Question about Mitsubishi WS-65809 65" Rear Projection Television
How do u replace a IC convergence on a mitsubishi 65 tv
  • 22 Answers
if you guys don't have experience or the right tools to fix board you will mess up your board.
so go to ebay and search for repair service listing #230735864835 and sen your board to this guy for convergence repair.
let a professional do the job for you and for cheap,why buying repair kits when you can buy the repair service?
Posted on Jul 19, 2012
SOURCE:
  • 15 Answers
SOURCE: 3d look on mitsubishi ws-55511
Hi bluemags,
It is true that you should use a higher power I.C., I do that all the time. However, the one to use is the STK392-120. This one is rated at 5 Amps unlike the STK392-110, 150, which are both rated at 3 Amps. I have not checked the data sheet on the 180. They are all OEM, since Sanyo designed them all. Beware of generic knockoffs not made by Sanyo. The generic I.C.s do not have the quality as the Sanyo originals.
Best Regards,
MyTvGuy
Posted on Feb 10, 2008
Slinteriors
  • 8617 Answers
SOURCE: Mitsubishi WT42311 Convergence IC replacements didn't work
the pico fuses will usually need replacement when the Ics go out they take out the two 5amp pico fuses.You can get replacement picos at the following link.
http://servicemanuals.vstore.ca/
Posted on Oct 11, 2008
diths_kri
  • 67 Answers
SOURCE: Red convergence problem - Mitsubishi 65
It sounds like your red gun might be close to going, we had the same problem our tv
Posted on Jan 07, 2009
asnowman
  • 788 Answers
SOURCE: What is the best IC replacement for original IC part# STK393-110?
Sayo makes the best IC's, don't just settle for the cheap ones. I have see this ic for as low as $5.00 on the internet.
I would also advise that the convergence IC’s be OEM or better, just because they are cheap does not mean that they are a good deal. I have seen the cheap IC’s fail after a short time, even though they look exactly like the OEM IC’s. I think that the bottom line is that you will get what you pay for when it comes to the parts.
You can try http://www.tvrepairkits.com/ they do carry OEM or better parts.
I hope this information allows you to resolve this issue.
If you need further assistance please comment to this post and I will try to help you further.
asnowman
Posted on Oct 13, 2009
SD Tech
  • 14553 Answers
SOURCE: the colors are blurry and will not converge
This model uses a Single convergence IC---a STK-393-110.
If convergence is skewed and will not adjust the chip needs to be replaced.
Most shops get 300 or more for this repair---you can buy the IC on Ebay for about 12 dollars--total parts cost should be under 30 dollars.
I have Start to finish, step by step instructions for this repair in this set--they tell you everything you will need and how to do the repair.
Let me know if you have questions or want the instructions.
If this helped you rate this solution as I do this here for free.
SD TECH
Posted on Dec 19, 2009
MY TV IS OUT OF FOCUS ON THE ENDS CLEAR IN THE MIDDLE WITH GHOSTING RED A BLUE EVERWORD OR DIAGRAM LOOKS 3 D OR DOUBLE VISION WHY
have you tried adjusting the convergence on the tv
once they get older or get moved you need to do this
go through on screen menus and look for adjusting convergence menu and follow on screen instructions
good luck!
Mar 25, 2011 | Mitsubishi WS-65611 65" Rear Projection...
On my mitsubishi ws65909 I have a 2-2 power light error code, what does this mean? any suggestions, I tried to power it up and the power light comes on and then goes off after 15-20 sec's
the famous code error 2- 2 is for fault in power supply or faulty power supply board. this has to be checked.
and error 2-3 is fault in convergence ic.so both the error codes are near to each other.so check out both options. i advise first replace the convergence ic on the board and check.the cost of each convergence stk ic is near to $15 .there are two such ic on the convergence board and both has to be replaced.then check out.if the problem is same go for power supply board replacement.
the ic which you have to remove and replace is stk 393-110 both the ic looks same anve same number .
you can get the required board and components at ----- www.partstore.com -------- or from ------ www.radioshack.com ----
if you are not familiar with doing this you can get it done by local tv repair technician familiar with this model tv.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Nov 26, 2009 | Mitsubishi WS-65909 65" Rear Projection...
Mitsubishi 1080 hd ws-65809 wont power up
This issue is almost always caused by a faulty Convergence IC inside your TV. These chips heat up and can become damaged over time. The most common cause I have seen for the picture distortion is the heat of the Convergence IC weakening the solder connection to the TV circuit board. If you look on various messages board you will see people rigging wooden dowels and other items to apply pressure to the chips in order to correct their picture issue. This works because when the solder joint is weakened the chip becomes loose and vibrations or pressure will cause it to work or not work correctly. Aside from all that information the correct fix is to have the IC chips replaces on your TV.
The solutions for this issue are as follows:
1. located a tv repair shop that will replace the parts for you. I had the same issue with my 65" Tv and the quote was $350 for the labor and parts.
2. You can ordered the IC replacements yourself online by going to google and looking up a reseller of the STK392-110 Convergence IC that is inside your model TV. You will need 2 of them and they cost around $6 each. If you have the soldering skills to remove the old chips and install the new ones this is by far the most cost effective route. It is a fairly simple process and guides can be found online.
Mar 17, 2009 | Mitsubishi WS-65513 65" Rear Projection...
The blu display on my sony 65" tv is arched, making the convergence adjustment in-effective.
its failure of Convergence Out IC chip and requires replacement.
TV has 2 IC chip in convergence circuit and I would recommend to replace both at same time.
Let me know exact model of Sony 65" TV to provide you more technical info.
Mar 14, 2009 | Sony KP-51WS510 51" Rear Projection...
Our TV (Mitsubishi WS65711) is 6 years old, and has recently started showing a blue ghost image on everything. It stopped for a while for a week or two, but started back up, and has continued ever since. I...
You have convergence problem in your tv as your local repair shop told you. You need to replace convergence IC . YOu can get from the link below .
Convergence IC can be obtained from the link
You need to replace both convergence ICs .It will cost you around $30
If you can replace it by yourself . If you take to repair shop they will charge you around $200 for this job. .
The IC number is STK393-110 .
You can get some idea on how to replace convergence IC from the link below
http://www.fixya.com/support/r704766-convergence_solutions
Hope this helps .
Feb 19, 2009 | Mitsubishi WS-65511 65" Rear Projection...
CONVERGENCE WILL NOT PROPERLY CONVERGED
you only need one STK393-110 Convergence IC and two 5Amp pico fuses. You can get the IC and the two fuses for less than 35.00 at the following link and they provide free installation instructions with pictures so you can easially do the repair yourself. Heres the link.
Jan 19, 2009 | Mitsubishi WS-65712 65" Rear Projection...
Mitsubishi rear projection tv
replace vertical IC and shadows/ghosting the problem is either electrolytic capcitor or video IC or convergence adjustment
Aug 18, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Red and Green
check video IC or tv convergence sometimes yoke
Aug 12, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubishi 1080 hd
check and re-solder the connections on the 2 convergence ICs in the middle power board. they are going to be attaches to the biggest heat-sink in the tv. if the re-soldering doesn't fix then replace with STK392-570 i would replace both but if you look at the board you should be able to figure out which chip is responsible for the vertical and which is the horizontal convergence. each IC converges all 3 colors but one is responsible for one axis.
Feb 20, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Help with my mitsubishi 65 inch tv
convergence ic going. you may also want to check some caps;
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
caps
http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm
http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
http://www.fixya.com/howto/h159332-mitsubishi_dm_board_repair
http://hdtvoice.com/voice/showthread.php?t=32186
replace DM
Dec 12, 2007 | Mitsubishi WS-65807 65" Rear Projection...
Mitsubishi WS-65809 65" Rear Projection Television Logo
50 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
