Question about Simrad Ap12h Powerpilot
Dead in the water , no autopilot
I'm stranded in grenada w.i. on a sailboat with a broken sutopilot. the armature is shot. the unit is a b&g network autopilot with a 445-00-061 .ram which has been discontinued. the unit may have been built by a uk company called hypro. i would break down a buy the replacement ram drive from b&g but it won't fit. its about 8 inchs to long because of the way they mountede to dc motot. if you google the part number, click on, and then scroll down to section 3 page 5 you will find complete specs and drawing for the assembly.
dave mcclimans
sy cutaway .
2 Suggested Answers
SOURCE: On my boat I
Your internal GPS module has failed and cannot be serviced.
You must buy a new complete navigation system.
"Loopback failed" means the module was unable to communicate with itself. A "loopback" is where a component within a system (hard drive, sounds card, video graphics card, etc) is redirected to send signals though its output device and simulate them back into the input device. This "loopback" is done within the internal circuit and can help identify and isolate dead circuitry.
Posted on May 13, 2011
Raymarine 4000 + autopilot. I immediately get an RG Fail message when I engage the autopilot on my Catalina 320 Sailboat.
I am not familiar with your particular model autopilot, but I do know that Raymarine autopilots can be fussy. All must have a compatible gps feeding it, of course. All must have a rudder angle indicator if your auto pilot connects to the wheel or rudder instead of directly to the tiller.
Aug 25, 2017 | Raymarine Boating
My Ap16 Simrad control head died. Any idea of as to 1) where I might get it repaired and/or 2) where I might find a replacement?
Hi John
Boy, you're up against it on this one. The AP16 is a pretty old unit for sure. Here's the link to your owners manual.
I've come across one instance in my experience where although there was enough power showing to the control head, because of corrosion and broken wire strands, there simply was too much voltage drop and not enough current flow for the unit to function when it was turned on. After cutting back/fixing the soldered connections and reconnecting the cable, the unit was good to go.
I hope this information is able to help you out.
Good luck.
You MIGHT get some joy contacting Simrad tech. at 1 800 628 4487
if you're in the US. If not, here's the link to their support page.
Dec 08, 2014 | Navico Simrad AP16 Autopilot for Inboard...
How to repair St40 autopilot. Works intermittently.
The autopilot draws a good amount of current. make sure that all connections are good and tight starting with the connection at the fuse or breaker all the way through to the unit. make sure the connection at the autopilot is clean and tight. If the problem persists, it may be internal to the unit.
Aug 24, 2014 | Raymarine St4000mk2 Marine Autopilot Wheel...
Problem: Autopilot does not engage. This is a new problem as it was working quite recently. Model: Simrad NSE8/AP24 with AC42 Autopilot Computer. Attempts to engage the autopilot result in an...
Which drive are you using with the AP24, is it just a hydraulic pump on a powerboat, like our RPU80, or is it a hydraulic linear drive (like our HLD-2000) or draglink drive (like our DD-15) on a sailboat?
Mar 24, 2011 | Simrad AP24 AUTOPILOT DISPLAY UNIT
Autohelm ST 6000
Check the installation manual for initial setup,if system worked before ,check rudder reference unit for broken wire loose connection or defective unit (it is a potentiometer resistance shoud change smoothly with position)
May 21, 2010 | Raymarine Smartpilot Autopilot St6002 S1g...
Display control unit frozen, display just reads standby
The reason is because the housingin is a little bit broken or throw the keypad water came inside yuor Display and after this the oxidation ha destroyed a part of the printid circuit or the switch of the keypad
Oct 03, 2009 | Raymarine Boating
Raymarine autopilot swings hard over immediatly i select auto
Apr 04, 2009 | Raymarine St8002 Smartpilot Autopilot...
Minn kota 68pd motor
Your armature has a dead spot. Either replace it or get a generator rebuild shop to test it on a growler, and fix the open winding. You can do it if you ohm between ajacent brush blocks and re-stake the wire clamp on any that ohm over 1 ohm. You MIGHT only have a dirty commutator which can be solved with crocus cloth.
Aug 12, 2008 | Minn Kota 74 AutoPilot Motor/Sonar Combo...
I would like to purchase a full Furano Navnet 3D system with for my 42' sailboat now in production. It does not have hydraulic steering though. Is there a hydraulic linear drive compatible withe Furuno...
No, you will use the appropriate Simrad Drive unit such as an HLD350. It comes in long and short throw and split versions, and dual ram versions. Better to discuss on the phone probably. 847-746-0100 or email
Aug 09, 2008 | Furuno NavNet vx2 1920C GPS Receiver
Leaking water
It sounds as though the collection pail is not installed correctly, or the hose fitting cap is loose. Make sure that the pail is seated correctly & the cap is tight. Inspect the bottom for rust perforation, too, although this is a long shot. If this fails, then the cold coil may have broken away from it's mount, & is dripping in the wrong place. Inspection with the cover off will reveal any misalignment or broken components. Repair as required.
Jul 17, 2007 | Maytag M7DH45B2A Dehumidifier
Simrad Ap12h Powerpilot Logo
24 people viewed this question
Top Simrad Boating Experts
Michael Vincent Cruz
ray gallant
Are you a Simrad Boating Expert? Answer questions, earn points and help others
