Question about HP Compaq Presario V2000 Notebook
Clicking noise at startup, computer crashes/freezes
Can't find system 32 message, then dumps physical memory. have restored system and same problem persists. Please HELP!
    Problem Solver:
  • 18 Answers
Well man seems you lost files of system 32 folder. try formating then re installin ur OS
Posted on Dec 02, 2008
I am using nComputing L230 Terminal but when I log in from the terminal, the windows and all related applications crash with exception code c0000005.
Uninstall your vSpace software, reboot, download and run their cleanup utility located at www.nc-eng.com/tools/ncuninstall.exe. Apply ALL MS service packs. Verify that no device drivers are missing or conflicting. Logon/logoff to the host and confirm proper functionality. Enable the Windows Startup/Recovery to capture a memory dump. This is done by the following steps: Right click on My Computer ' Properties ' Advanced Tab ' Startup and Recovery, Settings Button, Make sure Kernel Memory dump is selected. From there you can analyze the crash dump. Additionally, to help us, providing the complete hex code when the system crashes would help. Also, you never indicated what OS you're on or what version of vSapce you're using. All this is necessary to help you further.
May 18, 2011 | NComputing L230 Network Terminal
Hi, my windows XP pro is no longer runing. i end up with a physical memory dump Screen. But no longer open on my desktop PC screen.
Download Malwarebytes from filehippo.com and run on both computers in safe mode
Go to start and right click on my computer click on properties and then advanced then startup and recovery click settings. Where it says write debugging info click(small memory dump (64kb)
Jun 27, 2010 | Microsoft Windows XP Professional Full...
I have PC Chips M925 v 1.1A, Chipset Via P4m 266. It had only SDRAM 384 MB and I changed by a Kingston PC 2300 1GB and opened the jumper for the DIMM voltage and it works, and faster. But I also have more...
changing ram is good to make your computer more faster but sometomes it do cause harm, before you change your system was working fine, but you have already upgrade to a higher ram but now you recieve more crashes unlike before, may its time to re install your windows or have it reformated sudden changes in a computer hardware cause these problems this is incompatibility issues between the hardware and software that causes these problems to appear
michael
Nov 19, 2009 | PC Chips (M925G) Motherboard
Got Blue screen, and now my computer won't load
probably ur system's software is corrupted or ram is faulty..proceed with the following step(s) only if u r a professional..
1)replace the ram with a standby n see..
2)reinstall os..
3)also check for defective capacitors(esp above 1000mfd) & mosfets & the circuitry around the South Bridge on the main/mother board..
the above often take place with some error message(s)/blue screen..
but if there's no such displaying, esp if hangs/stops/power off during installation..
assuming that u r using ram(s) more than 512mb(recommened) or atleast 256mb..and hv enough free hdd space..
i don't know which version of os u r using..
howevr, install an updated n licensed antivirus (i prefer avg/kaspersky)..go for a through system scan..
try increase the size of virtual memory: start menu->run->type 'sysdm.cpl'->click 'advanced'->click on the 'settings' submit button under 'performance'->click 'advanced' tab->here u'll find 'virtual memory', click 'change'->select c: from the list->type the 'initial size': 1440 and maximum size: '2880'->click 'set'->ok->ok..donot restart the pc now..hv aglance ovr the software strength..look for startup items (the programsloaded during startup)..download n install n run 'Statup ControlPanel'..
http://www.pcworld.com/downloads/file/fid,7976-order,4-c,desktop/description.html
andmicrosoft kb890830..remove the unnecessary boot item(s) or do post me acomplete list of startup item that the Startup CPL is showing (in itzevery tab), i'll guide u..
also u may use 'Advanced System Care Pro' to fix all at a time..now restart the pc..
seek professional supervision of ur system admin/vendor....
Oct 31, 2009 | Alienware PC Systems Alienware Aurora High...
System crash after upgraing memory for acer aspire 4315
If u have 2 ram in 1 computer memoryh frequence
conflict betwwen each other if both r differ.
So cheange yhour ram and check both rammeoroy frequence are same .
Mar 26, 2009 | Acer Aspire 4315 Notebook
Physical memory dumped
to fix this problem, try the below steps. 1. as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key. one you reach the dektop..run a system restore if this as started happening recently. you can run system restore which will bring the computer back to an earlier time lets say few days back with the help of selecting the date in the calender in the system restore tool. To go into system restore tool click on start select accessories and the system tools and then system restore. Select restore my computer to an earlier time and click the date in the calender box once highlighted hit next and wait till the process completes once completed it will restart the system automatically and will give you a message your computer was restored successfully in case it says not restored then you can select another Bold date i mean a previous date to retry again.
2. boot to safe mode and folow the below steps: Edit the registry: Start then Run and type "regedit" Go to HKEY_LOCAL_MACHINE \ SYSTEM \ CurrentControlSet \ Control \ Session Manager \ Memory *Management and double click the DisablePagingExecutive value and enter value 1. Go to HKEY_LOCAL_MACHINE \ SYSTEM \ CurrentControlSet \ Control \ Session Manager\ Memory Management, double click on the Largesystemcache value and enter 1 as value to increase the size of the hard disk cache
please let me know if this helps. else we need to repair the os and will let u know the steps if this does not work.
Mar 23, 2009 | HP 285527-001 - Compaq Presario...
Intermittent bsod on system
right click my computer then properties then advanced
then system startup system failure settings
Jan 23, 2009 | Microsoft Windows XP Professional for PC
2 problems in one
Depending on what operating system you are using, I suggest repairing the operating system. For windows xp here is a guide that you can follow http://www.michaelstevenstech.com/XPrepairinstall.htm.
For windows vista
http://www.bleepingcomputer.com/tutorials/tutorial148.html
Apr 16, 2008 | Acer Aspire 3680 Laptop
Blue Screen Error Message
Your hard drive crashed. You need to buy a new hard drive and restore your computer using the restore disks. You can buy a hard drive here: http://www.interproshop.com/commerce/catalog/product.jsp?product_id=13055&czuid=1167865660865 They also sell larger hard drives. If you dont have a restore disk, you'll need to contact HP and they'll send you one. http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=423721&lc=en&cc=us&dlc=en&submit.y=9&submit.x=8&lang=en&cc=us
Jul 14, 2007 | HP Pavilion Ze4805us Notebook
HP Compaq Presario V2000 Notebook Logo
219 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
