Question about Canon imageRUNNER 4570 Copier
Grey scalloped line across top of page
Printing a grey scalloped edge to the page. Toner? Drum?
  • Paul Pettit
    Paul Pettit May 11, 2010
    Yes, sure sounds like it. The warranty card indicates the drum should last 64,000 or one year. Most of the time the drum lasts well past the 64,000 copies. Check to see at what copy count the drum was last changed. Good luck.
  • 168 Answers
Maybe drum could also be fuser belt
Posted on Dec 08, 2008
When you print each page has a gray/black line running down the page from top to bottom about 2.5 inches from the edge of the paper. Sometimes it is darker and other times it is lighter. We have tried...
While the line is showing up on the output pages.
Stop printing and put paper in the manual feed tray (tray 1).
Start printing again. As a page gets pulled into the printer about 1/2 way open the top cover.
Pull out the toner and look at the page inside the printer. If it doesn't have the grey/black line, get the fuser replaced. It is defective.
Jun 09, 2011 | HP LaserJet 1300 Printer
Toner blotched on printed material When printing
If the line has a 1/8" white margin on either side, clean your glass and mirrors.
If the line is all the way across your page, consult your users manual for cleaning the sawtooth electrode (open the front door and take out your waste tank, there is a green rod on each drum cartridge you can pull and hear a zipping noise) and cleaning the laser lens (there should be a cleaning wand under your waste tank, turn pad side down and insert in the gap underneath your drum cartridge)
Jan 14, 2011 | Sharp MX-3501N All-In-One Printer
Samsung scx5315f printing black smudge along edge of page
The fact that it's printing anything suggests that it is not a Toner problem. Remove the toner, and have a look at the run inside the printer, checking for any excess toner which is in there. Also, check the Drum and Imaging Unit for damage, wear and tear etc. There will also be a static strip near the imager, with a little tab which you can sweep across the unit to clean it.
Mar 05, 2009 | Samsung SCX-5315F All-In-One Laser Printer
I have a dark line across copies
Whats the make and model of the copier?
One culprit might be the drum.  If you can take a look at the drum from your copier and you see black lines on it.  It could be scratches on the drum or it may need a new cleaning blade to clean the toner off the drum.
Nov 11, 2008 | Office Equipment & Supplies
Faint grey lines Every 1/3rd of a printed page
This is the test to determine toner or fuser issue.
Print a test page
When you hear the paper feed into the machine open the top to stop the machine
Remove the toner cart.
You should be able to see the page with printing on it. (This is before the page hits the fuser)
If you can see the smudge or marks on the page the problem is most likely the cartridge or cleaning roller but NOT the fuser.
If the page is clean the problem is most likely the fuser.
Oct 22, 2008 | Lexmark Optra S 1855 Laser Printer
Consistent, faded and streaking vertical lines across entire page, from top to bottom.
Toner issue getting to drum - use gen toner cart.
or Drum blade stuffed (lines are down page fro top to bottom- replace drum assy
Drum has been exposed to light faint or blank across copies repeated 4 times down page - replace drum assy
or upper fuser roller stuffed, down page, smudgy print -  replace fuser
LSU(laser) or boards rarely cause issues
Oct 25, 2007 | Samsung ML 2010 Laser Printer
Flaws at top of each page when printing
Replace toner cartridge drum is scratched
(Possibly by staple going threw machine if that what each of the five marks look like, all those removed staples always seem to end up in printers)
You can pull it out (I think right top cover opens and cartridge pulls up and to the right)  then .. turn it over and gently pull back cover see drum has same marks as you see on paper, you can gently rotate drum by using gear on edge do not force it only turns easy one way, Do not touch drum surface very delicate and sensitive. Normal disposable item buy a New cartridge here is HP part number for your model  HP C8543X (HP 43X) Toner Cart.
Oct 19, 2007 | HP LaserJet 9040n Printer
Colour lines across the page
Hey Paul, Can you post a scan of the printed paper? It may help diagnose your problem. The most common cause of lines accross the page is either the PhotoConductor Unit or the 2ND BTR Assy.
Nov 30, 2006 | Epson Aculaser C1100 Printer
Canon imageRUNNER 4570 Copier Logo
159 people viewed this question
old marine
old marine
