Question about Kodak EASYSHARE 5100 All-In-One Printer
Can you scan old slide photos of a 5100 Kodak Aio?
Need to know how too.
Thanks,
Tam
  • tammy54321 Dec 02, 2008
    Am trying to scan old photo slides from 1971, they are minute photos you can see thew a viewer. Then I was to print them into photos but turn out black when I scan them on my Kodak Aio 5100.
    Tam
  • Alan Matzke
    Alan Matzke May 11, 2010
    May I ask If you are talking about transparent slides?
  • Kodak Master
  • 2,794 Answers
You can set them on the scanner glass and press the scanner button one at time and then edit each one as necessary.
Posted on Dec 02, 2008
  • Tim Babcock
    Tim Babcock Dec 02, 2008
    Go into the control panel setting of the copier and make sure that the scanner is set for color scanning. It might go to black and white by default.
My calibration page printed on plain white text paper
When you calibrate the 5100 AIO, first, you push in the photo paper drawer until it CLICKS. Next, print an alignment sheet. It will use the photo paper. Pull the drawer out, put the printed sheet in the scanner bed, with the arrow in the right hand corner, closest to you. Press start and it will scan and print a sheet on full sized paper.
If your initial scan doesn't print onto photo paper, you don't have the drawer pushed in the whole way. There is a definite click and the green light will turn on.
May 14, 2011 | Kodak EASYSHARE 5100 All-In-One Printer
Tip
I have to agree with you Zeizz. We bought our 5100 in the fall of 2007. After...
Tip of the day:
DO NOT buy a KODAK printer. It is pure **** but worse is the service you'll get from Kodak when you run into a problem.
Their service or lack of service makes me wonder if KODAK isn't about to go into receivership. There is such a desperate tone to their way of doing business these days it makes you wonder.
I've owned all HP printers at home and at work and NEVER had a problem with one of them.
The Koday 5500 displayed a printhead error the same day I purchased it and the issue hasn't gone away.
Stay away from ****.
on Oct 28, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
How can I scan a document. My 5100 AIO does not appear to want to carry out this function
In order to scan, the 5100 needs to be connected to the computer and the Kodak AiO Home Center software needs to be installed. Press the Scan button on the device and press Start to begin scanning. Refer to page 41 of the manual for detailed instructions. If you don't have the manual handy, you can view the PDF here.
Mar 25, 2011 | Kodak EASYSHARE 5100 All-In-One Printer
Koadak easy share all in one, won't print in bacl
Check the version of AiO software you are using. We had to re-install the Aio Kodak software yesterday because the print que did not register when I changed the ink cartridges. The AiO would scan, but the computer side still thought it was out of ink.
Perhaps the latest software will fix your problem too.
Juliasew
Jan 30, 2010 | Kodak EASYSHARE 5100 All-In-One Printer
I would like to reinstall Kodak AIO home center I
Uninstall application, download Kodak printer clear utility from Kodak official website and run it.
Disconnect your internet connection and try again.....
Dec 31, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
The scanner does not work on my Kodak EasyShare 5100 All-in-One Printer. Don't know how to make it work
Hi, if nothing happens when scanning w/ your printer.Please follow the steps below.
1.Verify that the scanner is working properly by copying a document first.
2. Open the Kodak AiO Home Center software.
3. Select Configure Settings.
4. Click Scan.
5. Click either the Documenttab or PictureTab depending on the file you want to scan.
6. Under File Save Setting, sure that the Prompt for filename and location is selected.
7. Click Apply then OK.
Thanks.
Regards,
Neerak21
Sep 24, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak 5100 AiO When printing emails the borders
Read through some of the solutions on here and eventually removed print heads and cleaned them and printing of borders and words is now fine. Still have probs with photos being discoloured .
Apr 12, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Can't load the Kodak AiO Homecenter software
Go to the control panel and uninstall it. Don't just delete the program from windows explorer. Reinstall everything. It SHOULD work fine.
Dec 31, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Will not scan kodak easyshare 5100
Go to Control Panel
Double Click on Printers and Other Hardware
Double Click on Scanners and Cameras
Double Click on Kodak 5100 AiO
Click Next
Read and follow directions
It ain't rocket science
Feb 08, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Home Center will not open...Can't scan
I needed to reload my AiO Home Center software and no one seemed to have the correct procedure. Maybe if you remove & reinstall yours it will resolve your problem. This procedure worked for me on my XP-machine:
1. got to Control Panel/Printers&Faxes and delete the printer
2. go to your Hardware/Device Manager/Universal Serial Bus Controllers, right-click on USB Composite Device and select Uninstall
3. go to Control Panel/Add/Remove Software and remove the EasyShare software
4. disconnect the cables from the Printer
5. download from Kodak.com the program "install_aio.exe"; run the program
(I selected only AiO+EasyShare+Software Updater to load)
6. followed the prompts after the sw installed to reconnect the Printer cables
7. rebooted
WORKED for ME !
Jan 13, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Kodak EASYSHARE 5100 All-In-One Printer Logo
80 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
