Question about Nikon Coolpix 5700 Digital Camera
"overexposure" The problem arose after I visited a botanical garden and went from cold outside weather to high temperature and humidity conditions. The next day I found that the image through the viewfinder and lens appeared vastly overexposed, nearly all white. If I focused on an object, the exposure would return to normal, but the picture taken was shot through all over with fine white lines, making it indecipherable. The exposure through the lens and viewfinder has now returned to normal, but the white lines in the pictures persist. Any suggestions, particularly those that don't require sending the camera away (I'm in another country now and will have dire need of the camera in about a week), would be very much appreciated. Thanks!
CCD failure. Known issue apparently based on other posts on other forums and web sites: http://www.nikon.co.nz/pagearticle.php?pageid=2-bdc691bf61
Posted on Sep 15, 2007
SOURCE:
OUTSIDE TEMP SENDING UNIT GOT WET AND WILL NOT CONNECT TO CLOCK. HOW CAN I FIX OR HOW CAN I REPLACE?
[PDF]WS-8117 ATOMIC CLOCK WITH OUTDOOR WIRELESS ...
https://www.lacrossetechnology.com/products/.../misc/8117-manual.pdf
NOTE: Do not set the clock until the outdoor temperature is displayed. .... The unit will still try and receive the signal every day despite it being manually set. ..... sunlight, extreme cold and wet/moist conditions as these will lead to rapid changes ... Beforesending the atomic clock in for repairs, contact La Crosse Technology.
La Crosse Technology Top Solutions
https://www.lacrossetechnology.com/support/top_solutions.php
A: Complete a restart for display with the temperature/humidity sensor: ... to rest for 15 minutes can result in failure to connect with the outdoor sensor or missing ... Products set outside of these time zones will not search for a WWVB signal as it is ... locate the Clock or Weather Display near an outside wall and point the unit in ...
Common issues weather stations: Click Here
www.weather-station-products.co.uk/faqs/common-issues-weather-stations
Under £30 £30-£75 £75-£125 From £125 Birdhouses/Feeders Outdoor Clocks ... I'mnot getting any outdoor readings from my outdoor sensor, what do I do? This willcure 90% of all sensor connection problems, important you must ... is the airtemperature, to get this reading you need to place the unit away from direct sun.
Replacement Temperature Sensor ' AcuRite
www.acurite.com > All products
Dec 16, 2015 | Audio Players & Recorders
Tip
Tips for operating Air conditioning system on Toyota Hilux and someother...
To cool off your Toyota after it has been parked in the hot sun, drive with the windows open for a few minutes. This vents the hot air, allowing the air conditioning to cool the interior more quickly.
Make sure the air intake grilles in front of the windshield are not blocked (by leaves or snow, for example).
On humid, do not blow cold air on the windshield. The windshield could fog up because of the difference in air temperature on the inside and outside of the windshield.
Keep the area under the front seats clear to allow air to circulate throughout the vehicle.
On cold days, set the fan speed to high for a minute to help clear the intake ducts of snow or moisture. This can reduce the amount of fogging on the windows.
When driving on dusty roads, close all windows. If dust thrown up b the vehicle is still drawn into the vehicle after closing the windows, it is recommended that the in intake be set to FRESH and the fan speed to any setting except "OFF".
If following another vehicle on a dusty road, or driving in windy and dusty conditions, it is recommended that the air intake be temporarily set to RECIRCULATE, which will close off the outside passage and prevent outside air and dust from entering the vehicle interior.
HEATING
For best results, set controls to;
Fan speed ---- Any setting except "OFF"
Temperature----Towards WARM (red zone)
Air intake ---- FRESH (outside air)
Air flow ---- FLOOR
Air conditioning ---- OFF
For quick heating, select recirculated air for a few minutes. To keep the windows from fogging, select fresh after the vehicle has been warmed.
Press the "A/C" button on for dehumidified heating.
Choose floor/windshield air flow to heat the voltage interior while defrosting or defogging the windshield.
AIR CONDITIONING
Fan speed --- Any setting except 'OFF"
Temperature --- Towards COLD (blue zone)
Air intake --- (outside air)
Air flow --- PANEL
Air conditioning --- ON
For quick cooling, move the air intake selector to recirculate for a few minutes.
VENTILATION
Air flow --- PANEL
DEFOGGING
The inside of the windshield
For best results, set controls to:
Temperature --- Towards WARM (red zone) to heat; COLD (blue zone) to cool
Air intake --- FRESH (outside air)
Air flow --- WINDSHIELD
The outside of the windshield
Air conditioning --- OFF
On humid days, do not blow cold air on the windshield. The windshield could fog up because of the difference in air temperature on the inside and outside of the windshield.
DEFROSTING
To heat the vehicle interior while defrosting the windshield, choose floor/windshield air flow.
on Feb 14, 2011 | Toyota Pickup Cars & Trucks
Tip
Cold Weather Tips - Ruggedized Laptops
Normally the LAPTOPS have been designed to work within a safe temperature range - normally 50 to 95 degrees F (10 - 35 degrees C). It is necessary to safeguard your laptop from cold weather Protect yourself and your laptop from the damage cold weather can cause.One solution to it is buying Ruggedized LaptopsIf your budget permits, purchase or lease a ruggedized laptop if you will be outside in cold temperatures for extended periods of time. Ruggedized laptops have been designed to work under extreme weather conditions. Most ruggedized laptops come tested according to MIL-STD-810F standards.
on Jul 15, 2010 | Computers & Internet
Home wired system with 8 units goes off in cold weather without any alarming conditions. Does cold weather effect their operation?
Check each of the sensors one has failed or it also alarms on low temperature and you are cold enough to trip it.
Jan 11, 2015 | Heating & Cooling
What would be the reason it leaks water
Just as a cold can of soda condenses the moisture in the air as it contacts the cold surface, so does an Air conditioner, it is part of the "conditioning" not simply temperature reduction. As you may know in New York city for example 95F is a heat stroke warning temperature if the humidity is very high, Miami beach is also very humid, humidity affects the comfort level at a given temperature tremendously.
May 01, 2013 | DeLonghi A120E Air Conditioner
Very cold temps and all of the windows have steam on the inside? What to do?
The humidistat for the humidifier is turned up too high...in very cold weather you may have to turn it back to like 20%...that is enough for very cold weather...
Then as it warms up again you can turn it up higher again...
When the humidity is too high the temperature difference will condensate moisture on the windows....
Feb 08, 2011 | Aprilaire 550 Humidifier
I have a Char-Broil Grill. My regulator started frosing over or turning white like a freon can would and so I changed the regulator and the new one is doing the same thing. I just replace the bottle...
This is normal under certain temperature and humidity conditions. The gas is expanding as it goes through the regulator and this causes cooling - that much is always the case. If you have had cool weather for a while, then the propane will be cold to start with. The expanding gas will cool the regulator to a temperature significantly cooler than the temperature of the gas in the tank. If it's humid outside, then condensation is going to form and if the regulator is below 32 F, you will get frost. Nothing to worry about, it has no impact on the performance of the regulator. This effect will diminish when the temperature of the propane goes up (after a warm day) and as the level of propane in the tank is reduced (so the pressure drop across the regulator will be less.)
Aug 17, 2010 | Garden
Unit not cooling house below 80 HELP ME PLEASE
It's 98 outside ... that says a lot. The gurgling is an indication that you are getting a lot of water out of the air (dehumidifying). If the unit is sized just right, or just a little too small, it may be working perfectly well.
You don't say where you are, geographically, but much to the US has an air conditioning design temperature of 95 degrees F. That means at 95 degrees, the unit will run continuously. With a 50% outside air relative humidity, it should keep the occupied space at about 75 degrees F. The more humid the air, the more the unit works on dehumidifying and less on cooling.
Give it some time, wait unti the weather breaks and see if it doesn't run just like it used to. If you chose to call a technician, have him/her take temperature readings of the condenser entering and leaving air, the suction line temperature, the liquid line temperature, the inside supply and return air temperature (dry bulb and wet bulb) as well as high and low side refrigerant pressures. Before they make ANY changes to the system (refrigerant charge) have them explain what they found wrong and make sure you understand what they are talking about. Adjusting the charge under these conditions, will mess up your operation under normal conditions.
Jul 20, 2010 | Whirlwind FH-778 Air Conditioner
I have upvc windows & always have condensation inside the windows. Only time that I don't have this problem is in the summer months when the weather is fine. I have had the windows for the last 12...
This is caused by high humidity and difference in temperature from inside to outside. So in winter when you have the heater on, there is a reaction when the inside of the upvc is heated and the outside is cooled and causes condensation to build up. Very similar to when you are in a car and there is humid cold weather. The black spots are very possibly a fungus growing as a result of the high humidity. You need to introduce fresh air into the house possible with a small inlet fan.
Nov 15, 2009 | Heating & Cooling
All weather
The Olympus Stylus 410 Digital camera will not be damaged by water splashed onto it from any direction and can be used outside in adverse weather conditions such as snow or rain. The Stylus 410 Digital camera is all weather, not waterproof, and cannot be immersed in water. It is designed to operate at ambient temperature 32?-104?F and relative humidity of 30-90%.
Sep 01, 2005 | Olympus Stylus 410 / ? 410 Digital Camera
Nikon Coolpix 5700 Digital Camera Logo
182 people viewed this question
Top Nikon Cameras Experts
Ric Donato
pictureman4u
Geoff Hone
Are you a Nikon Camera Expert? Answer questions, earn points and help others
