Question about Kitchen Ranges
I own a Saeco Royal Cappuccino. Quite suddenly the frothing attachment has stopped drawing the milk up through the tube to froth it. There is a little steam. Also the water/steam wand is not at it's usual pressure.Any suggestions would be most helpful.
  • edwinrendall Dec 02, 2008
    It is TYPE SUP 016
    Genius:
  • 1,239 Answers
If you try to make a cup of coffee, hold the button to see if there will comes some coffee, it can be the memory that have loose the settings. If so you have to program the machine again.
THANK YOU.....
Posted on Dec 02, 2008
  • ABHISHEK.C
    ABHISHEK.C Dec 02, 2008
    ANOTHER SUGGESTION
    Make sure the magnet in the water tank flow up when you fill it with warter.
    Genius:
  • 1,142 Answers
He machine takes a little setting up to get the right grind and after that
it will give you an acceptable "short" pull espresso most of the time. It
occassionally dumps unbrewed grounds right thru for some inexplicable reason
but after that is usually OK
The steaming wand works pretty well with the "cappuccinatore" fitted also.
The only real problem I have had with either machine after 3 years is on the
steaming wand attachment - the gaskets wore thru last month. Also I think
the grinder burrs ahve virtually had it, but it has done a lot of service
first
Cleaning is pretty good also as you can just dismantle the bolt in bits and
put all thru a dishwasher once a week.
  • 734 Answers
What is the model number?
  • futureloginn
    futureloginn Dec 02, 2008
    Try to make a cup of water(tea), press the button for water.
    On the old Royal Cappuccino that are the button on the right down corner and the new machine had it on the upper right corner.
  • futureloginn
    futureloginn Dec 10, 2008
    thanks
Our exprelia will not froth milk. It only sputters milk out when we try to make a cappacino
Arrange with Saeco to send it in for replacement under warranty, rather than repair.
Oct 20, 2017 | Saeco Exprelia Automatic Espresso Machine
Milk frothing is very poor. I have had the machine for 7months and at the moment the frothing has stopped and milk is warm not hot. I have tried to adjust the frothing with the white wheel bu it doesnt...
Hi. Have you removed the white wheel and tried to clean it? Check the O-rings on the frothing part for damages.
Sometimes cleaning it hasnt helped at all, The solution for it that might sound crazy =) that fixed it for me at that time was to block the 2 holes with you fingers(be carefull its hot) where the milk comes out from when you make coffee, you get a little backpressure in the milk circuit when doing it. Try 2 or more times. It helpt me.
Oct 18, 2010 | Saeco Primea Cappuccino Touch Plus Coffee...
Why won't my starbucks serina froth milk. Just stopped doing this all of a sudden. I descaled, the little hole in wand isn't blocked. The milk heats but no froth.
This problem developed on my Sirena machine about a week ago. Stopped frothing milk, but still produced lots of steam. In fact, it was splattering milk everywhere, just not producing foam. Cleaned the steam wand (including air intake) and descaled the machine (even though its only 3 months old) to no avail. Called Saeco customer support (1-800-933-7876) and the very helpful rep immediately identified the problem. Inside the Panarello steam wand is a removable plastic tube. The tip of this tube should protrude about 1/8" beyond the end of the steam wand. Mine was not. Using the eraser end of a pencil, I pushed the inner tube downward into position and, voila, I now have froth again.
Nov 23, 2009 | Saeco Starbucks Sirena Espresso Machine
My machine will not froth milk
Nov 01, 2009 | Saeco Starbucks Sirena Espresso Machine
Cappucinatore won't pull milk through the tube
Hi
There should be a small pin on the top of the Cappuccinator. When it starts, twist the pin slowly until the milk flows up the tube. Then leave it where it is and it will work all the time.
Jul 09, 2009 | Saeco Royal Professional Espresso Machine
I have a Delonghi Magnifica Rialto EAM4500 coffee maker. Recently it has stopped frothing milk. Per delonghi I have replaced all of the gaskets that connect between the milk container and the unit. When we...
I purchased a unit second hand for my wife's birthday today. It's only 4 months old, got it home, tested it, same problem... No froth!
I've read all the posts here and all were very helpful troubleshooting guides however they did not solve the issue.
Understanding how the frothing mechanism functions is half the battle in figuring out the solution. It's a simple vacuum type system. No doubt you've read about checking the orings. This is definately the first thing to check however if this is not the reason then consider the following.
The larger of the white tubes that has the red and black oring inserts deep into its port on the tap. Why? It pushes steam past the milk pipe directly into the chrome frothing tube which causes a vacuum essentially drawing milk up it's hose creating the froth. What you can't see without further investigation is that on the underside of the tube centered between the red and black orings is a small hole. This hole is responsible for drawing the milk upwards. If this is blocked, and it probably is then no milk and no froth. Use a really small screwdriver to carefully clean the white tube both from the front and the little hole underneath.
So in conclusion. Any air leak between the red and black orings will prevent the vacuum required to draw milk up the tube and alternatively any blockage of the milk channel will also obviously prevent the flow into the frothing mechanism. Hope this helps.
Apr 09, 2009 | DeLonghi Coffee Makers & Espresso Machines
Saeco Talea Ring Plus not frothing milk
per il milk island asciugare bene la valvolina e tutti i fori del blocco di plastica che fa da montalatte devono essere perfettamente asciutti dare dei colpetti alla valvola per fare uscire eventuale acqua all interno.
MORENO
Feb 20, 2009 | Saeco Talea Ring Plus Espresso Maker with...
The mahine does not froth the milk properly anymore
alisha165,
the saeco royal digital dosn't froth milk.... it produces steam, you are the one that froths the milk. is the machine still producing steam? if not you will need to have your steam boiler replaced. This should only be dune by a qualified repairer. If it is still producing steam but it is not as good as it use to be, descalling you machine may help.
Sep 29, 2008 | Saeco Royal Digital Plus Coffee...
Kitchen Ranges Logo
46 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
