on your network.
Find your speed. now repeat on same laptop plugged directly into the cable madem.
Do the settingsa change much?
If so, your network is at fault. If not, Comcast is lying to you.
May 12, 2009 | Linksys SR2016 16x1000 Mbps Networking...
Computers & Internet Logo
391 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
