Need a manual to use Tefal's toast'n'egg correctly
SOURCE: I have a tefal TT550015
1. Your toast n egg should have come with a small plastic cup. On the sides you will see dash marks which indicate how cooked you would like your eggs. One side is specifically for making the egg in the pan (or sandwich). Fill water to the desired marking....this should be about 2 1/2 tablespoons (from memory)
The part that looks like a waffle pattern (with holes) is where you put your precooked meat to be warmed.
2. For making a sandwich, put the english muffin in the toaster area. Add the desired amount of water to the egg cooking side. Spray your pan with nonstick spray and crack your egg in the pan. Mix up a little to break up yolk. Place meat on the meat warming part and place over the egg.
3. Cover with clear plastic dome.
4. Push down the toaster arm. Then press the button egg/toast.
The english muffin will begin to toast and the egg will cook......when the toaster portion pops up...bother will be done.
Enjoy!!
If you were to log on to the
manufacturer's web site, I think you may be pleasantly surprised as
usually, if available, one is able to download, by model number,
Customer Instruction Manuals,
list of Dealers for
spare part supplies and Driver
downloads
(if applicable)
as required.
The information is normally free of
charge.
I hope this helps.
how do you use the egg poacher please. Christmas Chrisis going on here, :)
I simply do not know how to use the product....
