Question about HP T5300 (dc643a#abu) Network Terminal
Out of Range message on monitor after T5300 finished booting. No Image.
When you turn on the T5300 the HP boot screen appears on the monitor and when it is done booting a message displays on the screen "Out of Range" and you get no video. I tried booting into setup and setting factory defaults and it didn't change anything. I am wondering if this device is worth fixing, can a person buy just the inside box and reuse the case?
  • Patty Guden Jan 31, 2007
    How do you change this setting on a T5300.
    President:
  • 2,961 Answers
The out of range refers to the screen resolution size of your pc as apposed to the monitor. It is unable to operate at the set refresh rate and screen res.
Posted on Jan 31, 2007
SOURCE:
My monitor shows image immediately when switched on but just as soon the image appears the screen of the monitor goes dark after that need to off/on the power switch three to four times before the image...
Please restart your computer and tap the F8 key as soon as you see something on the screen. You should get the advanced boot menu. Select Safe Mode from the list.
Let me know if you were able to boot to safe mode.
Jun 18, 2010 | Dell E193FP 19" LCD Monitor
In the middle of my screen a blue box is showing and in it this reads OUT OF RANGE H. FREQUENCY 68.7 KHz V. FREQUENCY 85.0Hz What does this mean and how can I fix it this was a gift...
That message appears when the Windoze display settings exceed the monitor capabilities. If you will boot into windoze safe mode (F8 at boot) and correct the display settings, the message should clear at the next boot. Afterwards you can right click on the desktop and access the display settings to make final adjustments.
In your case, the refresh rate (V Frequency) should not exceed 70 Hz
Nov 23, 2009 | Envision H22W 22" Monitor
At boot time appears message 'Device Monitor Appliaction (mispell
try this:
1. download combofix and follow his steps (don not agree with recovery console)
link is here : http://www.combofixdownload.com/
notify me if problem is resolved
Jun 28, 2009 | HP Computers & Internet
Solution for "my laptoop seems to want to boot but when is is done booting the screen turns black and remains that"
If the laptop appears to boot up and you can't see an image on the screen, you need to determine if the screen is faulty or the video card.
Connect an external monitor to the laptop's external video port, power up the monitor first and then boot up the laprop. If you get a normal video image on the monitor then the video card is OK and the fault is with the LCD screen.
If you don't get an image or POST information, then the LCD screen could be faulty or the laptop didn't boot up.
Please get back to me with the results of your tests and any error messages etc. so I can advise further.
Jun 18, 2009 | Acer Aspire 3680 Laptop
My ViewSonic computer monitor keeps displaying a Vga Not Support Message upon booting then the message Out Of Range comes up on a completely dark screen. Need Help
It sounds like the computer is trying to use a resolution that the monitor cannot handle. Boot into safe mode by pressing the f8 key during boot up and select safe mode. Once booted, right click on the desktop and select properties. In settings lower the resolution by moving the bar to the left and reboot.
I would move it all the way down, you can then move it up a step at a time once you are in normal mode again.
Hope this helps
May 02, 2009 | ViewSonic VA721 17" LCD Monitor
Gateway FPD1530 loses image shortly after powering up.
try booting into safe mode. press F8 while the computer is booting. see if everything stays normal. It should tell you that it booted into safe mode. Once there, change the resolution or the frequency of the display(also known as the refresh rate) by right clicking on the desktop and selecting properties. Once there, click the tab all the way to the right, it should give you color quality options and resolution options. At the bottom, there should be an advanced tab. Depending on our video card this menu can be different from others. Look in that new window for and option to change the refresh rate or the frequency. The value will be in xxx hertz. try setting it to 60 hertz.
Jan 31, 2009 | Computers & Internet
Monitor won't stay on. Error message comes up that says "no input signal", then monitor goes out.
Problem with the monitor, monitor cable, or video output. For monitor, if you have more than one input, make sure it's set to the correct one. Try a different cable. Try a different monitor. Check your video card settings--if you see the BIOS bootup screen while it's coming up then the Windows splash screen, then monitor blanks out, it's a Windows display setting. Boot into safe mode, then change settings--
  • Turn the computer on or Restart the computer
  • Start tapping the F8 key. The Windows Advanced Boot Options Menu appears. If you begin tapping the F8 key too soon, some computers display a "keyboard error" message. To resolve this, restart the computer and try again.
  • Ensure that the Safe mode option is selected (the top option)
  • Press Enter. The computer then begins to start in Safe mode.
  • When you are finished with troubleshooting, close all programs and restart the computer as you normally would.
Oct 31, 2008 | HP Computers & Internet
Input Signal Out of Range
I have been having the same problem with my hpvs17 monitor when i start to use my web browser on linux distros. Now, for the next few days i am going to try my system on a regular crt monitor. if the monitor does not crash, than i will have to say that the hpvs17 monitor has a defect.It seems that when i go online, while i am in the middle of searching something, the monitor just shuts off and i get "input signal out of range".
Jan 31, 2008 | HP Vs17 17" LCD Flat Panel Monitor
Input Signal Out Of Range
Some monitors have low resolution, that if it doesn't support that resolution then you'll expect an "input signal out of range" message on screen. try to boot on "safe mode" if it works then you have to lower your screen resolution at "display properties" if not then the monitor has a defective data cable. ;)
Oct 30, 2007 | HP Pavilion F1523 15" LCD Monitor
No image on screen when boot up computer
check vga cable! check also video card on the pc!
Aug 16, 2007 | LG Flatron L1710S 17" LCD Monitor
HP T5300 (dc643a#abu) Network Terminal Logo
446 people viewed this question
Top HP Computers & Internet Experts
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
