Question about Brother IntelliFax-2820 Laser Fax
BEEP, BEEP,BEEP IF UNPLUGGING YOUR MACHINE DOSEN'T DO THE TRICK, MAKE SURE ALL THE BUTTONS ARE UN STUCK. KINDA FUNNY... MY SECRETERY WAS FAXING SOME INS. PAPERS FOR ME THE OTHER DAY. SHE YELLS FROM THE HALL..."HEY, MICHAEL". I GO TO SEE WHAT HAPPENED, AND THE FAX MACHINE DOSEN'T WORK. SO I LOG ONTO FIXYA. THE SOLUTION... UNPLUG, WAIT 20 SEC. AND TRY AGAIN. GOOD IDEA, DIDN'T WORK. EVERY TIME YOU PUSHED A BUTTON ALL YOU GOT WAS BEEP, BEEP, BEEP. CHECK THE BUTOONS. SHE WAS DIALING SO HARD SHE GOT THE NUMBER 8 STUCK DOWN. WELL, I GOTTA KICK OUT OF IT ANYWAY.
Who is better than you? All kidding aside, I programmed forwarding to another office fax machine this morning and then all of a sudden noone was able to send from that fax machine any longer. The 3 beep symptom.
I checked and one of these keys was sticking. Thanks for the solution.
Posted on Oct 15, 2007
    Sniper:
  • 71 Answers
The Start Button can become stuck on these very easily. If it is stuck, then press it down and it should jump back.
Posted on Aug 14, 2007
SOURCE:
How to reset error copier mechine estudio 2006
The Toshiba eStudio 350/450 copier is one of the more popular copiers available in the marketplace. It has several features that make copying, printing and faxing easier, such as password protection and customizable settings. There are times, however, when a lost password must be recovered. Toshiba has provided a simple method to recover the password and, if need be, reset the copier settings.
By Daniel Valladares
Resetting a copier to its original settings is a simple way to fix several problems.
Step Make sure the machine is off. While holding down the "0" and "8" buttons on the keypad, turn the copier back on. Keep holding the "0"' and "8" buttons until the copier lets out a long beep. This will activate "Test Mode D."
Step Type in '263' on the keypad and press the green start button. The password should now show up on the copier's screen. At this point, you can type in a new password if you choose to do so.
Step Press 'Set' to set the new password. Turn the machine off, wait fifteen seconds, and then turn it back on.
Step Go to the functions you wish to reset through the main menu and press "Function Clear." If prompted, type in the password. Repeat for any function you wish to reset.
Oct 11, 2017 | Office Equipment & Supplies
My Panasonic viera tv will turn on and off but no other buttons work On the remote or on the tv itself
Try unplugging power cord for 10 sec. or for over night. That might be the trick. I did the same trick on a satillite receiver and a DVD player that got stuck like your tv is doing and it worked, doesn't hurt anything to do so. Hope this helps.
Feb 29, 2012 | Panasonic VIERA TH-65PV500 65 in. Plasma...
We have a DVD stuck in our Phillips DVD/hard disc recorder, after loading the dvd it would not read it then we could not open the door
Dear helen, I don know if this is possible with your machine but I have removed dvds by either; turning the power off to the machine then turning it back on then trying the remote again or the facia control. I f that dosen't work try unplugging it and using a knife to gently prise the door open then manualy pulling the cradle out. I have done this also without any damage.
Oct 09, 2011 | Televison & Video
I have a brother intellifax4100e and when ever i touch a button to send a fax dialing from the keys or using a programmed key - the machine beeps three times. I cannot send any faxes and i have tried...
When you get a treble beep it can be an idication that there is a key stuck down. Check every button to make sure it clicks ok. i bet you have one stuck.
Aug 18, 2011 | Office Equipment & Supplies
GE refrigerator pfss6pkwbss flashing 88 82 after a brief power outage...any info on how to resolve?
Simply press the top left (Engery Saver) and top right (Alarm) buttons at the same time for about 10 seconds--it will beep and reset the panel! I was told by both GE and a local repair service that I had to replace the entire control panel...what a RACKET!! GE needs to start telling people this trick when they call in with this error...it will come up every time there is a power outage.
Nov 23, 2010 | Refrigerators
Faxing multiple pages
Open the document feeder (number panel). Make sure that a switch actuator is not stuck down.
Jun 03, 2008 | Brother IntelliFax-2820 Laser Fax
All buttons cause machine to beep
Trying unplugging for 20 minutes maybe you can reset it.
Aug 28, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Can't receive a fax
Make sure the phone cord from the wall is plugged into the port in the back of the machine labeled "line" and NOT "phone"
Aug 02, 2007 | Brother IntelliFAX 2800 Laser Fax
Brother IntelliFax-2820 Laser Fax Logo
691 people viewed this question
James Cagle
James Cagle
ctnozil
Victorman
Victorman
