Question about HP OfficeJet 6210 All-In-One InkJet Printer
Paper jam my printer keeps saying there is a paper jam even though there is no paper, I have tried # 3 and that won't work any ideas
  • lytesha Dec 30, 2008
    every time i try to print something it keeps say out of paper but paper is in there whats the problem
I was having the same problem and having messed with this oh so many times and on the verge of just trashing the printer, I unplugged the printer, sat in the floor with it, turned it upside down, and gave it a BIG whack on the back. Low-and-behold, a small piece of styrofoam slide out of the cartridge carrier area. It is currently working now, for how long I don't know.
Posted on Dec 08, 2008
    President:
  • HP Master
  • 990 Answers
There have two steps to follow;
1, check through the paper path,you will find a sensor make sure it moving freely.
2, check both end of the cartridge carrier track(steel bar) you will find something stuck over there
Posted on Dec 06, 2008
Paper jam displayed but no paper jam found. Cleaned with air but this did not help. Seems like printer wants to keep resetting itself.
I had this problem and someone on Fixya solved it. Open the back cover and slide the guide slightly. If it's off center it won't work and gives you the jam message even though there's no jam. It solved it instantly.
Sep 27, 2011 | Brother MFC-7820N Printer
My printer says it has a paper jam, even though the paper jam has been cleared. It won't print. Any ideas?
Hi, Try pulling out the plug for 1 hour and then try again. Pulling the plug may reset the printer.
Good luck.
Jun 27, 2011 | HP DeskJet 3740 InkJet Printer
Paper jam
The way you describe your error, it seems that there is still some residual paper stuck inside the printer that may cause subsequent paper to be mis-aligned.
Paper jams can be tricky to solve. The paper is usually stuck inside the printer mechanism so even if there is no visible paper jam, you will still get the paper jam error. Try this:
1. Turn off your printer
2. Open all trays and remove any paper stuck there
3. Locate the button to open the printer, open it and remove any paper stuck there also.
4. Repeate the above step for all buttons that you can find to access the inside of the printer
5. Close all doors and put back all trays
6. Turn on your printer
NOTE: Please rate our help to keep this free service online.
Jan 07, 2010 | Lexmark X5150 All-In-One InkJet Printer
Turned it on and it says paper jam. There is no
Dec 22, 2009 | HP PhotoSmart C4280 Laser Printer
Paper jam on my i560
there is a small paper very small paper stuck in the printer remove it it will work
Nov 09, 2009 | Canon BubbleJet i560 InkJet Printer
Canon Pixma MP150 keeps blinking E 3 saying there is a paper jammed even though there's no paper in the printer. I found a little screw inside, could this be the problem?
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
tokio-5
Aug 02, 2009 | Canon PIXMA MP160 All-In-One InkJet...
My printer has stopped feeding the paper - It doesnt even try to do it now- and the paper jam light keeps flashing even though there is no jam. any ideas ??
Please check the paper feed motor connector, if ok then check the supply from PCB.. 12V regulator IC to be replace..
Jul 10, 2009 | HP OfficeJet Pro K8600 Printer
Paper Jam 2
Most probably you took a paper sensor out of position when removing the first jams. In your unit, the paper sensors are connected to the main board or power supply board. If the equipment is under warranty, any authorized service center will gladly replace it for free.
Oct 03, 2007 | Samsung SCX 4521F All-In-One Laser Printer
HP OfficeJet 6210 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
