Monitor won't stay on
My Envision EN-5100 monitor suddenly goes to a black screen with amber light and won't wake up until I reboot the computer. Last night it did this several times, within 20 minutes of starting up each time. I checked the power settings and made sure they were at never power down, but that hasn't helped. My monitor and whole system are probably close to 4 years old, but other than some viruses sometimes, work good. Color and images look good when it is running, and we do no gaming on this computer.
  • jakegest Feb 24, 2009
    I've been having the same problem (I have a Dell E207EFP).. although it usualy takes a longer time for it to happen. Although I'm not sure I've solved it... I was just able to wake it up by turning the monitor off, unpluging the power cord to the monitor and unpluging the Input cable at both the computer end and the monitor end.. then reconecting everything and turning it back on. So far this is the only thing that has ever worked short of rebooting the computer.
  • 88 Answers
Yep sounds like it's screen saver, when you have done the screen saver goto control panel look for power tab and have a look in there cancel what you don't use, change your power options, hope this helps, paul.
Posted on Jul 02, 2012
  • 57 Answers
Your computer may be in screen saver mode, it has instructed the monitor to go to power saving mode, or the the monitor's video cable is not properly connected to the computer. Another possible cause of this is a locked-up or in-operative computer since the computer is what supplies the monitor with all the display data or information. Move the mouse or press a key to de-activate the screen saver or power saving mode. Check the monitor's video cable and make sure it is snugly connected to the computer. To see if the computer is operating properly, press the CAPS LOCK key on the keyboard repeatedly while checking the CAPS LOCK light. If the light is not turning ON & OFF, the computer is non-functional. Contact your computer manufacturer for help.
Posted on Dec 02, 2008
I have a dell dimension 4600 computer. I usually put the computer in sleep mode when I am not using it. Usually I press the ESC button and the computer wakes up. All of a sudden, the monitor won't...
Plug the monitor into another computer to determine if the monitor is damaged or working properly. You can also plug another monitor into your computer to determine the same thing.
May 21, 2011 | Dell Dimension 4600 PC Desktop
Screen is black when computer is turned on. Tthe monitor power button blinks, but when you push the button, the light does not stop blinking and the screen stays black.. The monitor was working and last...
Try a different video card or disconnect the one you have in your PC and use the VGA monitor connection on the motherboard. If it works your video card is gone.
Dec 22, 2017 | Envision 19" Widescreen Flat Panel LCD...
I have a Envision EN-7100e monitor. Downloaded
catamount309, This is only a guess, but unit may have internal "switch-mode-power-supply"/"CCFL inverter" board problem. When screen goes BLACK, is it also BLANK? If you can see WIN-desktop with aid of bright flashlight 1 inch from screen, then SMPS is in partial shutdown mode. If you see nothing, then SMPS is in full shutdown. In either case, Technician will need to repair the SMPS/CCFL inverter board. If KNOWN GOOD monitor works with PC, then you know 7100e is bad. Do you know and understand how the new energy efficient screw-in curlie-Q light bulbs work? If the "electronic ballast circuit" not working, then it can't light-up the CCFL tubes on the reverse side of LCD panel then you see black. Do more reading in my fixya profile for more options open to you. Do your research first!! Hey, reading is free!!!
Will you fix or trade for new? 12fixlouie
Mar 07, 2010 | Envision EN-7100e 17" Flat Panel LCD...
19'' Flatscreen Envision monitor, goes to sleep
it does not sound like it is a computer problem, but a monitor problem. you need a new monitor because last i checked, those monitors either cannot be repaired or the cost exceeds that of a new monitor. sorry.
Jun 25, 2009 | Apple MA876LL iMac with 20" Screen Desktop...
Flat screen monitor
Possibly a bad inverter that turns on the fluorescent backlight or a bad bulb.
Jan 17, 2009 | Envision EN-7100e 17" Flat Panel LCD...
Envision color monitor, Model EN910e
Hi..there! Barb,
It's seems you got a busted backlight inverter... Need to replaced a new one or repaired it. Have a nice day!
Oct 22, 2008 | Envision EN-7220 17" Flat Panel LCD...
Envision EN 5100 E with Dell Inspiron 530...
you can try to reset your display settings... try 640x480 resolution 60Hz refresh rate this can be done in the control panel under display---settings tab..
good luck.if that doesn't work I would just return it and buy a viewsonic LCD here the price was just marked down from $260 to $130 bucks
Jun 25, 2008 | Envision H170L Monitor
En 710 e enivision monitor
hi there, black out monitor couses many trouble, it maybe in the video section, horizontal section, power supply section. so some test, start with the power supply section, then the horizontal section and the video section. ty
Dec 26, 2007 | Envision ECT-700G (Beige) 17 in.CRT...
ENVISION EN-985E MONITOR PROBLEM
When using this monitor on a PC running Windows Vista Home Premium the screen text is blurry and hard to read . I have tried working with the Clear Type in Vista and that does not help . I have reloaded the driver for this monitor and this did not help either . Any suggestions ?
Steve
Dec 05, 2007 | Envision EN-985e Monitor
Computers & Internet Logo
925 people viewed this question
David Payne
David Payne
