Benq power supply "short"?
Many thanks for your prompt advice. Unfortunately it's one month out of warranty!
Don Barrett
  • 4,806 Answers
If you can extend the warranty do so, wait about 2 weeks then take it back
Fixed Pc for the price of the extended warranty!!
regards
Posted on Dec 02, 2008
No power
Hi bigbuck17,
Here are some basic steps that will help you fixing the problem.
I'm assuming that your unit is dead set without an standby LED light and your outlet is live.1.Power cord - check the cord it might be opened (no continuity).This is due to frequent bending,pulling. 2. Power switch - check for dry joints, open contact. 3.Check the internal fuse- sometimes the fuse fail because of the power surge, replacing with new one will cure the problem, If this is the case I would advice you to use surge protector/AVR (Automatic Voltage Regulator). However if the fuse blew again this is an indication that you have a shorted parts in the power supply, you may visit the linkhttp://www.fixya.com/support/r8053361-fuse_keeps_blowing for more info. If no reaction and still the unit didn't power up then you have an open parts on the power supply.
4.If you see that the fuse is intact , don't attempt to touch anything because there some fatalcomponents stored electricity enough to hurt you with a simple mistake only. I would advice you to look for a professional to troubleshoot the power supply. If you want to repair it yourself make sure that you have necessary tools and test instrument. First check bad solder joints(re-solder all cold solder), leaky electrolytic capacitor(sometimes it has bulged at the top but not all, you better have a capacitor checker), open/shorted regulator transistor/IC(mounted in heat sink), open fusible resistor (caused by shorted regulator Transistor/IC), shorted zener diode.
You may also replace the entire power supply board.
Also check if your unit is under warranty before opening the back panel, it will void the warranty. Avail it because the manufacturer of your unit will fix it for free or a little charge only.
Hope I helped you.
Have a nice day!
Thanks for using fixya.
Jun 01, 2011 | Element Electronics FLX-2210 22 in. LCD...
No power
Hope I helped you.
Have a nice day!
May 22, 2011 | Televison & Video
It keeps swtching off
Hi Anthon,
This is an indication of out-of-regulation in the power supply section. The very common caused of this fault is the dried/leaky electrolytic capacitor in that section. It will drop the supply from normal voltage and will disable the unit. Sometimes it has a bulged/dome at the top but not all, it is better that you have a capacitor checker/tester to determine its condition. Also, bad solder joints can produce the same symptom, it is hard to spot, you should use table lamp/portable lamp for finding the cold solder. Another reason of the symptoms is the open fuse/fusible resistor in series with the output of regulator IC/transistor, shorted/openRegulator IC/transistor, shorted zener diode(all are in the power supply section) and the microcontroller. Best that you check the output voltage of each regulator to determine where the fault came from and narrow the job.
If you don't have necessary tools and test instruments, and can't do the job yourself, I would advice you to look for a professional to troubleshoot the problem. Don't attempt to work in the power supply if you don't know the safety precaution of handling it, there some stored electricity enough to hurt you with a little mistake only.
Also check if your unit is under warranty /extended warranty, avail it because the manufacturer of your unit will fix it for free. Don't open the back panel, this will void the warranty.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
May 13, 2011 | Samsung SyncMaster 540N 15" LCD Monitor
Tv no power
You may also replace the power supply board, try online like ebay.com and shojimmy.com.
Hope I helped you.
Have a nice day!
May 11, 2011 | Televison & Video
It just is a black screen and no power light on I unplugged it and it still don't go on
Hi buda07,
You may also replace the power supply board, click this LINK.
Hope I helped you.
Have a nice day!
May 06, 2011 | Sanyo DP19649 LCD TV
No power on
Hi frankiepr37,
If you don't have necessary tools and test instrument and can't troubleshoot the symptoms yourself, I would advice you to look for an experienced technician to isolate the problem.
Hope I helped you.
Have a nice day!
May 05, 2011 | Televison & Video
There is no power
Hi ngroutides,
Hope I helped you.
Have a nice day!
Apr 26, 2011 | Televison & Video
No start ,dead
Hi alonzot,
Hope I helped you.
Have a nice day!
Apr 25, 2011 | Soyo DYLM1798 Monitor
No power
Hi r_natan,
Hope I helped you.
Have a nice day!
Apr 17, 2011 | Panasonic TH-42PD60U Television
Benq S41 power suppl ''short"?
thats what i suggested earlier, the AC adapter in the laptop has blown, thats what causing the feedback/overload. you can fix the problem yourself but it is a big job!!!
If you need the problem resolving straight away, then take it to be repaired, under warranty if its still covered by it!!
Sorry for the misunderstanding
Kind regards
Dec 02, 2008 | Computers & Internet
Computers & Internet Logo
105 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
