Password.. Hello mate i was setting up my linksys put the cd in...and no its saying please enter your password.....but i dont have one can you help me ? thanks
I need to password protect my wireless router - someone in my neighborhood is using is and I was notified by Charter Communications that I was in copyright violation and that I should passowrd protect my router - I am not computer savvy, so can soemoen help me? I need to password protect my wireless router - someone in my neighborhood is using is and I was notified by Charter Communications that I was in copyright violation and that I should passowrd protect my router - I am not computer savvy, so can soemoen help me?
You can't post conmments that contain an email address.
Please try the below steps for changing the Linksys router's administrator password
Step 1:
Access the router's web-based setup page. To do this, open a web browser and enter the IP address of the router on the Address bar then press [Enter]. Step 2:
Click on the Administration tab. Enter the new password in both the Router Password and Re-enter to confirm fields. Step 3:
Click Save Settings and click the Continue button on the next page.
Hello Friend
Please open page with address 192.168.1.1 and open the router page with username= blank
password=ADMIN
Go to wireless tab and click on the security
Click on the secutiy box and enable this.
Set this to WEP or WPA
Enter the passprase\password which you want tas a password for your wireless network.
Enter these details
You can also check this user iterface here.
No proplem you don't need a software cd to secure the router. Please follow the steps Click the below link http://192.168.1.1
Now it will ask for username and password
Enter username = ( blank) and password = admin If you can't login using this credentials then you will have to reset the router
If you logged in . Then click on Wireless > Wireless security
On this screen select
Security Mode : WPA Personal WPA Algorithm : TKIP WPA shard Key : "enter a password here" Group Key Renewal : set to default
Click on save settings. After that restart router . Now your wireless network is secured and you will have to type the WPA shared key inorder to connect to router when it prompts
Welcome to FixYa
Login to Router Page and Change your Password.Follow Steps
Launch a Web browser (Internet Explorer, Firefox, Safari or Google Chrome) and enter "192.168.1.1" in the URL bar. You will be prompted to enter a user name and password; enter "admin" for both. If the user name and/or password has been changed by a previous user or the URL doesn't bring up the Linksys login page, reset the router
Change the wireless network password by clicking on the "Wireless" tab and then the "Wireless Security" tab on the row below. Select "WPA-Pre-Shared Key" to create your own password for the wireless network; choose "WEP" from the pull-down menu to have a random password generated for you. Record your password and keep it in a safe place.
If you cant Enter in to Page or any Error RESET it by Pressing RESET key in Backside..Then Follow above steps.You can also look this Link...
If this Helped you-Dont Forget to Rate ME..Thanks for Contacting FixYa..
..hi..hello...if you don't remember the password their is a simple way about..try to find small hole at the back of router the name is reset,so u make a resets using small pin.reboot the PC/CPU when the router is connected then after reboot re-type again (192.168.1.1) then u see again the box of Linksys only u need enter the box is Password the password is (admin)..good luck and Thanks...
Linksys reset
The easiest method of resetting your Linksys router’s password is to reset your router back to the default factory settings. This is done by simply holding down the reset button located on the back of the unit for at least 30 seconds. Once the router has been reset, it must be reconfigured. Using your web browser go to URL address http://192.168.1.1. You will then be prompted to login to your router. A log-in screen asking for the password will automatically appear. At this time enter the default password “admin”, in lower case letters into the password field. The username field may be left blank at this time. (Note: both the default username and default password are set to “admin” on some of the newer Linksys router models). If I could be of further assistance, let me know. If this helps or solves the issue, please rate it. Thanks, Joe
You can manually install it even without a CD, if you dont know how to do that you can contact Linksys tech support so they can walk you through in configuring it manually , this is the number 800-3267114....
You can try accessing the router setup page or the user interface of it byu typing the http://192.168.1.1 on the address bar of the computer that is wired to the router and working to the internet, of you can also call linksys tech support so you don't need to reset the router because they can tell you how to change and check all the settings on your router this is the number 800-3267114, but if you want to reset the router just press and hold the reset button of it for 10 seconds,,,,
