Wobbly Tub my roper RAB423DWO started making a really loud beating noise and when i open the lid and push on the tub it moves about 3-5 inches in any direction.
5 Suggested Answers
catriver
  • 878 Answers
SOURCE: Tub and Basket
Fairway, sounds like you have a worn drive block. You are going to have to remove the agitator and inspect the drive block. If it is the drive block you will get some good hammering when the spin cycle stops. I will attach some photos of a worn out drive block. If you want to attempt to handle this yourself, we can walk you through it. Catriver..post back.
Posted on Oct 23, 2006
  • 1314 Answers
SOURCE: loud cliunking noise in beginning of spin then won't spin
get a flashlight and see if a foreign object has fallen down through one of the tub holes and is jamming the tub you have to look real close
Posted on Jan 11, 2008
  • 1028 Answers
SOURCE: Amana NAV2335AWW During the agitation cycle
suspect noisy brake not a major concern but not a pleasant noise to listen to..best not try repairing yourself ..believe that may be a maytag version if so brake spring can be dangerous to release without proper tools
Posted on May 01, 2008
SOURCE: whirlpool GHW9100LW1, belt came off
I had the same problem and being a procrastinator, I waited until the belt came off before launching a full scale investigation into the knocking noise it had been making for about a year. Here is what I found and below that is my no guarantees fix.....
I removed the nut and pulled the tub pulley off. I noticed the tub shaft has a "shoulder bolt" and the pulley could not be tightened onto the shoulder bolt with enough squeeze to keep the tub pulley from wobbling. Tolerance issue... maybe? I decided to measure the keyed tub shaft with calipers and found the thickest part of the shaft to be 1" ish. The Shaft is part of the tub bearing assembly (from my observation) and the tub shaft is part of the tub bearing which measured 1 1/4" diameter. I found a washer that was 1" inside diameter and 1 1/4" outside diameter and placed it over the tub shaft behind the tub pulley. I tightened the nut snugly and reinstalled the belt. Ahhhhh, quiet operation and no more wobble. I will let you know if it causes another problem but from what I can tell.... replacing the tub pulley with another of the same dimensions will not work.
you don't need a very thick washer(my washer is too thick (.1"ish) so I will replace it soon(yeah right) with 1/32" or maybe 1/16"...I used rubber but I think steel or brass or what ever would probably work too.
Purists will tell you that the lock nut should be replaced, or if you don't use the permanent thread locker you could use loctite.
Hope that helps.
Posted on Oct 02, 2008
  • 5 Answers
SOURCE: Tub is leaning down slightly to the right and slightly downward
Dear Hi, The reason for the nuisance is that the vibration mount on front end of the tub is worn out and you need to replace the same. you can DIY but its better if you take a technical help with someone who knows how to change them. Replacing the vibration mounts will solve your problem. Make sure that you replace both the mounts as otherwise it may again lead to unbalanced mounting and you may have the problem again too soon on the otherside.
Posted on Mar 23, 2009
RTW4640YQ0 made horrible loud noise banging so I pushed pause button and once lid release I removed laundry and see that back side of tub in down and when I reach my hand over top of the basket frame there...
There are several springs in the machine and it sounds like one of them that you cannot see has broken. To get an idea about the problem, drain the machine and unhook it, lay it down so that you can see what is going on from the bottom of it.
Nov 04, 2013 | Roper RAS6233KQ Top Load Washer
The tub is very wobbly and the machine was loud and moved across the floor when the spin cycle was on
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Apr 20, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Machine makes loud banging noise during the spin cycle
The load is out of balance. Open the lid and redistribute the contents. When it's empty, grab the basket and give it a slight push sideways. It should move a little but, not free swing. If it doesn't have much resistance, the "snubber" has dried out and should be replaced. It is simply a piece of rubber in a metal bracket, that rests on the tub. When the basket spins,the snubber keeps it from jumping around.
Aug 31, 2009 | Frigidaire FWT449
Washer makes loud, thumping noises during spin cycle.
support bracket that supports the tub is breaking. stick your hand inside and push up and down and see if its coming apart. if u look at it when it runs does it wobble?(the tub) if not take a look at the pulley on the back and see if its wobbly.
Jun 22, 2009 | Washing Machines
Loud noise in washing machine
Hi, Raise the lid and stick something into the hole to activate the lid switch. Start the washer in spin cycle and after 30 seconds or so, release the lid switch and see if the tub continues to turn and make the rumbling noise. It sounds to me like the block that holds the inner tub has gone bad.
Has nothing to do with the move but, might have just happened.
Please let me know if this is the case or if I can assist you further.
Thanks
Vic
May 30, 2009 | Kenmore 22422 Top Load Washer
Whirlpool ultimate care II will not spin
You said,washer is full of water and will not spin. You hear the lid switch clicking. When you start it on spin cycle and hear a hum, the tub moves a couple of inches and then stops...shortly after it shuts off.
Some reasons this may happen
Washer won’t drain or spin
n
1. Is the drain hose clogged, or the end of the drain hose
more than 72 inches (183 cm) above the floor?
2. Is the lid open? ............Also the lid switch can be faulty!!
The lid must be closed during operation.
3. Is there excessive sudsing?
Always measure detergent. Follow manufacturer’s directions.
4 If you have very soft water, you might need to use less
detergent.
Sounds to me like the lid switch can be faulty!!Then it acts like the lid is open.
Huuum
Oct 13, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer makes loud knocking noise
I think that the drum bearings have gone on the machine..
To open the door and spin the empty drum quickly by hand and you should hear the noise or say a less amplifed one.. You can also move the inner drum up and down to see if there is something wrong with it..
Sep 28, 2008 | Roper RAS6233KQ Top Load Washer
Tub continues to spin
sounds like someone either wired out your lid switch or it is stuck in the closed position check that first
Aug 18, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Washing Machines Logo
20 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
