Question about Dell Latitude D505 Notebook
Dell laptop wireless wont work - Dell Latitude D505 Notebook
  • Dapid Candra
    Dapid Candra May 11, 2010
    Do you have the wireless device?
  • 49 Answers
Make sure you have a wireless card installed. It's either under the keyboard or an access panel in the bottom plastics. If you don't have one, you can get one off ebay. They're not that expensive.
If you do have one, go into the BIOS and make sure it is activated.
Posted on Dec 30, 2008
DELL Studio 1537 intermitently disconnects from my wireless network then wont find my network but finds several others in my neighborhood that are far away or says no wireless networks available. My other...
Your signal probly getin week at times ,,walls weaken wifi,,,and if other computers goin on same wifi,,a stronger cpu,,like a desktop or so,,stronger cpu will hog all wifi from the weaker one,,,also try dell website fro driver updates
Nov 04, 2010 | Dell Studio 1537 Laptop
My dell inspiron 1545 wont connect to linsys-g
Your laptop may have a pre-defined Ip address locked in for your work connection. Did your buddy use the laptop at your place of employment, or was it used at his home? Sometimes an ip is entered manually in the tcp/ip menu locking it to a certain address. To check this opem metwork connections in control panel and right click your wireless device then choose properties and left click. Scroll to the TCP/IP line and go to properties. Make sure everything thereis set to automatic.
Mar 13, 2010 | Dell Inspiron 1545 Notebook
Wont connect to belkin 54g with wpa security applied
Please try using Wireless 'G' mode only in the router. Also, try using 'TKIP' and not TKIP+AES for encryption.
Please rate this solution, if it works for you.
Jun 01, 2009 | Dell Inspiron 6400 Notebook
Wireless Internet wont work unless I plug in a wire
QuickSet utility Wireless options can cause these issues.
There is a setting to always deactivate on battery. Make sure this is not set up. The correct setting would be Always active on battery or Always On, or no power saving options for Wi-Fi. Depending on the version of QuickSet which you have.
Apr 21, 2009 | Dell Inspiron 1525 Laptop
Wlan not working on dell vostro 1000
Try disable, then re-enable the driver, if still no luck, try to locate the wireless adapters properties an check to see if all is in order, ch, SSID, everything must match to the wireless signal. (by the way where is the signal coming from ?) your router ? or else where ?
Apr 15, 2009 | Dell Vostro 1000 Notebook
Problem maintaining wireless signal
Changing channel wont help,you should use specific ip setting then automatic ip setting
Jan 19, 2009 | Dell TrueMobile 1184 Wireless Broadband...
Sounds as though theres no power getting to the card if theres no light on it - the dell 6XX series has a weakness in the PCMCIA connector too - it can easily flex and seperate from the socket on the motherboard over time and especially in transit. I wouldnt suggest trying to fix it yourself but dell will send someone out to fix it if its under warranty or for a small fee if not. hope this helps
Sep 30, 2008 | Dell Latitude C610 Notebook
Dell Inspiron 1526 wireless
Usually this is a driver problem, in which you have the wrong driver trying to configure the wireless. Some wireless drivers and cards are so similar that they will install and either show and network but won't connect, or show the card working but won't see the network. Take the cover off the bottom and get the make and model of the card, then find the right driver either at Dell's support site or Dell uses several different wireless cards and checking the make and model of the card is the only sure way of knowing you have the correct driver.
Jul 06, 2008 | Computers & Internet
I didnt understand the solution for the router not working on vista
Try hitting <Fn> + <F2> keys on keyboard. If that doesn;t work click Start > Run > type devmgmt.msc > check device manager for your wireless adapter properties --- is it working properly?
Jun 26, 2008 | Dell TrueMobile 1184 Wireless Broadband...
Dell Latitude D505 Notebook Logo
166 people viewed this question
Alun Cox
