Question about Brother IntelliFAX 1840C Plain Paper Inkjet Fax
Ok the fax keeps telling me to reinstall ink cartridges, so I do and then it goes through all the colors and asks if I replaced them and I say yes. Then it says no cartridge! What do I do?
  • ezgro Apr 20, 2009
    I have replaced all the ink cartridges and it keeps saying "no cartridge"
I had the same problem, but i change ALL the cartridges, & it reset itself finally, good luck
Posted on Dec 13, 2008
After replacing 901 black cartridge printer keeps saying aligning cartridges please wait
every time replacing an ink cartridge, printers asking for alignment.do it once , following instuctions which appears in printers monitor.after,look at printed page and saw if is asking to scan once this page.
Feb 15, 2015 | HP Officejet 4500 All-in-One -...
MY C5180 WILL NOT PRINT THE COLOR RED
Hello there, I am the Expert that will be helping you today. My name is damnor01.
Welcome to Fixya.
Have you replaced the colour ink Cartridge?
If you have not then you may be low or out of the colour ink cartridge. You would therefor need to purchase a replacement compatible ink cartridge.
If you have replaced the colour cartridge then you may need to give the ink some time to flow through the system.
Use the software that came with your printer and use the option to clean the ink heads of the colour cartridge.
When asked if you have replaced cartridges say yes.
Tell me how it goes!
Thanking you kindly
damnor01
Feb 13, 2011 | HP Photosmart C5180 All-In-One InkJet...
WHILE TEST PRINT CYAN INK NOT SHOWING WHAT SHOULD I DO SIR
This issue will only occur if an ink cartridge(s) is or was installed inthe wrong position (slot) in the machine. When a cartridge is installed, the ink tube system is filled with the ink from the cartridges, to prepare the machine for printing. If the cartridge is inthe wrong position the tube will fill with the wrong color.
NOTE: If you just installed or replaced the ink cartridges and your printed documents are missing colors please refer to the solution - I just installed or replaced my ink cartridge and my printed documents aremissing colors. What can I do? Blank
To resolve this issue you will need to clean the print head.
NOTE: It may require 10 to 15 cleanings to clean the ink tubes and print head. During the cleaning process, the ink in the cartridge(s) will be consumed. Additional ink cartridges may be required to completethe cleaning process.
1. First verify the position of the ink cartridges:
a. Open the ink cartridge cover and check to make sure the ink cartridges are in the correct order.
b. Starting from the left side, the correct order is Black, Yellow, Cyan(blue), and Magenta (red).
- If the ink cartridges are installed in the correct order, close the ink cartridge cover and continue to STEP 2.
- If the ink cartridges are not in the correct order, remove the ink cartridges that are installed in the wrong position by pressing down on the release lever(s), located above the ink cartridge and remove the cartridge(s) from the machine.
Next, reinstall the ink cartridge(s) in the correct position in the machine by gently pushing the cartridge in until it clicks.
When all the cartridges are installed, close the ink cartridge cover.
2. After closing the ink cartridge cover, the LCD will prompt - Did youchange XXXX (XXXX = the color) This message will be displayed for ink cartridge that was removed. Press the - (Minus Key for No). This willkeep accurate data of how much ink is left in the cartridge.
1. Press the INK key.
2. Press OK to select Test Print.
3. Press OK to select Print Quality.
4. Press the COLOR START key.
5. Review the Check Sheet. The colors on the Check Sheet should be in a specific order: Black, yellow, Cyan (Blue) and Magenta (red).
a If the colors on the Check Sheet are in the correct order and are notmissing any dashes, press + (Plus Key for Yes) on the key pad and continue to STEP 7.
b If the colors on the Check Sheet are not in the correct order, are missing dashes or blank or a color other than Black, Yellow, Cyan or Magenta printed press - (Minus Key for No) on the key panel and continueto STEP 6.
6. The machine will need to perform cleanings to flush out the incorrectcolor or dried ink from the ink tubes and print head.
a. The LCD will ask you BLACK OK. If black is fully printed and is the correct color, press + (Plus Key for Yes). If it#s blank, missing dashes or is the incorrect color, press - (Minus Key for No).
b. The LCD will ask you COLOR OK. If any of the 3 colors (yellow, cyan (blue), and magenta (red) are fully printed and are the correct color, press + (Plus Key for Yes). If it#s blank, missing dashes or is the incorrect color, press - (Minus Key for No).
c. The LCD will say START CLEANING + for YES and - for NO. Press + for YES to start cleaning. The machine will go through a cleaning cycle that will take approximately one to two minutes.
d. After the cleaning is completed, the LCD will say PRESS START. Pressthe BLACK START key. This will print out the print quality check sheet again for you to check and see if your print quality issue has been resolved or not
NOTE: If you wait 1 minute after the cleaning cycle is completed, the display will return to date and time. You will need to go back to STEP 3 to print the Print Quality Check Sheet again.
e. If the ink color order is correct and all of the dashes are present, press + on the key pad to select YES and continue to STEP 7.
If the colors on the Check Sheet are not in the correct order, are missing dashes or blank or a color other than Black, Yellow, Cyan or Magenta printed press - key to select NO. Repeat the cleaning process byfollowing STEPS 6a through 6d. You may have to perform this procedure up to 15 times in order to clean the ink tubes and print head
NOTE: During the cleaning process, the ink in the cartridge(s) will be consumed. Additional ink cartridges may be required to complete the cleaning process.
7. Test by printing the document that had the reported problem (wrong color printing).
Dec 08, 2010 | Brother DCP 165C Compact Color Inkjet...
My Brother MFC 420CN printer indicated it was out of Magenta...so I replaced the cartridge. After replacing it asks "Did you replace Magenta?" I said "yes". Now it indicates "No Cartridge. Open scanner...
Yep, it supposed to **** your money out of you pocked until you come up with a right solution.
Try pulling your power cord when your unit is on and when it off. It might help.
Try a factory reset on your printer. It's called hard, cold, factory, deep reset that means same thing.
Resetting Brother Printer
You need to keep pressing the DOWN or UP keys a couple of times till you see 'Maintenance 99' displayed on the display. Then hold down the 'Set' button to go to standby mode. Please note that if you press the exit key only after typing in a single digit then the machine goes to maintenance mode in initial stages.
Sep 07, 2010 | Brother MFC 420CN All-In-One InkJet...
How do I change the toner?
The Fax-2480c does not use toner cartridges.
This is an inkjet and so uses ink cartridges.
There are 4 cartridges, black, yellow, cyan (blue) and magenta (red). If any of these cartridges are empty, you need replace them.
This machine takes LC-51 cartridges.
You're probably out of warranty so jsut get refills... it's cheaper
Mar 25, 2010 | Brother IntelliFax-2480C Fax
Replacing a cartridge
Title:
I replaced my ink cartridge, but the LCD is still displaying "Ink Empty". What can I do?
Description: This is typically caused by an incorrect selection made during the LCD prompting after a cartridge is replaced. When an ink cartridge(s) is replaced, the LCD will ask, "Have you removed Blck? 1 Yes 2 No". This question will be asked for ALL 4 colors in sequence, regardless if the color was replaced. If "1 Yes" is NOT selected for the color(s) that was replaced, the LCD will return to "Ink Empty". Do the following to clear the message:
  1. Pull the scanner cover release lever located below the control panel and lift the top cover.
  1. After 15 seconds, re-close the top cover and then re-close the control panel cover.
  2. The LCD will then display Have you removed Blck? 1 Yes 2 No.
    The LCD will display this question for ALL 4 colors (not just the ones replaced). BE SURE to select 1 YES for each ink cartridge that was replaced.
    If 1 Yes is selected, the LCD will then display Change to new (color)? 1 Yes 2 No. Again, BE SURE to select 1 YES.
Note "Change to new (color)?" will only appear if 1 Yes is selected for "Have you removed (color)?" If 2 NO is selected for the "removed" question, the LCD will then move on to the question for the next color.
Oct 11, 2009 | HP Photosmart 3310 Printer
After replacing the ink cartridges ran out I replaced them for new ones and the machine is not telling me that cartridges are empty tried and tried to rereplace them and I still keep getting the same
  1. Press the Menu/Set key.
  2. Press the up or down navigation key until TEST PRINT appears on the LCD.
  3. Press Fax Start. The DCP/MFC begins printing the Print Quality Test Sheet.
  4. By reviewing this Test Sheet, you can determine if the print quality or alignment needs improvement or adjustment.
StepA - Checking the print quality:
  1. The display will read "IS STEP "A" OK?" 1.YES 2. NO.
    Before choosing YES or NO, closely examine the print quality of the four color blocks that are formed by short diagonal lines on the Test Sheet.
    If all lines are clear and visible, press 1 (YES) and proceed to StepB. If you can see missing short lines, press 2 (NO).
  2. The display will then ask you if the print quality is OK for each color. Press 2(NO) for any color with the problem.
  3. The display will then show START CLEANING? 1.YES 2. NO.
    Press 1(YES) and the DCP/MFC will start cleaning the color ink cartridges.
  4. After the cleaning is finished, press Fax Start. The DCP/MFC will print another Print Quality Test Sheet.
  5. If you can see missing short lines in any of the four color blocks press 2 (NO) and repea the quality check and cleaning process. Repeat this procedure at least 5 times if print quality remains a problem. If short lines are still missing after the fifth cleaning and test print, replace the necessary ink cartridges. If the print quality of the 4 color blocks is OK, press 1 (YES).
StepB - Setting the Alignment:
  1. The display will then read "IS STEP "B" OK?".
  2. Examine the 600 DPI and 1200 DPI test prints on the Print Quality Test Sheet. If the number 5 sample of both the 600 DPI and 1200 DPI most closely matches the 0 sample, press 1(YES).
    If one of the other samples is a better match for the 0 sample, press 2 (NO). The display will then prompt you to select the sample that most closely matches the 0 sample for 600 DPI and then 1200 DPI.
  3. Print another Print Quality Test Sheet by following the steps provided at the top of this page and check it.
  4. Press Stop/Exit.
Aug 11, 2008 | Brother MFC 420CN All-In-One InkJet...
Brother MFC-3360C cyan ink cartridge replace ment
On the front of the cartridge there is a sight tube for the ink, the fax shines a light through this tube to detect the ink.
I wraped a piece of paper around the tube to block the light beam on all the cartridges.
I dont need a processer to tell me if the machine is out of ink, I can work thay out when it stops printing!!
Now tell me you are out of ink you peice of electronic ****.
Jun 27, 2008 | Brother Multi-Function Center MFC-3360c...
Changing ink cartridges
Do you use generic ink carts?
Those do make a lot of trouble with different errors.
Use another cart and it should disappear.
The technique of brother printheads demands some ink to keep the printhead working. Otherwise it will dry out. Therefore the machine runs some auto cleaning cycles (about once a week).
You should set date and time and leave the printer on power (You can turn it off by pressing stand-by-fax. But do not unplug/disconnect it from power outlet. Otherwise the printers logic thinks that if the printer is reconnected that it is newly initialized and pumps a lot of ink into the waistinktank).
The amount of ink when running auto cleaning cycles is about 1/10 of the amount of the initializing one!
Nov 08, 2007 | Brother MFC 420CN All-In-One InkJet...
Re install ink
I know this is a dumb question but did you remove the tape off he bottom of the ink cartridge? Also sometimes if you are using a generic ink cartridge the machine may not recognize it. Make sure the cartridge is seated in properly and that it is in the correct location. (not color spot). Hope this helps. John
Sep 07, 2007 | Brother IntelliFAX 1940CN Plain Paper...
Brother IntelliFAX 1840C Plain Paper Inkjet Fax Logo
71 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
