From the camera or computer, the color prints are dim somewuat indistint. the color ink cartridge is new (canon). Used maintenace for fine and fine deep cleaning. Still fatnt colors.
  • 734 Answers
Hi,There might be the printer roller pressure problem,, means there is a low pressure between the roller and the cartages(head of cartages) .
Thanks
Posted on Dec 02, 2008
    Sergeant:
  • 217 Answers
If the orignal prints from the camera is light it will print dim from the computer.still u can adjust the printquality from printer properties and make the prints darker.and also try checking any other print from the printer except the prints from camera.if that also comes dim then it might be printer problem as u said the cartridges r new,the print head needs reparing and cleaniong if the head is blocked.
  • 19,396 Answers
Try increasing printer resoilution from printer settings.
Also ensure you have the right paper tuype in printer settings.
  • Ginko
    Ginko Dec 02, 2008
    Check printer properties.
    Ensure that the printer is not set to economy mode/fast print.
    Increase printer resolution settings.
    Ensure that the paper type is set up correctly, if you print on photo paper using plain paper settings, you get dim colors.
    If this cannot fix the problem, the printer color managment can have a problem, this may be realted to a main board or firmware defect, or to a bad print head.
I just recived a used BJC-85 its is printing fine in black and white but not color whats wrong
Try some of the following possible problems:
1. Make sure the color cartridges are installed correctly.
2. Make sure the cartridges are not expired. There should be a date on the sticker on them.
3. Make sure that the cartridges are clean. Sometimes the ink can build up on the cartridges and stop ink from coming out.
4. Go to Start -> Control Panel -> Printers and Faxes. Find your printer and right click, then press Printing Preferences. In the options there make sure that color is selected.
Apr 20, 2011 | Canon BJC 85 InkJet Printer
Printing nice but very light
the ink may have become very old. i would suggest you to make a refill again.
Jul 30, 2008 | Canon PIXMA iP90 InkJet Printer
Tip
Canon MP 460 An Error Message Is Displayed On The LCD
If an error message is displayed on the LCD, take the corresponding countermeasure described
below.
Message Action
There are no photos in memory
card.
There are only invalid images on the memory card.
Photo data edited/processed on a computer should be printed from the
computer, not from the camera.
There is no paper. Reload the paper correctly and press [OK].
The paper is jammed. If paper has jammed in the machine, clear the jam, reload the paper in the
machine correctly and then press [OK].
Ink has run out.
U041
Replace the FINE Cartridge, and close the Scanning Unit.
If printing is not finished yet, just press [OK] on the machine to continue
printing in the “no ink” state.
Replace the FINE Cartridge with a new one as soon as possible after
printing finishes. The machine may be damaged if printing is continued
under the ink out condition.
The following ink cartridge cannot
be recognized.
U051
U052
U053
U059
The FINE Cartridge may not be installed properly, or the Cartridge may not
be the compatible with this machine. Install the appropriate FINE
Cartridge. If lines are misaligned or the resulting output is not satisfactory,
carry out the FINE Cartridge Alignment.
Some ink cartridges are not installed
in place.
U075
U076
Confirm that the FINE Cartridges are installed in the appropriate positions.
See “Replacing A FINE Cartridge” on page 75.
The ink absorber is almost full.
Press [OK] to continue printing.
Contact the service center.
The ink absorber is almost full. Printing will no longer be possible once
the ink absorber is full. Contact the service center immediately. Press [OK]
Incompatible device detected. Depending on the model or brand of your device, you may have to select a
print mode compliant with PictBridge before connecting the device.
You may also have to turn ON the device or select Play mode manually
after connecting the device to the machine. Perform the necessary
operations according to the instruction manual supplied with your device.
If the error is still unresolved, there is a possibility that you are using a
digital camera or digital video camcorder that is not supported by this
machine. Use a digital cameras or digital video camcorder compatible with
this machine.
Auto head align has failed. Make sure all required boxes on the head alignment sheet are filled in, and
that the sheet is set in the correct position and orientation on the Platen
Glass.
If the machine is connected to the computer, you can align the FINE
Cartridge using the MP Driver. Follow the procedures described in the
Printer Driver Guide.
The following ink may have run out.
U162
This FINE Cartridge may have previously been used, or the ink may have
run out. The function for detecting the remaining ink level will be disabled
since the remaining ink level cannot be correctly detected. If you want to
continue printing without this function, press [OK]. Canon recommends to
use new genuine Canon Cartridges in order to obtain optimum qualities.
on Dec 08, 2009 | Office Equipment & Supplies
Black 3e won't print, even with NEW printhead.
Hello!
Please check the "Rplacing an ink tank" part of the manual. Hope it will help you.
https://manualsbrain.com/en/manuals/1796179/?page=45
Oct 24, 2017 | Canon PIXMA MP780 All-In-One InkJet...
Canon IP4300 - the two black ink cartridges
No!
The large cartridge is used for text only printing.
The smaller black cartridge is used for black in images such as pictures.
You have a "C (cyan) M (magenta) Y (yellow) and B (black) color system. This actually saves the color inks for you. If the Black was not there, you would need to make a composite black from the color inks.
Don
Jan 31, 2010 | Canon PIXMA iP4300 InkJet Photo Printer
HAving trouble printing
Check and make sure you did buy the right one first.
Apr 23, 2009 | Canon PIXMA MX310 All-In-One Printer
Canon PIXMA MP450
I had the same problem and spoke to canon australia technician. Any 4 number code means it is a servicable error. 6500 code specifically says take to a service centre...
bugger....but thats what they told me...
Jun 08, 2008 | Canon Pixma MP450 All-In-One InkJet...
Canon IP90 portable . No ink printing.
Have you performed a nozzle test? If one or more of the colors is missing when you do the nozzle test, the printhead itself is likely in need of replacement.
Before considering replacment, perform a clean on the printer. Due to variations between mac and pc, please see your documentation / support files on how to perform the clean on your printer.
After performing the clean, again perform the nozzle check to see if the problem is resolved.
If still not resolved, remove and re-install any cartridges you recently replaced to make certain they are installed correctly.
May 01, 2008 | Canon PIXMA iP90 Mobile Printer
Canon Pixma MP830
pleaz alihn the new cartridde by programing or change the ink ,it may be dry
Sep 14, 2007 | Canon PIXMA MP830 All-In-One InkJet...
k24674
jasbo
jasbo
