The on button turns green for a second then back to red. Can not get the dvd to play or spin at all.
Threw it in the garbage and bought a new one.
Posted on Dec 03, 2008
It won't play dvd's in color
Please check the type of disc that you're playing.
Generally, if the NTSC format disc being played in PAL Player or vice versa will cause this issue. Please use the NTSC format disc in NTSC player and PAl disc in PAL player.
Please check if the Player is connected to the display device with the correct cables and to the correct jacks.
Please make sure to connect the Component OUT (Red, Blue, Green cables) to the Component IN (Red, Blue, Green).
If you are using the Compiste connection (Yellow, Red and White), please connect the Video OUT of the Player to the Composite or Video IN on the TV using the Yellow cable and Red and white for audio according to the color codings.
Please try with different jacks on the TV to confirm if the issue is with the Jacks on the TV.
Please try power resetting the TV and check if that helps.
Turn off the Player.
Unplug the Player power cord from the electrical outlet.
Let the Player remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the issue is still unresolved, the Player needs to be Serviced at the Authorized Service Center.
Mar 30, 2011 | Sony DVP-NS50P DVD Player
Sylvania DV220SL8 won't play DVDs, DVD tray won't open
One simple solution is to unplug the unit for 30 seconds then plug it back in. Worked like a charm for me.
Jan 09, 2010 | Sylvania DV220SL8 DVD Player/VCR
Status light yellow, won't power on
Hey, I just unplugged my Cyberhome DVD for about 5 minutes and replugged it in. It is working fine. Try it with yours and let me know..
Lcamp518@zoominternet.net
Feb 08, 2009 | Cyberhome CH-DVD 300 DVD Player
I have a denon 1720 dvd player. When you press the power button it comes on for 3 seconds then the power button turns back red and powers off. If you press the eject button within the 3 seconds the tray...
same equql problem....?????
Can you help?
i have a denon 1720 dvd player. When you press the power button it comes on for 3 seconds then the power button turns back red and powers off. If you press the eject button within the 3 seconds the tray opens and the power button stays green. As soon as you close the tray the power agin goes to red. i have a denon 1720 dvd player. When you press the power button it comes on for 3 seconds then the power button turns back red and powers off. If you press the eject button within the 3 seconds the tray opens and the power button stays green. As soon as you close the tray the power agin goes to red. Can you help? thanks thanks
Dec 21, 2008 | Televison & Video
Progressive scan mode
THis one should be easy--just read it in the manual--reset your video mode by removing any disks from the player, close the drawer, and then press and hold the "stop" button for five seconds. The green power button should flash red and back to green. Hope that solves it.
Sep 17, 2008 | Cyberhome CH-DVD 300 DVD Player
Not playing
im not sure if this is going to help, but it helped when mine wouldnt start. take off the top frame of the dvd player so you can see part of the disk tray. put the dvd in and if you notice that its not spinning, then try spinning it to the left with your finger.
Jul 14, 2008 | Cyberhome CH-DVD 300 DVD Player
DVD stopped playing all DVDs
Reset you player by doing the following:
With the player on, hooked properly to your television, and on the correct station:
Open the tray
Close the tray (with no DVD inserted)
Hold the stop button down for a full 5 seconds
The CyberHome screen should appear. You should be able to play your dvd's now.
Feb 20, 2008 | Cyberhome CH-DVD 300 DVD Player
Coby dvd player
do you see the laser light come on when the disk spins if not it has probably lost power or failed, if so sometimes the laser head gets moved to close to the drive mechanism and the motor cant pull it out. i have found several of these that had this problem.
Oct 19, 2007 | Coby DVD-207 Portable DVD Player
Cant play anything on it
I had the same problem, After googling for a few minutes I found the reset procedure for this player.
1. Turn it on.
2. Eject any disk you have in there and close the tray.
3. Hold down the "STOP" button on the player (not remote) until the green light flashes red and the system reboots.
4. Insert disk and enjoy.
This worked for me... mileage may vary.
Aug 29, 2007 | Cyberhome CH-DVD 300 DVD Player
I change settings
The reset on my son's CH-DVD 300 was the stop button. All i did was turn on the dvd player and then held in the stop button for 10 seconds. And badow, I have video.
Nov 28, 2006 | Cyberhome CH-DVD 300 DVD Player
Televison & Video Logo
15 people viewed this question
Top Televison & Video Experts
Electro Med Services...
