Riso gr 3770
Machine was running fine - had a jammed master - cleared it and now get t1 errors - have re-installed the master roll, hit all reset and traced the entire path through the machine and can find no blockages - t1 over and over
  • 92 Answers
Check sensor (photo) that point towards the drum from inside and clean use a flash light to locate good luck
Posted on Jun 28, 2009
Riso RP3700 gives A17221 error msg
have you checked you master disposal unit if there were any masters jammed in it?
Jan 29, 2014 | Riso RP 3700
Riso EZ 200E model gives error message A-34 -218 but all seems fine at master roll installation. What can we try ?
It means to reset the master material in the master making unit. Should be ok after that.
Jul 27, 2010 | Riso RZ220 Duplicator
We have a riso gr 3770 the drum tray will not
under the drum tray there is a rectangular hole, try to actuate the sensor by flat screw
May 10, 2010 | Riso RZ390 Duplicator
Riso gr 3770 error T14
how can i solve the Error T14 for Riso Gr 3770
Thanks
May 12, 2009 | Riso RZ220 Duplicator
Riso GR 3770 master make shadow on it how to fix it?
check the dust or any scar in scanner (glass).
Feb 17, 2009 | Riso RZ220 Duplicator
Code Error T4
T-4 is an ink overflow condition. You may need to check and clean out ink section of drum. Remove the ink then press reset button. Then turn off and on and re-insert ink.
Dec 01, 2008 | Riso RZ220 Duplicator
Riso 3770 Error Code T11
This is a presure motor lock eror . you will have to unplug the potentiomotor on the back of your IO board .
Nov 12, 2008 | Riso RZ220 Duplicator
Error Code T14 on Riso GR3770
The machine is not alinged. I had that code this evening and the guy came here and in no time he fixed it. is your drum going in the machine? if so then turn off the machine and while pushing down the clear/reset button turn the machine on
Oct 16, 2008 | Riso RZ220 Duplicator
Riso gr 3770
- Please check if they have Master Roll Jam?
- Install properly the Master Roll.
Sep 18, 2008 | Office Equipment & Supplies
Riso Rz 220
Remove the master that is on the drum. Then check the master roll remove it cut about 18 inches off then re install master roll. hit the reset, then print bottons.
Jun 11, 2008 | Riso RZ220 Duplicator
219 people viewed this question
jasbo
jasbo
