Question about Acer Aspire 3000 Notebook
Acer aspire 3000 won't hold a charge
The hole where you plug in the charger seems to be broken. the charger itself still has a green light, so i don't think that is the problem. i would have to sit there and hold the charger in a certain place the entire time i was on it. and it seemed to be harder and harder to get it to charge until eventually it stopped all together. what i want to do is download all of my pictures on there to a disc. i don't have a problem sending it to acer and getting it fixed, but i don't want the hard drive wiped clean yet. all i really need is a charged battery to borrow for like 20 minutes until i am finished downloading my pictures. i live in erie,pa. unless there is another way to charge the battery i have? or some other solution. please help!
  • 6 more comments
  • Amie Dec 03, 2008
    ok, i am not sure that i follow you completely. my charger has one wire that goes in the wall and one in the laptop. so, i don't think it's what your describing. just to clarify, it's the hole in the laptop that is broken. anyways, i will show my husband your email and maybe he can figure it out. thank you very much for helping. God Bless you as well.
  • Amie Dec 03, 2008
    Ok, thank you very much. I'll have him take a look and if we have any more questions (which we probably will) I will let you know.
    God Bless, Amie
  • Amie Dec 04, 2008
    do you know how to get there exactly? we both have had it apart already and we can see the place where the charger plugs in, it just seems impossible to get to it. any suggestions?
  • Amie Dec 04, 2008
    This sounds like it's really going to work! I'll let my husband know and get back to you. Thanks!
  • Anonymous Jan 29, 2009
    Lmao
  • Greg Wilkins
    Greg Wilkins May 11, 2010
    OK i understand now. I thought the charger was broke. Tell your husband if he can get to the soldered connections where the plugin is on your laptop he can take the end off the charger and solder the wires to the connections directly. I'm sorry for not understanding and i get carried away sometimes i have been doing this fixing stuff all my life and forget other people might not be able to do the things i have grown to do.
    God Bless Greg
  • Greg Wilkins
    Its 14.8 volt battery so have you got any chargers laying around the house above 14.8 to say 18 volt? cause if you do and your charger uses two wires cut the charger off keep the wires going to your acer. ok then take the other power supply take most of the wire off. connect the wire together from the plug to the other power supply plug it in . watch to see if the light on your laptop shows charging light if not just switch wires .I have made my own power supplies on a lot of my equiptment because you can buy stuff cheap without power supplies :-)
    God Bless you Greg
  • Greg Wilkins
    what is the output on the charger? and while your at it is there two wires coming out of your power supply?
    Sergeant:
    Champion:
  • 334 Answers
IDEA! maybe a better solution. Going at this another way. Take the battery out because its what needs charged anyway. You should be able to see the connections.I don't know if it tells you positive or negative tho but this can be done with a voltage meter. If you hook the voltage meter up on dc voltage it will read backwards if its hooked up wrong. This will tell you which one is positive and negative. You can do this with the power supply too.when you have that figured out we are going to connect the power supply directly to the battery. after you cut the plug off and strip the wires connect the wires with tape or anyway you can to make connection and let charger charge till battery is built up.
I wanted to send this too it may be of some help to you sometime.Its an address to a acer manual
God Bless Greg
http://www.scribd.com/doc/7630525/Acer-Aspire-4720G4720Z47204320-Note-Book-Manual
Posted on Dec 04, 2008
Battery won t hold charge
If your battery does not hold charge, and you don't want to buy a replacement, then there is not much can do other than to keep using your laptop with the charger. All batteries have a time life span.
Jun 19, 2013 | Acer Computers & Internet
Acer Aspire 5552 won't power up, charge light flashes on and off
Remove the battery and plug in the Cord/charger, will it boot? If no, try another Cord/Charger with the EXACT same power specs. Replace battery if necessary.
Mar 02, 2013 | Acer Aspire 5552-3691-24271 Laptop
It won't charge and the power and batter light are all blinking
The first steps you could apply are-
1. Check the plug points. Test some other charger on the same plug point. If it's working, then go for the next step.
2. Use an alternate acer aspire 3000 charger. If you have a friend with the same laptop / same charging adaptor, borrow it and see whether the laptop is being charged from that. Or you could go to an electronics shop and see whether they have a spare charger just for checking purposes. If no adapter works, then it's not the adapter's fault, it's the fault of the laptop charging port.
3. To be sure, you could attach your adapter to an extension cable (a spike guard would be suitable. It prevents sudden peaks in current, thereby protecting your laptop from damage) . If it doesn't charge still, it's a fault within the laptop.
To check the charging port within the laptop, you'll have to go to a hardware specialist (assuming that like me, you're not adept at hardware!) . The specialist should guide you properly.
If the laptop is within the warranty period, you could try the service centre. Hope I've helped :)
Dec 18, 2012 | Acer Aspire 3000 Notebook
Not charging Acer Aspire 5732z, now won't turn on!
If it does not work with the Charger while the battery is out then I would say either your charger is bad, the dc power jack where the charger plugs into the laptop is bad or you've got motherboard issues. Does the charger have a light on it to indicate that it is on when plugged in the wall? Do you see any lights when you plug the charger into the laptop?
Take an ink pen and see if the little pin inside the computer where the charger plugs is loose and moves a bit. If so that is probably your problem. If the pin is tight and the charger works, then you've got motherboard issues.
Mar 29, 2012 | Acer Aspire Computers & Internet
Laptop is not getting charged
you need to buy new motherboard, it is a hardware problem
if you still on the warranty, take advantage of that because i believe they going to replace the parts for free
Jun 15, 2010 | Acer Aspire 4720 Notebook
My charger works and the light is solid green when i plug it in, but when i plug the charger into my computer the light blinks and my computer wont charge. what's wrong?
Either the battery has failed beyond the point of taking a charge or power connector on the mother board is broken. Check out my website www.micromendllc.com
Feb 26, 2010 | Acer Aspire 3680 Laptop
My acer 5735 won't hold a charge. Seems to charge (green light)
if it doesnt hold a charge its degraded and will need to be replaced . people dont realise that keeping a laptop plugged in damages the battery
Jan 10, 2010 | Acer Aspire 5735 Notebook
The battery won't charge on acer aspire 3610. I replaced battery with a new one which arrived with 65% charge. I fitted it and laptop worked until no charge left. The charger is plugged into mains and...
check the output of the charger and see if it is charging if so the conector might be bad does the plug wiggle when it is plugged in? it should feel very solid
Nov 27, 2009 | Acer Aspire 3610 Notebook
Acer laptop won't charge.
When you finally get the charge light to come on, does the battery get fully charged? How long can it run while not plugged in?
A junker will not charge properly, or hold a charge for a short period of time. If this is the case, time to get a new battery.
If the battery seems to charge fine and the uptime is acceptable take a look at the charger and connectors, make sure their clean and free of debris. Maybe try to locate someone with the same charger and see if the problem continues (Some computer shops may have your charger)
Jul 17, 2009 | Acer Computers & Internet
Acer Aspire 3000 Notebook Logo
294 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
