Question about Smeg 24 in. DWD612SS Built-in Dishwasher
Hi our dw 1612 integral dishwasher has thrown a fault code E2 which according to the book is a tripping of the water level switch. unfortunately the book dosent tell you where the switch is located or how to reset it even when you find it !! would be really grateful regards keikth
  • 76 Answers
I don't mean to make you sound stupid but it isnt a switch that you can use.
It is used in a dishwaher to make sure that the water doesnt over fill and spill over out of the dishwasher and electricute someone. it cuts off the water (when working corectly) and washes as normal or if it over fills it tells you and in your case it is error E2
you need to speak to a appliance repare shop to see what needs to be fixed or replaced.
Hopefully this has givin you some help
if you have any questions plese dont hesitate to ask
Posted on Dec 03, 2008
Frigidaire dishwasher fault code i30 and drain pump is always running
I'll presume you have since cut the power??.
That error code should be in your owners manual but (once again) suspect debris is messing up the water level sensing system and telling the pump "the tub ain't empty yet!".
An exploded view of your unit should be available from a parts supplier and you can decide if you want to pull the DW and explore further. Often, a simple clean out solves the problem.
Oct 23, 2016 | Frigidaire Dishwashers
Whirlpool dp1040xtx flashing code 61 and 66. 61 flashed a couple times. What's wrong?
F6E1 - Water is not present in the machine when it should be.
Could be: inlet hose filter clogged, blocked holes on spray arms, dishes not loaded according to manual, water tap closed or water pressure too low, drain hose placed incorrectly, DW filters clogged, check dispenser (missing dispenser gasket, improper detergent), check water indicator (OWI or VWI) depending of model DW, check connections beetwen OWI (optical water indicator) and CB (control board), main motor, wiring, control board.
Check the foam level in the appliance. Depending what kind of detergent was used. Was the foam level too high?
Comment: Washing tabs combined with short washing cycles can produce too high foam level.
Dado
Jun 17, 2015 | Whirlpool Dishwashers
Error 8 light on. I think all lights flash, then far right light stays on. Recently had issues with it. Not emptying properly. How do I fix it??
6. Troubleshooting
In case of a malfunction, the dishwasher will identify the program by switching on a combination of lights.
When an alrm is present, all the PROGRAMS lights (4) come on, while the PROGRAM PHASES lights (7) identify the error code:
E2
The system which limits the water level inside the dishwasher (safety unit) has been tripped.
E3
The appliance is not able to pump out the water.
E4
Temperature sensor disconnected.
E5
The appliance is not able to take in water.
E6
The appliance is not able to pump out the water from the tank.
E7
The appliance is not able to measure the amount of water loaded accurately (on models with turbine flow-regulator only).
E8
Anomaly in the system which distributes water to the basket (where installed).
56
CODE
E9
PHASES LIGHTS
DESCRIPTION
E1
The anti-flooding system (if installed) has been tripped.
The maximum level of water for loading has been exceeded (on models
Jun 02, 2015 | Smeg 18 in. DWD409SS Built-in Dishwasher
Error 8 . How do I rectify it?
6. Troubleshooting
E2
E3
E4
E5
E6
E7
E8
56
CODE
E9
PHASES LIGHTS
DESCRIPTION
E1
Thjere is something wrong with the distribution. Check for blockages.
My candy CDI45 is not working, it just keeps beeping and saying E2. Any tips on getting it working again would make me a happy lady again.
Hi.
E2 is called water safety level error. Unfortunately the problem is often caused by either a defective pressure switch or by a defective control board. The problem is quite common in SMEG built dishwashers like your Candy.
All you can do is disconnecting power for a couple of minutes, by either tripping circuit breaker or disconnecting power cord. That will reset control module. While power is off remove water (if any) from the bottom of the appliance.
If that does not do the job the parts must be tested and the appliance must be repaired replacing defective part.
Regards.
Ginko
Aug 18, 2011 | Dishwashers
Du1055xtsd2 whirlpool dishwasher runs but doesn't fill with water doesnt cycle
A few things could be wrong.
It can't cycle without water. be sure you have water at the valve under the dishwasher. You should be able to see it by dropping the front plate under the DW.
If you have water pressure, then check for voltage (120) at the valve with the timer calling for water. ( start of cycle).
If you have voltage and pressure, replace the valve.
If you don't have voltage, it could be the little switch inside the DW. It pulls up and down. The level switch could be bad.
If that doesn't do it, it may be the timer or the door lock interface.
Good luck.
Oct 13, 2010 | Whirlpool 24 in. DU1055XTPS Stainless...
My smeg dishwasher stopped during a cycle and warning lights E2 come on. suggesting that it has drawn too much water and to contact customer technical services, any idea what i need to do
E2 shows that the water level switch has been tripped or its faulty,interupt the programm and switch off the dishwasher then switch it on ,programm it again and start the washing cycle again,if the problem persist then test the water level switch for possible replacement
Jan 10, 2010 | Smeg Dishwashers
E1 fault code Dishwasher runs for about 5 minutes. Water fills up at bottom of unit and then machine seems to pause then fault code E1 appears then water is pumped out from bottom of machine. There are...
I think both the heater and thermostat / trip switches need to be checked.
If water is going in and out ok, then it seems to be waiting to heat the water. It sees a fault - so just clears out.
Heating elements do fail after a few years.
Aug 05, 2009 | Dishwashers
HOTPOINT FDW60P DISHWASHER
There is usually a float switch inside the DW body. Usually a polystyrene lump. This may be stuck in the up position, or a pool of water may still exist within the case.
When you say trips the electric - is this your wall MCB or ELCB ? If it is that then there is a major electrical fault on this machine that needs investigation.
Jun 11, 2008 | Zanussi 24 in. DE6744 Free-Standing...
Bosch
f is fill fault to much or not enough water or water in the sump white plastic base the f code will not go away until you solve the problem when the f code shows up the drain motor will run all of the time
Apr 01, 2006 | Bosch 24 in. SHU6802UC / SHU6806UC...
Smeg 24 in. DWD612SS Built-in Dishwasher Logo
339 people viewed this question
Top Smeg Dishwashers Experts
Starnley Johnwells
Starnley Johnwells
Are you a Smeg Dishwasher Expert? Answer questions, earn points and help others
