Question about EliteGroup nForce3-A Motherboard
PORTS DO NOT WORK FOR PRINTER OR MOUSE - EliteGroup nForce3-A Motherboard
  • 67 Answers
Is your PS/2 (or PS/2 Legacy) enabled in your BIOS?
Also make sure your USB is also activated in BIOS.
Posted on Dec 02, 2008
My laptop cannot detect the mouse. It states that there is an undetectable device. I have followed all directions and I still can't get the mouse to connect to my laptop
I think this will help.
A USB Connector has 4 terminals.The two terminals at the ends are to supply 5 Volts. The middle two are for data transfer.
If the terminals at the end are OK the device will get power (5V). Then the computer can detect something was attached. But if one of the middle terminals are damaged, your computer cannot recognize the device.
The problem might be with the USB port of the printer. Connect it to a different port. Does it (mouse) work on your desktop machine? Then the problem is not with the mouse.
If the mouse fails on all USB ports, the problem is with the mouse. Check the USB jack of the mouse. Sometimes the damage is visible. Or else one of the 4 wires of the mouse cable is disconnected (damaged) due to bending of the wire. In this case, buy a new mouse or replace the mouse cable.
Jul 22, 2011 | Office Equipment & Supplies
Mouse can not work
this is usually do to a port going out or the total failure of the mouse.. or if it's a rather old mouse, the ball underneath is too worn to work.
if it's the port, there are 2 kinds, one is a round port (PS/2), you will have to turn off the computer to remove the mouse from this type of port.
if it id the round ps/2 port, you will have to either get a new mouse using usb, or you can try a new ps/2 based mouse.
REMEMBER you cannot plug in or remove a ps/2 mouse while the computer is still on!
The next port, and most common is the usb port. it's a small rectangle.
You most likely have atleast 4 of these on the back of your computer, and most of the newer computers have 2 on the front, sometimes in a hidden panel.
Sometimes if you are a windows user, windows will set a usb port aside for what normally resides there, and a mouse in a port that usally houses a printer usb plug will make windows not see the mouse sometimes.
Removing a usb port mouse is rather easy, you dont need to turn the computer off to do so.
Before considering replacing a usb mouse, try putting it into another usb port. sometimes this will work. also, see if the lights are working underneath when plugged in. (optic mouse, not ball mouse).
if you have determined that your mouse is broken, then the next step is to replace it. bestbuy sells mice for about 25-30 dollars.
if you dont mind waiting 3-7 business days, a reputable online retailer like can sell you a mouse for about 15-20 dollars, and 3btech does not charge for shipping.
usb mice can be found here:
ps/2 mice can be found here:
Jun 17, 2010 | Computers & Internet
The USB ports on my Toshiba A135 S2356 laptop are not working. I tried to use my printer and it says not connected. I bought a new cord but it still doesn't work. What should I do?
1. first check ur USB port using any other USB device, like pen drive, mouse, keyboard,etc.
if system detects that device, then ur USB port is OK!
2. if USB is OK, then the problem is with the 'Printer Driver' not the cord!
3. reinstall the printer driver!
4. update the driver!
5. if USB port is not working, then replace it!
if this helps, tell me.......
Dec 30, 2009 | Computers & Internet
My mouse and printer are both connected through USB ports. The mouse will not now work when the USB cable to the printer is attached and printer is turned on. All USB ports are working properly. This is a...
I had the same problem with mouse, it happens when devices connected to two USB ports that are close to each other, so I connected mouse in the back of computer USB and printer in the front USB (or reverse), or further away from each other.
Oct 30, 2009 | Microsoft IntelliMouse Trackball 1.0
Lenovo 3000 C100, mouse and printer problem
check your mouse driver and printer driver make sure you see them in the list
Jan 20, 2009 | Lenovo 3000 C100 Notebook
I have an Hp Deskjet D1320, it got shut-off incorrectly
Normal 0 Try disconnecting the Mouse Receiver from the USB port and reinstall the CD software program. When the program asks you to connect the Mouse Receiver to the USB port, do so and it should work.
Hope this helps. Bud
Jan 01, 2009 | HP LaserJet 1300 Printer
Computer won't recognize USB ports
If you are plugging a USB device into a different port it takes some time to recognize and install it - it re-installs for every port. There could be cable and/or port issues as well. Plug the printer into a USB port that the mouse does work on and allow several minutes for it to detect install it.
Dec 18, 2008 | Dell Dimension E521 PC Desktop
USB Ports on AL27 only work with printer and external hard drive.
I fixed the problem by going to "Device Manager," then to the "Universal Bus". Under "Universal Bus" are a list of the individual USB ports. You have to delete each one individually. When you delete each one, a window opens up which gives you various headers; select "drivers" and hit "uninstall". When you hit "uninstall", windows will ask if you want to proceed. Select "Yes". You'll then get a "warning" that the computer may not work correctly if do this procedure. You want to proceed with the deletion of each Universal Bus port. Once you've removed the Universal Bus ports, then reboot windows. Windows will detect the individual Bus ports and find new drivers for them. Once the drivers are installed (automatically by Windows), the USB ports will be operational.
Nov 15, 2008 | Sharp Actius AL27 Notebook
Aspire 3610 USB ports
I think you might have a loose cononection for the data ports. Try putting a little bit of force on the usb device. Up, down left right. NOT ALOT. If it starts working when force is used, i tihnk you should try to take it apart and resolder the connections. If it dosen't work, uninstalling the driver and installing.
Jun 01, 2008 | Acer Aspire 3680 Laptop
USB ports no longer working
After all done,
Did you think of replacing motherboard?
Feb 17, 2008 | Computers & Internet
EliteGroup nForce3-A Motherboard Logo
Top EliteGroup Computers & Internet Experts
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
