Computers & Internet Logo
Jessica Pope Posted on Jun 18, 2012
My acer 1 netbook wont start back up after trying to do updates
I turned it on this morning and it shut down to do updates and when it went to start back up it stayed on a black screen with one blinking underscore on it. I dont know what to do to turn it on. someone please help me D: i just got it a year ago
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jun 18, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
52
Points
Format your drive in which windows is loaded and then load windows a different drive (D or E or F etc) it will work and after re instalation windows disable windows update from control panel (control panel then system and security then windows update then turn automatic update on or off then select never check for update) and apply
5 Related Answers
Tequella Chapman
  • 9 Answers
  • Posted on May 09, 2008
SOURCE: Toshina Satellite A135-S4527 Bios update, Problem after
Tyr this, turn your computer and just use your keys to select the control panel. 2 go into devices and see if your mouse is installed if the show s that your mouse is on there. Please select the mouse to refresh it. 3 Go back to the start menu shut down the computer for 2min the turn on strike the F12 key I believe and see if your mouse is installed.
cpenzes
DEKR
  • 1102 Answers
  • Posted on Jan 13, 2009
SOURCE: Acer Aspire 5920 will not start up either in safe mode or normal
IF YOU DON'T NEED ANYTHING ON YOUR PC YOU CAN FORMAT IT WITH YOUR WINDOWS OR RECOVERY CD
SOUNDS LIKE YOU MAY HAVE ALREADY LOST FILES
LET ME KNOW HOW THIS WORKS
Anonymous
  • 3940 Answers
  • Posted on Jan 31, 2009
SOURCE: A hard disk problem is preventing windows from starting.
The black screen with flashing cursor can be caused by the files needed to boot being located in sectors of the hard drive that can no longer be read.
You can try booting to the XP CD, and go to recovery console and RUN CHKDSK /F See if that fixes the file structure and allows the system to boot. If that fails, you can try a repair installation of Windows. If that fails, the most likely resolution is replacing the HDD and reloading Windows and the drivers.
Anonymous
  • 70 Answers
  • Posted on May 10, 2009
SOURCE: Need to restore to factory default but my lappy gives me a blank black screen with a blinking underscore on the top left of the screen.
There might be one step you could try to restore the system to factory specifications. When you turn the laptop on, and you see the Acer splash screen, press the Alt-F10 keys together at the same time, and this should hopefully bring the Acer eRecovery system up, provided that your computer has the built-in recovery partition. If it asks for a password, try using the default of "000000". If that doesn't work, then a password has been entered into the system, and there is no way to reset it, however there is a way to find out what the password is, however it does require the use of the Ubuntu Operating System (which is free to download, here)
Anonymous
  • 7 Answers
  • Posted on Jul 18, 2010
SOURCE: Acer Aspire One Netbook 8.9' Won't Boot Up !!!
The Acer Aspire One has a built-in BIOS recovery routine, which can boot into a minimal BIOS environment via a special boot block to re-flash the BIOS, even if the system does not pass POST and does otherwise not boot anymore. This is also known as crisis disk mode.
First format an USB flash drive with FAT. It does not need to be bootable.
Download the latest BIOS, and extract all files from the zip file. Put both FLASHIT.EXE and the BIOS file with FD suffix in the root directory of the flash drive. The files must not be in a folder. Rename the BIOS file to ZG5IA32.FD before proceeding. It only works with this exact filename.
Turn the AA1 off, with the flash drive still connected, and make sure both battery and AC adapter are also connected.
Press Fn and Esc simultaneously, keep them pressed and press the power button. Release Fn+Esc after a few seconds. The power button starts blinking at this point. Press the power button once. The AA1 will now initiate flashing the BIOS. After a while the button stops blinking, and the AA1 reboots shortly after. Wait patiently.
If it doesn't reboot by itself, but keeps blinking, wait at least a few minutes before turning it off, and try again.
Memory leak
First replace the CMOS battery. Question: When you turn it off, are you shutting down with the Start Menu RESTART, shut down? OR pushing the on/off button. If you post the Acer Model and the OS you are using it would be helpful. Is the Battery in the laptop? Is it charging?
It wont even turn on all the way
One easy solution is to remove your batery pack for at least ten seconds, replace, fully charge, then restart your computer
Acer Aspire One Netbook wont start
i had the same problem, but when i clicked skip file it continued any way... the update installed could of moved a necessary file or folder and now your recovery portion is ruined. i recommend contacting acer through there website. hope this helps
2answers
Acer 110 boot problems
This could majorly happen because of sp3 conflict with one of your hardware drivers
log in into safe mode and rollback the last software or hardware driver update
2answers
Hi there, I bought an Acer Aspire One netbook two days ago. That evening I installed AVG anti virus and Online Armor. Everything seemed to be working fine. I shut the netbook down. Yesterday evening I...
yeah I'll give you the best suggesstion since you have just bought your acer notebook take it back to the store and have them re-installl windows for you,since its just been two days they will do anything for you
Black screen on startup!
By the sounds of it you've install an update that could have gone wrong. i'm not sure if it's the same with all acers but it might be keep pressing F8 and try logging into windows via through safemode if you can't do this then you could have corrupted some stuff on the motherboard and i would contact Acer customer support
Sony vaio boot up in normal mode
boot to the repair partition and reinstall windows it sounds like a registry problem reinstalling should fix
Laptop worked fine the other night went to shut it down and it then said that an update was needed before it turned off so it done that and then turned itself off.went to turn it back on the next morning...
boot up computer and as screen starts up keep tapping F8 to go into safe mode and then go to system restore and restore to a date before the update and it should work for you ..... it may have not been a real update or it just didnt load right / larryyb
Cannot start up my laptop since in done an update
Try booting into "Last known good configuration" it is on the same screen as Safe Mode, if that does not work, you can try to run CHKDSK /r from the windows install CD, just choose "Repair" in the option, if this does not work I suggest removing that hard drive and slaving it into another computer to get your data off and then reload Windows onto it. It is missing a .dll
Acer Laptop Vista service packs 1-3
remove power supply nd battery, should allow you normal boot up.
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
