Question about Hitachi Televison & Video
I have a hitachi DLP TV modle no ux21513
I need to know what lamp will fit this tv ux21513
  • 934 Answers
Lamp with housing is a LM500
But to save a few dollars call Glen at ACME Sales in Florida for the best price on just the bulb and put that in the new housing. It's about half the money.
1-800-575-9833
Bill
Posted on Dec 02, 2008
How does a ballast for a hitachi ultravision dlp tv look
Anon, the bulb/lamp plugs into the ballast, The attached videos shows the ballast and location near the end of the video. Check the attached links. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
HITACHI how to replace your enclosure guide
Mitsubishi Toshiba Samsung DLP TV Bulb Won Turn On DIY Easy DLP Ballast...
hitachi ultravision dlp tv replacement ballast Google Search
Apr 20, 2016 | Hitachi Televison & Video
My tv is a hdmi 50" dlp hitachi it goes outandlamp
What is the Model Number that is Printed on Back of TV?
Apr 12, 2011 | Toshiba TheaterWide 52HM94 52" Rear...
My tv went out the other day completely but when i turn it on there is no picture but there is a flash on the lamp light and temp.
Most likely bad lamp . Listen for a very slight buzz from the rear of tv at power up. IT will buzz several times before lamp light begins to blink. IF it does and pix does not light suspect lamp .. Part number Ux21513
Feb 16, 2011 | Hitachi 60V710 60" Rear Projection HDTV
My Tv is on standby. light keeps flashing on and off. What must i do
This is a common problem for this TV sets the first thing you need to replace and hopefully the only thing is the Lamp they are suppose to last around 2-3 years old here is the lamp you need
http://www.discount-merchant.com/SearchResults.asp?Search=UX21513
Oct 04, 2010 | Hitachi 50V500 50 in. HD-Ready LCD...
Television turned off and red light under lamp is lite. Televion will not turn back on. Is this just the bulb blowing out or is it something worse?
This is a common problem for DLP TV's the average time for the life span is 6000-8000 life hours witch is a average time of 2-3 years of use if you have not replaced the lamp before I recommend you do that first and that should fix your problem and be careful when you buy a replacement make sure it is a Philips not a Generic I found the lamp you need and it is a Philips
http://www.discount-merchant.com/UX21513-LAMP-p/hitachi-ux21513-housing-h.htm
I replaced the lamp with the proper part #UX21513 and followed all instructions, but the lamp indicator is still flashing red and the TV doesn't come on. Is the lamp defective or is there a reset button...
There is no reset button for the lamp. My first resolution would be to unplug the TV, pull the lamp and try to reseat it. Sometimes the contacts are not perfect. Make sure that all panels and doors are closed as many units have a switch that must be activated with a pin on the panel and/or door. This would also keep the lamp from striking.
Also, some units have a default reset and that is done by pressing and holding the on/off button as you plug the power cord back in. Follow up with results.
Jun 30, 2010 | Hitachi 50C10E Lamp
Picture is very dark and hard to see
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast. But if you don't hear any strange noises,tv is around 6000 hrs,2-4 yrs it could be time to replace the lamp.The lamp you need is UX21513.You can find it here: http://www.discount-merchant.com/Hitachi-UX21513-LM500-Replacement-UHP-Lamp-Proj-p/hitach-ux21513-lm500-lamp-bulb.htm?Click=48173 Have a blessed one!
Apr 04, 2010 | Hitachi 50V715 50" Rear Projection...
TV Exploded
Sounds like the DLP lamp failed. You can decipher the Hitachi flashing red light. That should help to be sure.
The DLP lamp replacement is fairly straightforward and can be done with minimal tools
Sep 10, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
Lamp went out on DLP TV
Did you replace the lamp door? A flashing red light is an indication of a door open or an impropely seated lamp. Try removing the lamp and reseating it. Reinstall the door and try turning it on again. Also, you may want to unplug the TV from the power source, count to about 20 and then plug it back up again. This may reset the TV.
Good luck
Aug 09, 2009 | Hitachi Televison & Video
Blinking lights
buy this lamp p/n UX21513 but first take out the old check it should be blown by what you say..
Oct 05, 2008 | Hitachi 60V710 60" Rear Projection HDTV
Televison & Video Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
