Question about KitchenAid KP2671 Professional 6 Series Stand Mixer
Mixer speed switch is haunted
I have a pro5 475w mixer. It automatically raises its speed to max and then shuts off, every time you move the switch to any setting. I've replaced the switch twice, and in 20 minutes the new switch is haunted again. Sometimes the switch will go back to normal for a few minutes, and then goes right back to "auto-shift max speed-shut-off." Quite the thing to use. My mixer will only accelerate about 3 sec and then shuts off.
The likely problem is the Hall Effect sensor located on top of the motor. This sensor is used to determine the speed of the motor. Since it does not sense a speed, the motor revs to top speed and shuts down. You have to shut the switch to Off/Reset to try again. Replace the sensor which costs under $10 before replacing the speed control which costs $50.
Posted on Dec 09, 2008
  • 57 Answers
The switch is not your problem.
open the top half of the mixer and check your gears i think they are slipping
more information can be found here
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=KP2671&siteCd=KAD
Posted on Dec 02, 2008
2 Suggested Answers
  • 9 Answers
SOURCE: mixer speed switch is haunted
Here is where you can download the repair manual. Read the section on speed control adjustments and repair. This might not be difficult for someone who is mechanixcally and electrically knowledgible.
Mike H.
Posted on Mar 25, 2008
I have to go up to 3 or 4 before the mixer will start
Does the mixer operate on the lower settings once you've got it going at the higher speeds?
If so the motor mechanism may need to be serviced (cleaned). OR it could be the switch mechanism is either 'dirty' (maybe with built up flour?) or has failed and needs to be replaced.
While UNPLUGGED, move the switch back and forth from OFF to full speed many times, if you have compressed air, blow that into the slot around (top & bottom) while operating the switch.
Set to OFF, plug it in the mixer and try it.
If that doesn't fix the problem, then consider having the mixer serviced or replaced.
Nov 27, 2015 | KitchenAid KSM150PSMC Mixer
Why won't our kitchenaid stand mixer run?
He rdnowak:
I am sure #10 in the highest speed, but are you saying it will only run at #10? if so I would start by removing the cover again. Hopefully no parts are missing. Make sure the selector switch is moving things on the board if possible. I mean if you can move it with you finger you should be able to move it with the selector lever. Sorry for the trouble but I have never taken mine apart I just clean the out side. I do no this. Sometimes I must take something apart and reassemble them several times before getting them to work the way they are supposed to.
Best of luck
'RR
May 15, 2014 | KitchenAid Pro 600 Stand Mixer KP26M1X-...
The speed lever won't hold a speed
The spring attached to the speed control switch has come off or broken. Does the switch stay in one place when you move it or does the switch move about freely. I need a little more info to be more help.
Feb 23, 2013 | KitchenAid Classic Stand Mixer
I received my mixer as a gift for my birthday in October. The bowl gets stuck and does not release from the base. I have to hit it a number of times with a rubber mallet to get it to release. Also when...
If that is the bowl that came with the machine it is not wrong. What happens from time to time is that the head on the mixer automatically adjusts causing the beater to not operate as it should. To adjust the head on the mixer place a dime at the bottom of the bowl, attatch the beater to the mixer and make as if you are going to start mixing. The beater should JUST touch the dime. If it doesn't touch it at all or is pressing it against the bowl, tilt the head of the mixer up to locate the adjustment screw located inside the shaft. Take a flat head screw driver, turn the screw clockwise (to lower the head) or counter clockwise (to raise the head). Place the beater back on the mixer, turn the machine on and see if it moves the dime moves. Once it is properly adjusted the dime should move ever so slightly.
Nov 19, 2010 | KitchenAid KSM150PS Artisan Series Stand...
Mixer won't shut off
Sounds as though the switch has shorted? Or the speed controller has failed ON. You could try a replacement if one can be had?
Feb 03, 2010 | KitchenAid KSM5PS Heavy Duty Stand Mixer
My KitchenAid KSM90 will not turn off. All the speed settings seem to work, it just won't shut off. I have it open, but don't understand how the switch operates such that it turns the mixer off. The...
I determined that the switch that controls whether the mixer is on or off is controlled by a copper bar with a contact. The contact got fused to the copper bar, possibly due to a short. Since the contact got fused to the copper bar, the circuit was always connected, so the mixer was always on. The solution was to 1) unplug the mixer, and 2) take a screw driver and gently pry the contact away from the copper bar. When the mixer is in the off position, the copper bar and contact are no longer in contact. When the mixer is on, the copper bar and contact make contact. My mixer now works just fine. Yea!
Jan 28, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
The latch/switch on the speed control board is stuck
You need to take the back cover off and then split the gear cases to find the mechanical reason why the lever is stuck. Take the motor off the pedestal, remove the planetary and undo the 9 screws that hold the bottom gearcase to the top housing. You will need to unplug the white and the black wires from one side of the speed control plate.
Jun 14, 2017 | KitchenAid K45SS Classic Stand Mixer
Mike H.
Feb 07, 2008 | KitchenAid K5SS Heavy Duty Commercial...
Hard time moving from # 2 to # 3 speeds back and forth
At the risk of asking the obvious, are you aware that one must shut off this machine before going from one speed to the next?
Oct 22, 2006 | Hobart N50 Stand Mixer
KitchenAid KP2671 Professional 6 Series Stand Mixer Logo
348 people viewed this question
Top KitchenAid Food Mixers Experts
jack arons
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
