Question about Brother IntelliFAX 2800 Laser Fax
I have a Brother intellifax 2800. It's leaving streaks on all my fax output. How do it fix this problem.
  • 4 Answers
On the Intellifax, there is a glass bar that runs across and allows the fax machine to read the image. Take out the entire drum unit and you should see that bar in the middle of the machine, careful it can be hot. Take an alcohol swab, or a q-tip dipped in alcohol and rub it from left to right on the glass bar. You may also see some spilled toner that is causing the streaks. Remove any toner with the alcohol swabs, do not use water or try to vacuum (huge mess if you do). You do not have to get all the toner, just make sure the glass bar is clean. That should do it.
Posted on Dec 02, 2008
Black streaks on my Brother Intellifax 2800 when receiving
You most likely have a bad toner cartridge, The light sensitive drum will probably have a score mark in it causing the issue. Do a "copy" before replacing it, and then afterwards to prove it it has been fixed.
Sep 18, 2009 | Brother Office Equipment & Supplies
Intellifax 2800 fax machine
my suggestion would be to down the manual from brother.com
Jan 19, 2009 | Brother IntelliFAX 2800 Laser Fax
Brother Intellifax 2800 replace drum message
the unit that you install the toner cartridge into is actually the drum on this machine.
Jun 24, 2008 | Brother IntelliFAX 2800 Laser Fax
Black Streak
I would first try a diffent cartridge. If that doesn't work then you might have a bad transfer roller, the printer may need service.
Jan 10, 2008 | Brother IntelliFAX 2800 Laser Fax
Blank Streaks
streaks are caused either by the toner, drum, lamp or fuser.
If you make a copy and it does not show a streak then it was done by the person sending the fax. BUT, check this,
open door and take out toner cartridge. look for a thin glass that is on the bottom of the machine and wipe it. Toner spills will cause a black streak.
Nov 15, 2007 | Brother IntelliFAX 2800 Laser Fax
The brother Intellifax 2800 intercepts other faxes
Make sure that the proper phone number is installed in the fax.Also that they are not sharing the same common line.
Oct 17, 2007 | Brother IntelliFAX 2800 Laser Fax
Black streaks on the fax
Yes it does, the rubber blade that cleans the drum is not doing its thing properly, hence leaving your mark, pull the drum unit out and expose drum by pulling back the cover underneath it, you should see your mark on the drum, don't touch drum with fingers or brush/clean it, it is photosensitive too so keep away from light for any period of time.
Oct 16, 2007 | Brother IntelliFAX 2800 Laser Fax
Brother IntelliFAX 2800 Laser Fax Logo
129 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
