I have a Sony Disc Changer that skip on some CD's. All CD's are clean, and I went to an authorized Sony Dealer in San Diego, and they said it was fine. It still skip on some CD's. Do know of a good Sony Repair Facility in San Diego? The unit is two years old, and I bought it from a friend who used it a lot.
If you take it to Best Buy they can repair it at the service center.
Even if the CD's are clean, they can still be scratched. A scratch can not be cleaned and it can cause the CD player to skip. If this is the case, it is not the fault of the CD player. If the CD's are not scratched and still skip, then you do have a problem with the CD player. Most times it is the laser pick-up, but it can also be the spindle motor or even the DSP IC.
Is the skipping always on the same CD's? Do you have some CD's that never skip and others that always skip? If so then you have a few CD's that are just too scratched up to play properly. This happens sometimes and cleaning them will not help. Since this player is not under warranty, you can take it to any local repair shop for service. It does not need to go to a Sony repair shop. In fact, all Sony products of this type that are under warranty end up going to Mexico for repair. Sony no longer has any factory service centers in the US. They have places you can send your unit in the US, but they end up sending it to Mexico. Find a local repair shop and take it to them if you can determain that the player skips even when using a CD that has no scratches. Most minor scratches can be played thru by most CD players, but if a scratch is deep enough, it will skip.
I would first try a cleaning disk and If it still does that yes have your lens replaced
HI UNPLUG it for a day.and clean the lens.if it is showing error messages you should change lenses
Sony Electronics Inc
2 reviews - Write a review
16530 Via Esprillo
San Diego, CA 92127
(858) 942-2400
This is the closest Sony shop to you.
This is the service center addresss
San Diego DSSC Service Center 16795 Via Del Campo Dock 30A San Diego, California 92127 Voice: 866-766-9272
The lens is the problem of your device.the lens is faulty and needs replacement.
I have a Sony Disc Changer that skips on some CD's. All CD's are clean, and I went to an authorized Sony Dealer in San Diego, and they said it was fine. It still skips on some CD's. Do know of a good Sony Repair Facility in San Diego? The unit is two years old, and I bought it from a friend who used it a lot. Anyone know of a good place to have the lens replaced?
Thank you sir
