Question about RCA F32450 32" TV
Acess service mode rca ctc197cw
How to access service to adjust vertical size.
  • 121 Answers
Hold menu button in. push power button once. push vol up once.
Posted on Dec 03, 2008
How do I adjust the Vertical size or position?
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
NB: Please read and understand well, the instructions to enter the service mode, before you begin. Be very careful. Note how to "EXIT" the service mode; after entering and adjusting data. This is very important.
Search the site by type in the "brand name" to your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Apr 23, 2016 | Zenith SY2765S TV
Tip
SERVICE MODE AND ADJUSTMENTS
Accessing Self Diagnostic Menu
1. While LCD TV set is on standby mode, press the following
sequence on the Remote Commander key. (RM-GD020)
For more check the following link. Use the search tab on the top right corner on the page to find your product.
www.electro-medical.blogspot.com
google.com/+AjinGopakumar
on Feb 18, 2015 | Sony Kdl-32cx520 32" Full Hd Multi-system...
Zenith TV B27A24Z, Vert Size Adjust
To do this adjustment, you should enter the service mode option. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Feb 27, 2014 | Zenith Televison & Video
How to adjust vertical size my hitachi c29-r30sp
You could go into the user menu and look around to see if it has an adjustment. If not you will have to access the service menu for your tv. There may be a setting to adjust vertical size there. If that still isn't possible you may have to open the tv and look for a pot or a switch that can control the vertical adjustment. It may be by the vertical output circuitry. This could also mean that you have a defective component in the vertical circuit or inadequate voltage to that circuit.
Mar 11, 2010 | RCA F27440 27" TV
Picture is cut off on the bottom of my Hitachi 57F500
Verical position is hard to adjust and is in service menu. A service manual will get you there, but you might get lucky with the vertical size adjustment. If you open the front of the TV, the vertical size is adjusted with a knob on the deflection board. Remove the speaker grille and take off the access panel. You will see two knobs, one horizontal and one vertical. Be careful, those red wires have 30,000 volts on then, don't touch anything but those knobs. If its just an adjustment, the v-size knob will fix. Set it so ESPN ticker is just above the bottom of the screen. *Service mode - the manual tells little but entering is done by "press and hold the input button, press the power button, release both after you hear HV come up" .. the v-pos parameter is in there, but this manual doesn't say where or how to adjust, procede at your own risk. If you get into trouble, pull the power so you don't save any settings. I believe you just navigate through the menus to find the parameter and use arrows to adjust. Enter may save. Sorry the service manual I have tells nothing much.
Dec 07, 2008 | Hitachi 57F500 57" Rear Projection...
Vertical Stretch
You need to adjust "vertical height" in the service program. You need to put the set in "service mode" to do this adjustment. If you google "enter service mode RCA F32665" you should find the procedure. It will be listed in abbreviated letters such as VERT SIZE or VERT HT. Follow the instructions for entering service mode and saving the data closely!! The data you change will be listed as a number between 1 and 63. The number will only need to reduced by a small amount and you can still see the picture behind the data and watch it shrink as you adjust the number down.Always burn the new number to memory (if required) before exiting service mode. Good luck
barneyluc
Dec 01, 2008 | RCA F32665 32" TV
RCA 32" TV
Many RCA's use the following to gain access:
Hold the 'Menu' button while turning the set on.
The code may also be inside the back cover.
Feb 20, 2008 | RCA F32650 32" TV
Service mode
To enter service mode, push and hold the [Menu] button on the set. While holding, push and release the [Power] button, then the [Vol +] button.
You will now have some information on the screen: "P0 V0"
To actually be able to change these values, you must push [Vol +] on the remote so the information reads V76. Then pushing on the Channel +/- will change the "P" value.
P1 - 3 are error codes. If there is a problem with the set that can be self-diagnosed, the "V" will report the code. These codes are available in the RCA repair manual.
P4 - 7 control the horizontal size, shift, vertical size and shift.
You may also find a summary leaflet for the service tech clipped somewhere inside the chassis. The procedures for getting into the service mode, as well as the service items of interest will be there.
If you're attempting to adjust color or geometry errors, you'll need the Video Essentials DVD, Laser Disc or some other source of test material.
Dec 11, 2007 | RCA P46812BL 46" Rear Projection...
Image adjustment for GE 24GP65
Yes you can adjust the vertical size in the service menu, but you must be carefull when doing any horizonal adjustment as this can shut down your set .
Dec 16, 2006 | GE 24GP653 24" TV
Need access to service menu to adjust vertical size
No service menu for this set. Sounds like you have a bad yoke winding on this one....accordianman
Oct 25, 2006 | Emerson SpongeBob SquarePants TV
RCA F32450 32" TV Logo
100 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
